I bought a netbook to 10 "and I was able to install Photoshop CS4 but the ACR window is too large and the bottom is beyond the verge of developing screen.
Is it possible to resize the ACR or there another solution?
thanks
The minimum display dimension supported in Camera Raw is 1024px x 768px...that is the smallest possible UI designed arrangement. There's nothing the ACR team can do to alter that since the minimum dimensions of Camera Raw are dictated by the minimums display size of Photoshop which is also 1024 x 768.
I use this EEE PC utility, other netbook should have similar utility: http://www.youtube.com/watch?v=9NCBkouIXag
I have the same problem. I also have a netbook with a 1024x600 px display. ACR will work and all the adjustments are operational. The problem comes when you want to 'open image'. Simply hit 'return' This is the default operator in ACR and it will now open in PS.
I cannot find how you can change the output resolution. If any one has any ideas, let me know.
