ALC-WKS-007-040 error
Oct 1, 2009 6:34 AM
I'm getting this error occasionally when rendering the PDF in the workspace.
If I just open the PDF and save it with some minor changes it works fine.
I am unable to find the root cause for this problem.
This happens for both 'Default Render ES Update 1' and for my 'Custom Renderer'.
Any help is appreciated.
Nith
    Oct 1, 2009 6:49 AM   in reply to $Nith$
    This is problem with the render service.
    I would recommend to enable record and playback to see where it fails. The log file, or the stack trace of the error would be useful.
    Jasmin
    Oct 1, 2009 7:39 AM   in reply to $Nith$
    If you get an ALC-WKS-007-040, you will have an error in the log. You would also be able to use Record and Playback to check where it fails. This has nothing to do with BAM.
    That being said, you can remove the Lava_Adobe.ear file from the JBoss deploy folder if you're not planning on using BAM to free some memory and speed up the JBoss start time.
    Jasmin
    Nov 3, 2009 7:34 AM   in reply to $Nith$
    Hi Nith,
    I have the same problem, can you show me how to increase the default document disposal timeout value.
    Thanks in advance,
    Han Dao
    Jan 21, 2010 1:33 AM   in reply to $Nith$
    Hi all,
              Am currently working in LC ES2. Am facing an issue of ALC-WKS-007-027 when i try to open the form in the worklist after submitting in the workspace. Can u help me here.?
    Desc.: In Assign Task service --> Presentation & Data --> i use .xdp as an assest and Initial Task Data variable as xml.
              In Assign Task service --> Output --> Output Data variable is the document type.
    I am not sure of the different variable types to be used.
    Pls anyone help me of which variable and type of variable to be used so that this doesnt cause any issue in initiating the workflow.
    Thanx in advance
    Balaji
    Jan 21, 2010 2:20 AM   in reply to $Nith$
    yes anand, i did try it.
    Still the same scenario happens.
    Balaji
    Jan 21, 2010 6:35 AM   in reply to Balaji Gurumurthy
    What about if you put the same xml variable for the output.
    Jasmin
    Jan 21, 2010 6:36 AM   in reply to Jasmin Charbonneau
    Can you post the server.log. It might contain more information on the error.
    Jasmin
    Jan 21, 2010 8:50 PM   in reply to Jasmin Charbonneau
    i have attached the server log along with the other issue faced :
         2010-01-21 21:20:27,190 ERROR [com.adobe.workflow.AWS] stalling action-instance: 122251 with message: ALC-DSC-003-000: com.adobe.idp.dsc.DSCInvocationException: Invocation error.
    at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(Defaul tPOJOInvokerImpl.java:152)
    at com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(In vocationInterceptor.java:140)
    at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.procee d(RequestInterceptorChainImpl.java:60)
    at com.adobe.idp.dsc.interceptor.impl.DocumentPassivationInterceptor.int ercept(DocumentPassivationInterceptor.java:53)
    at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor$1.do InTransaction(TransactionInterceptor.java:74)
    at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapt erBean.execute(EjbTransactionCMTAdapterBean.java:357)
    at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapt erBean.doSupports(EjbTransactionCMTAdapterBean.java:227)
    at sun.reflect.GeneratedMethodAccessor299.invoke(Unknown Source)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces sorImpl.java:25)
    at java.lang.reflect.Method.invoke(Method.java:597)
    Hope this helps u to solve my issue.
    Thanx
    Balaji.
    Jan 22, 2010 3:17 AM   in reply to Balaji Gurumurthy
    The exception trace shows two distinct exceptions.
    1. com.adobe.idp.taskmanager.dsc.client.task.TaskManagerException: CustomUI is specified, but no CustomUI Path is specified for Task: 9557
    This exception is there because "Workspace User Interface" in Assign Task is set to custom, but no path has been provided. Please set it to default. Or if the requirement is of a custom UI, please provide the path.
    2. 2010-01-21 21:09:17,868 WARN  [com.adobe.workflow.AWS] ALC-FUT-001-001: Unable to overwrite file c:\test\.
    This is the same exception as discussed here (http://forums.adobe.com/message/2536189#2536189).
