MacLaeod
Too many TPC sockets opened for a single IP
Jan 15, 2010 10:51 AM
Hi there,
I am running a ColdFusion server on a VPS to HostMySite.com and lately we are having strange problems with it. Every few minutes the server is not responding even if we restart the services - IIS and ColdFusion - and even the whole system.
HMS guys investigated the problem and they discovered that every connection to the server is openening multiple sockets for a single IP address (every single visitor).
Here is the full message from HMS technician, do you have any previous experience related to this?
I've been doing some advanced monitoring and troubleshooting of your VPS over the last 24 hours.
It is important to understand that the issue you're actually experiencing is related to TCP sockets.  Every connection to your server opens a socket and sometimes multiple sockets for an individual IP (visitor).
I opened the site http://www.viaromania.eu/ and instantly there were 7 connections established from our IP address.
C:\Documents and Settings\hmsadmin>netstat -ano | find "209.41.163.23"
TCP    76.12.37.79:80        209.41.163.23:9563     ESTABLISHED     4
TCP    76.12.37.79:80        209.41.163.23:21164    ESTABLISHED     4
TCP    76.12.37.79:80        209.41.163.23:26819    ESTABLISHED     4
TCP    76.12.37.79:80        209.41.163.23:36833    ESTABLISHED     4
TCP    76.12.37.79:80        209.41.163.23:37624    ESTABLISHED     4
TCP    76.12.37.79:80        209.41.163.23:39566    ESTABLISHED     4
TCP    76.12.37.79:3389      209.41.163.23:2577     ESTABLISHED     141388
After just browsing around a few pages on the site you can see how my connections are expanding.
TCP    76.12.37.79:80        209.41.163.23:2852     ESTABLISHED     4
TCP    76.12.37.79:80        209.41.163.23:2900     ESTABLISHED     4
TCP    76.12.37.79:80        209.41.163.23:11014    ESTABLISHED     4
TCP    76.12.37.79:80        209.41.163.23:11178    TIME_WAIT       0
TCP    76.12.37.79:80        209.41.163.23:14107    ESTABLISHED     4
TCP    76.12.37.79:80        209.41.163.23:14248    ESTABLISHED     4
TCP    76.12.37.79:80        209.41.163.23:17177    ESTABLISHED     4
TCP    76.12.37.79:80        209.41.163.23:17606    ESTABLISHED     4
TCP    76.12.37.79:80        209.41.163.23:17930    ESTABLISHED     4
TCP    76.12.37.79:80        209.41.163.23:23460    ESTABLISHED     4
TCP    76.12.37.79:80        209.41.163.23:24594    TIME_WAIT       0
TCP    76.12.37.79:80        209.41.163.23:25191    TIME_WAIT       0
TCP    76.12.37.79:80        209.41.163.23:25507    ESTABLISHED     4
TCP    76.12.37.79:80        209.41.163.23:32301    ESTABLISHED     4
TCP    76.12.37.79:80        209.41.163.23:33591    ESTABLISHED     4
TCP    76.12.37.79:80        209.41.163.23:37338    ESTABLISHED     4
TCP    76.12.37.79:80        209.41.163.23:38404    TIME_WAIT       0
TCP    76.12.37.79:80        209.41.163.23:45140    ESTABLISHED     4
TCP    76.12.37.79:80        209.41.163.23:49734    ESTABLISHED     4
TCP    76.12.37.79:80        209.41.163.23:53755    ESTABLISHED     4
TCP    76.12.37.79:80        209.41.163.23:55735    TIME_WAIT       0
Over the last 2 days there are 205 coldfusion-out logs and they are all full of the same error:
java.net.SocketException: Software caused connection abort: socket write error
Normally when we see this we'll make a few registry adjustments that allow for more socket connections and a shorter time to live on existing socket connections.  However in your case all of the registry adjustments have already been set.
MaxUserPort 65534
TcpNumConnections 200 connections
TcpTimedWaitDelay 30 seconds
I adjusted the TcpNumConnections to 500, see if this alleviates the issue.  Note that allowing 500 Tcp Connections is not necessarily a good idea as this amount of traffic could theoretically bring down your server.
I created a scheduled task that executes every 60 seconds in which it counts the connections on port 80 and writes it to the file netstat.txt on the desktop.
After logging for the last 24 hours it has gone over the 500 TCP connections 19 times all between 2:21pm and 2:40pm
2:21 PM 1367
2:22 PM 1423
2:24 PM 1684
2:25 PM 1466
2:26 PM 1867so
2:27 PM 1250
2:28 PM 854
2:29 PM 796
2:30 PM 799
2:31 PM 794
2:32 PM 816
2:33 PM 730
2:34 PM 662
2:35 PM 524
2:36 PM 531
2:37 PM 539
2:38 PM 551
2:39 PM 551
2:40 PM 522
So this is pretty good news.  This means your site over the last 24 hours only had 19 minutes of issues due to TCP connections.
Please, post your messages if you know why so many sockets are opened for every single IP and if this is a normal behaviour.
Greetings,
Adrian.
  • Jochem van Dieten
    Apr 8, 2001
    Jan 15, 2010 12:11 PM   in reply to MacLaeod
    I am trying to look at some stuff on your site, but that is kind of hard as it is down. But from the 3 requests to the site that worked it appears as if you are routing pretty much everything through a /cazare.cfm template. Not just HTML, but images, JS and CSS as well. That is quite likely a big part of what is causing the problem. ColdFusion really isn't very efficient in serving static content in the first place, and on top of that it is really bad at working together with the caching mechanisms in the browser. If possible, move your static content somewhere where it does not get processed by CF. And if you can't, make sure to add some expires headers and the like to your assets to they browser does some minimal caching and will not request every asset for each request.
  • Jochem van Dieten
    Apr 8, 2001
    Jan 30, 2010 4:12 AM   in reply to MacLaeod
    MacLaeod wrote on 1/27/2010 11:01 AM:
    Too many HTTP requests are opened for each visitor we have and we have over 2,000 TCP connections opened simultaneous. Please, check the attached screenshots.
    Does anyone knows if this is normal? Notice how many TCP connections are oepened for a single external IP.
    That number of connections for an external IP does not really mean
    anything if you don't know how many people are behind it. It could be
    one person, or a proxy for 3000.
    I have been looking at your site a bit using Chrome's speed tracer and
    the two things that stand out most on an HTTP level (and hence on a TCP
    level) are:
    - you have no caching set up for your /images/* folder. See
    http://www.mnot.net/cache_docs/ for a decent explanation. I would
    recommend both a max-age and a public setting. For an IIS manual see
    http://www.microsoft.com/technet/prodtechnol/WindowsServer2003/Library /IIS/0fc16fe7-be45-4033-a5aa-d7fda3c993ff.mspx?mfr=true
    - you are disabling HTTP caching of some of your CSS by changing the URL
    every time. /livezilla/templates/style.css?cache=0.6557160455307057 is
    not cacheable if you change the number on every request.
    Try out Chrome's Speed Tracer yourself and make sure you fix everything
    it flags as critical.
