Oscar Abrams
Designing a book for print
Feb 2, 2010 11:01 PM
When creating a non-fiction book in InDesign, and submitting it to a offset printer, should the book cover be a part of the main indd file (that has the book pages)  or is a separate file created for the cover?
    Feb 2, 2010 11:08 PM   in reply to Oscar Abrams
    It is not a problem to send single file. But the cover is in 2/4 colour and inside pages are in single colour than send separate cover file.
    Feb 3, 2010 12:17 AM   in reply to Oscar Abrams
    at times a cover involves setting the magin, spine and bleed which in most case not applied inside i suggest NO!!!
    Feb 3, 2010 12:19 AM   in reply to Oscar Abrams
    I usually work with 2 or even more files. The cover has a different size if you produce a hardcover book. And even if you're producing a paperback it has a back, so you're forced to work with at least 2 innd documents.
    Feb 4, 2010 10:02 PM   in reply to Oscar Abrams
    That is between you and the printer. Ask them their preference. I'd expect it to be separate.
    Feb 5, 2010 9:00 AM   in reply to MichaelKazlow
    2 files without question. If you are doing any kind of a wraparound cover you must have a separate file for the cover. The printer won't know the depth of the spine until final page count and stock determination.
    Feb 5, 2010 12:44 PM   in reply to Mr. Met
    Also, apart from its being two separate print jobs, with two files either can be changed separately, minimizing confusion and errors.
