Currently, whenever I attempt to start Photoshop CS4 Extended, it launches fine. However, when I try to open a document (doesn't matter whether it's an old photo or a new blank one), I get an error:
The specified module could not be found. C:\Program Files\Common Files\Adobe\Adobe Version Cue CS4\Client\4.0.0\VersionCue.dll
I have tried to find a solution (particularly here), but not to much avail
. I'm currently using Windows 7 Ultimate, 32-bit.
I have seen it, however, in several steps (particularly step 4.2, solution 2) it mentions a folder "ProgramData". I have ran a search on my computer, and found no such folder on neither Local Disc C or D. And probably the most annoying thing is that the error pops up every few minutes (around a 20-25 minute interval) and closes anything I might have open (it also restarts Windows Explorer, closing any folders, minimized and open).
are you on vista/7? ProgramData is a hidden folder found in the root of the C drive (i.e. c:\ProgramData). To show the hidden folders check out this link:
http://windows.microsoft.com/en-us/windows-vista/Show-hidden-files
So... what am I looking for? I attached a screenshot of the folder (sorry, I really suck at this
Thank you so much, you've been of great help. However, now, whenever I try to Right-Click (other than on my desktop), I get the same error, and Windows Explorer restarts (apparently it wasn't at random
). Even if I am able to finish this whole process without Right-Clicking, I am going to need it at some point in the future, so I would like a permanent solution.
A quick check to see if you have a virus loaded is to type in MRT in start, start search. Click on the mrt.exe and let it run. You can also do that in the safe mode. This is a very good tool to use and it is downloaded every month on your computer.
If you have anti-virus software run that in windows safe mode too.
I have fixed the right-click problem, however my main problem is still unsolved
. I have followed the stops closely, and reached step 4.5, solution 2. It says "click Edit" however, I have found no Edit button there. I have tried clicking on the "Change Permissions" button, and there's an Edit button there, but the other steps don't match. I think I'm doing something wrong yet again
. Thank You all once again for your help.
Hello,
I'm having the same problem (I'm running Vista). Photoshop opens fine, but I cannot create or open any files. When I browse to the directory where this dll should be, I can see it's not there.
I'm using the trial version to try it out before I spend the money on it. However, I have'nt been able to do anything with it. I'm a little worried about unistalling the trial version, since it may not allow me to reinstall (that's happend before).
Anyway, is there any chance that someone would upload the dlls in their "Version Cue CS4/Client/4.0.0" directory? Does anyone know of another solution?
Looks like the same problem
. I've re-installed, re-updated and repeated the Adobe solution over and over, but still nothing.
Edit: I've reinstalled Photoshop from a friend's CD (using my code) and it's still the same problem, so I highly doubt that it's got anything to do with the installation. I'd be very grateful (as I'm sure DevourerOfWorlds would be) if someone uploaded their own file. I'm sure it won't take too long to just attach it
Edit: I've reinstalled Photoshop from a friend's CD (using my code) and it's still the same problem, so I highly doubt that it's got anything to do with the installation. I'd be very grateful (as I'm sure DevourerOfWorlds would be) if someone uploaded their own file. I'm sure it won't take too long to just attach it.
Yes, that would be nice. Could someone at least confirm that they have the dlls? The directory is "C:\Program Files\Common Files\Adobe\Adobe Version Cue CS4\Client\4.0.0".
Your welcome. I found on the Adobe download page the 4.0.1 version cue update for windows. When you download it make sure you right click on it and run as admin.
Also if you have a download problem turn off popup blocker in Internet explorer.
http://www.adobe.com/support/downloads/detail.jsp?ftpID=4218
Edit: Make sure nothing Adobewise is running or running in the background before install.![]()
Yea, I keep getting an error (-_- Adobe Version Cue CS4 Version 4.0.1. - Adobe Version Cue CS4 server not installed). You know what, I should just buy Photoshop Elements. What's another $80 when I've already payed $200
Edit: By the way, I redownloaded, and now it actually opens, but I still can't install it.
This is getting frustrating....
I'm having a hard time finding any support or contact info, since I'm just using the trial version. I've tried all the suggestions I could find, and none have worked.
I'm very glad that I did not spend any money on this yet (sorry a.nasteveski
), and it doesn't look like I'm going to.
Thanks for all the help!
Okay, I finally got it working. Here's what I did:
First, I removed the "Version Cue CS4" directory.
I then downloaded and installed the Adobe Illustrator CS4 trial. What I was hoping would happen is that the directory would be replaced. I was right. I'm not sure if it was Illustrator, or Bridge that needed the files, but either way they were replaced.
I made a backup of the directory to make sure that if this happened again, I would be covered (even though my trial ends in 30 days
You may not have to install Illustrator. You may just need to reinstall Photoshop (the only reason I installed Illustrator is because I can't reinstall the trial version). Just make sure you first remove the "Version Cue CS4" directory to ensure that it will be replaced.
Thanks for the help! ( Hope this helps a.nastevski! )
