Digital Signatures and date fields
Feb 1, 2010 2:11 PM
I have a form with digital signatures.  I understand that the digital signatures have a date on them but until we are fully electronic with the form some users may still print sign and date.  With that said we will have a date field next to the signatures.  Is there anyway to default the date field to whatever date the form was signed - to tie them together some way?  If not is there anyway to make the date field not be less than today's date?  That it can't be post dated?  Thanks!
Jodi
    Feb 1, 2010 3:20 PM   in reply to Jodi1725
    Check the Digital Signature status, if it is in signed state populate the date field with date.
    But problem is it will show the current system date, may be user can change their pc/laptop dates.
    Please check the attached sample. Script written on change event of Digital Signature field.
    RAGHU.
    Feb 2, 2010 10:47 AM   in reply to Jodi1725
    I could not find any problem with same code with 7.2, 8.2, ES2 designers.
    what is the designer and reader versions ur using?
    Can u post the form to debug? if not copy atleast the signature and date field to new form and post here.
    RAGHU.
    Feb 2, 2010 11:07 AM   in reply to Jodi1725
    Use as
    var getSigField = event.target.getField("form1[0].#subform[0].FacStaffSig[0]");
    in ur code on signature field for form1 and FacStaffSig has missed -[0], when accessing the field its required in this way.
    RAGHU.
    Feb 2, 2010 11:22 AM   in reply to Jodi1725
    u added for signature field only also needs to add form1[0].
    Then give reader extentions and sign it will work.
    RAGHU.
    May 27, 2010 8:45 AM   in reply to Jodi1725
    I am also having problems with this. Using the script it works no problem on page 1 when i duplicate it for page 2. I cannot get it to work. Any ideas what i am doing wrong
    http://www.mediafire.com/file/3meamzt5mgm/testing.pdf
