Rendering issue with the navigation tree in AdvancedDataGrid
Dec 1, 2009 9:54 PM
I need to display a hierarchical data in ADG.I am using HierarchicalGroupData with an xml as the dataprovider.I am facing a rendering issue when i am expanding any particular node for the first time.What happens is that there is a delay before the items in the tree are displayed(By this time the items in the other normal columns will be displayed and the tree column for the opened node will appear blank for a second).When i collapse and expand it again , it is not happening.It happens just the first time only.
Any help in this matter will be appreciated.
    Dec 2, 2009 12:37 AM   in reply to flex2008
    Perhaps the delay is caused by the creation and initialization of your renderers. Can you post the code for your grid and renderers?
    Jan 18, 2010 3:34 AM   in reply to flex2008
    I tried the sample and it seems to be working fine.
    Can you post the sample application with your latest code changes?
    -Sameer
    Jan 21, 2010 10:49 PM   in reply to flex2008
    It seems to be an issue with using Containers as renderers. Please log a bug here - http://bugs.adobe.com/flex
    I tried with a simple (very basic) renderer extending UIComponent (containing a Label) and things are working fine.
    I've attached the renderer for your reference, you can add more things to the renderer and use it.
