Deadline on Monday! and I can't EXPORT!
Jan 8, 2010 12:58 AM
Hello I have a big project:
Lots of assets - I also used extensive footage from Premiere Pro and used the amazing dynamic link.
I'm using the Render queue - Lossless preset.
So I don't think its a problem with conversion codecs etc...
some composiitons\parts of the project I can export - but some I can't - I think it might have something to do with muti-cores\RAM issues.
what can I do?
I need to export it back to premiere to do the Music & effects part.
I tried sending a comp to Premiere but the Apple will just kept on turning endlessly.
Help me please!
My specs:
(Leopard 10.5.7):
CPU: Core i7 920
RAM: 12gig
GPU: GTX 285 2GB OC
HDD: 6 X 1 TB HDDs: 4 HDDs in RAID-0 and 2 HDDs for System.
    Jan 8, 2010 7:44 AM   in reply to ArkaPro
    I know you're in a hurry but you've posed to at least one other forum so we expect you to come back and eventually close all of your threads by supplying us with your solutions--where ever you received them.
    You have not provided any tangible information aboutyoru codecs for us to help you decide if that's related at all.
    The usual advice to these inquiries is to ask why you waited so long to test your workflows but that doesnt help you out so nevermind.
    You probably don't want to export, you want to render. Do you understand the differences? Can't tell from you post.
    bogiesan
    Jan 8, 2010 8:26 AM   in reply to ArkaPro
    As David said, you are giving us nothing to work with. If only parts do not render, this would mean that they either use specific effects that cannot work in the environment you chose or a specific kind of source ffotage is making things go belly up.
    Mylenium
    Jan 8, 2010 5:47 PM   in reply to ArkaPro
    hmm, i agree with the previous posts. maybe it has something to do with too much data in one composition and try reducing as much as you can until it works. if nothing works try it on another machine, also try checking on/off the multicore rendering in the preferences box, sometimes my AAE gets stuck if its doing multiple.
    Jan 9, 2010 8:46 AM   in reply to ArkaPro
    > Hey thanks on replying here and on the "Cow" - i'm not sure if its OK to post in two diffrent foums - if thats the xase I'll delete on of the threds.
    If you do cross-post, we ask that you do your best to make sure that you post resolutions to all threads so that people on one thread don't waste their time suggesting things that someone else has on another thread---or even trying to help you after you've already gotten your problem solved. (See this post.)
    > When I say "export' I mean using the "send to render Queue" - I'm not sure about what you mean "render"
    Definitions are on this page: "Rendering and exporting overview"
    > also when AE lunches it says:
    4% out of 3.0GB RAM is used... (???)
    is it because Leoprad is and AE CS4 is 32bit - is it normal?
    Read this: "FAQ: Why doesn't After Effects see and use all of my RAM?"
    Jan 9, 2010 9:55 AM   in reply to ArkaPro
    > but please don't delete this thread...
    Nobody said anything about deleting your thread. We were just informing you of a certain kind of courtesy that is the norm on such forums.
    Jan 10, 2010 5:42 PM   in reply to ArkaPro
    That message says pretty much what it seems to say: After Effects is having a hard time creating a large enough block of memory to render that frame.
    Try this search, which pulls up some great resources on working past this error.
