I think you guys are making thing way too complicated.
Here is why I got this error.
I had the normal Adobe Reader 8 but I found out that the new Adobe Reader 9 Pro has this OCR text recognition thingy which is the coolest thing ever for college student like me. Anyway, after I downloaded the trail and got the best out of it, it expired and left me with nothing ![]()
I am going to skip the next part because I end up uninstalling the Pro and then installing it again hoping I will get another 30 days (silly me) but from doing all this the 8 got all messed up. ![]()
Now, I competely got rid off the Pro and have 8 but it kept getting the above mentioned error. Here is how I fixed it because nothing worked from the previous posts:
1. I opened the .pdf file
2. I clicked on Help
3. Clicked on REPAIR ADOBE READER INSTALLATION
4...and magically everything works just fine again
I hope this helps to some of us.
Peace!![]()
Unfortunately the instructions did not work for me. I received this 'invalid plugin detected' immediately after I had installed CutePDF Writer. Obviously it has installed a plug-in somewhere which Adobe Reader is picking up on, it then terminates the program. I have uninstalled the programe and have tried to clean my Windows 7 operating system with CCleaner, all to no avail.
ADOBE this is not good news, so many hits on this in Google, you've messed up big time. The only way to get to my PDF documents is to get another PDF reader installed. I guess that is the last Adobe wants, so please get your finger out and sort this out.
Let me recap; Adobe Reader is not working and you suggest to let CutePDF know and provide a solution? CutePDF is working very well! Considering that more than 3 million queries were raised through Google on this very subject makes me wander whether Adobe actually realizes to scale of this problem.
I have resolved the issue by renaming the "plugins" directory to "plugins deleted" and then restarted Adobe Reader. It has rebuilt a new directory and the program works fine now. The option in the Help pulldown menu does not work for me.
Pieter.
You told me that Reader was working fine UNTIL you installed CutePDF. That would seem to imply that when they install their software it causes problems for us. I also know that users who do NOT have CutePDF installed don't see any such problems. Seems pretty clear where the problem(s) lie.
Also, be aware that without plugins installed, you have turned off a HUGE amount of functionality in Reader including the ability to properly view and interact with a variety of PDF files.
Wouldn't it be easier to use a proper Adobe Reader and a PDF creation tools that doesn’t cause conflicts? There are other free PDF creation tools out there that don't have such issues...
I have met the same problem.
Our plugin is developed using SDK 7 and worked fine under Acrobat 7/8/9.
This afternoon we receive the certificate from adobe and then i use "SignPlugin" tool to sign our plugin.
The sign process is successful.
But when i start up Reader 9.2 it shows the error.....
Could somebody tell me why?
I have build my plugin with acrobat 8 SDK by VS2005.
And then run makemd32.exe return by adobe as the following steps:
Next i replaced my plugin's API_ENCRYPTED_DIGEST data segment by msgdig.rc.
Build my plugin.
Startup Adobe Reader 8,the same error appeared.
Also,the cert returned by adobe is 624 bytes and i noticed that it should be 554 bytes said by "Developing Plug-ins and Applications" in acrobat 8.1 SDK,
Is it OK?
For Reader 9 I see the helper below pointed by adobe.
As the doc mentioned,after I receive my cert i just need using SignPlugin.exe to sign my plugin,but that cause the "Plugin Hash Failed" error.
If i copy the dummy.rc & RIKLA-DigCert.rc content into my plugin's resource file,the signing process is successful.
But it can not load by reader 9.
Did i missing some keys?
But the agreement said that
“Reader” means versions 8 and 9 of the Adobe Reader software application, on any platform, if made generally commercially available by Adobe during the Term.
Even if the key is only for Reader 9, i signed my plug in conformed the way Adobe mailed me and it still can not be loaded.
Thanks P-Jansen!
The solution from 'bulgariangirl' didn't work for me either, so I try the one from 'P-Jansen' and worked. Goto C:\Program Files\Adobe\Reader 9.0\Reader and rename the [plug_ins] folder to [plugins deleted] (Maybe any name will do it, but I prefered to go with the sugested one.) Restart Adobe Reader and walla! Error is gone! ![]()
At least from the user point of view this quick fix works, however, for developers the root of the problem is not solved yet.
Excuse me. I don't know if my case is the same as the rest of people, but maybe It can be usefull to tell you. Two days after the mentioned error message appeared I was thinking a little about what I did on my PC just before the error began to manifest. I realized I just installed Babylon software (the trial version). Then I uninstalled it and all is right again. Good luck![]()
I went to adobe file under reader deleted all plugin files. then went to control panel and opened program, clicked on aadobe and clicked on change and selected repair and all right plug ins are added. then the error did not show any more. this good luck
c:program files: adobe: rader' reader: plugin
As you see I am not technical, however I took the risk based on comments on this blog and it worked.
Good luck![]()
Great!!!. That is better. Thank you very much. Tell me: ¿Does Babylon
work correctly?
El 22/07/2010 5:32, riv6 escribió:
thank you!!
I have the same case, but I didn't unistall the Babylon. I just removed the Babylon folder in
C:\Program Files\Adobe\Reader 9.0\Reader\plug_ins
and the adobe reader works great!
thanks
After Install Acrobat Reader 9.3.3 in Hebrew I Got this message invalid plugin detected. Adobe Reader will quit
Last night I installed Babylon 8.0, Feedburner and Wordfst and after these actions I couldn't open my Adobe Reader 9.3.3 which functioned fine before these installations. I went to C:\Program Files\Adobe\Reader 9.0\plug_ins and find that the main culprit for this was Babylon 8.0. Then I tried to remove it but every time I opened Babylon this folder recreated itself. I probably should have deleted it completely, i mean the whole program but I really need it so now I use one at the time and every time I have to move Babylon plug in to folder Optional or to delete it. It works only if Babylon is closed. Only then my Adobe Reader works. I have to say its really tiresome...
in response to: (Jittu_Sharma)
Nov 16, 2008 10:37 AM in response to: (bruce628) Re: the error "invalid plugin detected. Adobe Reader will quit"
I followed your instructions
"You can find these in the "plug-ins" folder. [C:\Program Files\Adobe\Reader 9.0\Reader\plug_ins]"
I finally found my culprit, I deleted one file folder at a time, then restored them from my Recycle Bin.
I finally found my culprit, in the folder “Babylon” the file “BabylonRPI" was the main culprit.
I deleted the whole Babylon file folder, and havent had the error "invalid plugin detected. Adobe Reader will quit" ever since.
Thank you very much kid, you kept it simple, I am not a Techie either.
It is very useful your info. I have not tried again. I have
uninstalled Babylon like you. I will not installed it until Babylon
repair this bug. I think that is the better to do.
Thank you
R
