The PDF was exported from Adobe InDesign with layer option enabled. We need to delete one of the layer appeared in the PDF. Kindly help me out to delete the layer in PDF.
Yes I agree the figure will not appear if we turned off layer and save as PDF. The thing is two figures were placed in a same place in the PDF. Both figures were assigned as a seperate layer. One is a "Figure" layer and another one is "Default" layer (it was assigned both figures and contents of the page).
On this particular occurrence i want to delete the "Figure" layer without affecting any content in PDF and it should not create a PDF again. This PDF will be ready for Web page. Kindly help me out to solve this issue.
I'm a little confused. If you delete the layer you affect the content.
In his previous post I believe Peter was referring to Acrobat and if so that's a good solution. If you control or right click on the layer in Acrobat, you have the option of changing the default state to "Off". Save the PDF. Now the layer is hidden and won't print, but since it's not deleted you haven't lost it forever.
I did that and it worked but the file size remained large. To completely remove the unwanted layers from the file, you then have to follow up with a Save As. So in summary the steps are: 1. Hide all unwanted layers. 2. If getting rid of all layers, right-click a layer in the layers panel and choose Flatten Image. 3. File > Save as... I'm guessing an alternate method is needed for getting rid of some layers and not others, perhaps involving Merge Layers.
Okay, none of the above works for me. The unwanted layers always reappear after flattening / merging / saving As, even when I hide them.
Here's what worked:
1) HIDE the layers you want to KEEP. (The layers you want to delete remain visible).
2) Select Tools > Advanced Editing > Touch-up Text Tool.
3) Hit Ctrl-A to select all visible text objects.
4) Hit Delete.
5) Select Tools > Advanced Editing > Touch-up Object Tool.
6) Hit Ctrl-A to select all visible objects.
7) Hit Delete.
8) Now, you want to "merge away" the unwanted layers, which are now empty. In the Layers pane, Click the "Options" pull-down and select "Merge Layers...".
9) Hold down CONTROL and click all the UNWANTED (empty) layers.
10) Click "Add".
11) In the right-hand pane (target layer), select the first layer that you want to KEEP. This will basically merge that layer with all the empty ones, and in effect, delete the empty layers.
12) Hit OK, and you're done. When you save the file, the layers you want to preserve are preserved, and the file size is smaller, reflecting the "deleted" layers.
This thread didn't help me even though the subject seems to be precisely what I needed, so I came up with this "brute force" method... Hopefully this helps someone else in the same predicament. If there is a more efficient way of doing it, let me know.
I was able to hide the layers I didn't want, flatten the PDF layers, and have it discard the unwanted layers. FWIW, I had to do this because I had no access to source files, and our Heidelberg RIP software does not honor the "hide" and "never prints" layer options in Acrobat. In other words, we burned a lot of bad plates. I didn't know there were hidden layers at first, and the person burning the plates didn't see the extra content (.25 pt lines intended as a dieline) in the low-rez preview of the plates.
Adobe, just add a "Delete Layer" button already, eh? ;-)
We are using Acrobat X pro and there seems to be no ability to remove layers from a pdf and save-as with only selected layers. We are working with a large (45 mb) file with many many layers. Tunring the layers off is not an optimum solution. We want to be able to delete layers and save-as, in order to create a smaller file that is more managable. Adobe, you should add this function: delete layer!!
Thanks cj2161! You saved my day and my sanity!
I have a pdf with about 40 layers. It's a map that I'm altering/working on. It's very detailed and has all the features I need but unfortunately it also has a lot of features I don't need -- like foot paths, electrical lines, fences and whatnot, all on different layers. I was planning on exporting the pdf into Illustrator and simply delete the unwanted layers there. But that didn't work, the 40 layers always merged into one in the process and I couldn't find a way around the problem. The obvious solution was to the delete the layers in the pdf but strangely there is no delete function. And even if you render the unwanted layers invisible, turn them off (whatever that means) and tick "will not export if invisible" they still get exported. But your roundabout method of emptying unwanted layers and merging them with one of the wanted ones actually works. I don't think I'd have been able to solve this riddle on my own accord.
The original file was autocad but I´ve never worked with autocad. So the pdf was simply a means to get this map into Illustator which I know how to use (more or less). Again, thanks for your help!
Illy can read at least some Autocad formats directly (DWG and DXF). Did you try that?
