I installed CF9 trial develop edition on windows 7 64 bit ultimate.When I attemp to reach http://localhost/CFIDE/administrator/ I get this error:HTTP Error 500.19 - Internal Server Error.Is there anyone else can help me for solving this.
That could mean anything to be honest, do you have any more info? Does it give you a more detailed error message anywhere?
O.
Is this straight after the install when the setup routine first tries to browse to that URL to complete the install? Or did that work OK, and are you getting this on subsequent hits to CFAdmin?
Is the CF service running when you try this?
Adam
I'll tell you what my money's on actually - have you installed "Application Development" and "IIS6 Metabase Compatibility" under your Roles for IIS?
IIS7 needs these extra modules in order for CF to function properly.
Yes this is straight after the install period try to launch coldfusion administration page which on localhost I got that Error Code.By the way I did IIS 6 compalibility and tried lost of things.
Was it a standard or multi-server install?
What happens if you browse to http://localhost:8300/CFIDE/administrator?
I'm not sure about the port, you'll need to check your JRun.xml file for that, down in the <service class="jrun.servlet.http.WebService" name="WebService"> section. On a multi-server install it's in the [Jrun dir]/servers/[instance dir]/server-inf/ dir. Not sure about on a standard install.
Adam
I reinstalled to coldfusion following the steps like here
http://www.codecurry.com/2009/09/installing-coldfusion-on-iis-7.html but now I get this error HTTP Error 404.2 - Not Found ISAPI and CGI restrict list settings
