Email form as PDF, not XML
Jan 7, 2008 11:04 AM
  Latest reply: tdsilk, Aug 3, 2011 6:52 AM
Replies 1 2 3 Previous Next
    Feb 4, 2010 6:27 AM   in reply to Jasmin Charbonneau
    Thanks for replying, Jasmin!
    Can you explain what I need to do in order to "Reader Extend" the form.
    Feb 4, 2010 6:39 AM   in reply to CKVisiuals
    See post http://forums.adobe.com/message/2221568#2221568
    The comment about 500 users, is because you can also use Acrobat to Reader Extend a form if the form is going to be used by less than 500 users.
    Jasmin
    Feb 4, 2010 6:48 AM   in reply to Jasmin Charbonneau
    Hi, Jasmin.
    I'm a bit confused by this message and not sure why I've received.
    Looking for all the information, the Reader Extension can be
    accomplished using Live Cycle? What is the alternative, I'm working on
    a Mac with OS 10.3.9?
    Cathy
    Mar 3, 2010 11:14 AM   in reply to pguerett
    I had been having the same problem and thanks to all of the good responses from everyone, I got mine to work by changing the Email Button to just a plain Button and adding the email address of my choice to it and changing the XML option to PDF.
    This is also nice because now if there is a change in personel, all I have to do is change the email address tied to the Button.
    Mar 3, 2010 3:37 PM   in reply to Edved_22
    Thanks for your response.
    What version of Acrobat are you using?
    Mar 4, 2010 5:15 AM   in reply to CKVisiuals
    Acrobat 9 Pro
    Nov 10, 2010 7:24 AM   in reply to (WorkflowUser)
    I too am attempting to create a PDF file that can be emailed.  When I go to the Object Pallete, the only tab that I have is the Field tab.  I do not have a submit tab that is open under the Object Pallete.  Is there a setting or something that I am missing.  I am using Adobe LiveCycle 8.0 to create the form.  Any help that could give would be greatly appreciated.
    Nov 10, 2010 7:33 AM   in reply to Rick7808
    Under the Field tab, you need to click on Submit instead of Regular and the Submit tab will show up.
    Nov 10, 2010 7:52 AM   in reply to Edved_22
    When you say click on submit instead of regular, I am not sure what you are referencing.  Here is all the information that I have in my field tab.
    cid:image002.jpg@01CB80C5.45F26FE0
    Master Deputy R. M. Slough
    Henrico Sheriff's Office
    Computer Coordinator
    Office:  501-5553
    Mobile:  349-2322
    Nov 10, 2010 7:54 AM   in reply to Edved_22
    Nov 10, 2010 8:12 AM   in reply to Rick7808
    Ok, I see.
    On the top drop down, change it from Email Submit Button to Button, then set it up from there.
    Under the Submit tab that will appear, change XML to PDF and put in the person's email address that you wish it to go to.
    Hope this helps.
    Nov 10, 2010 8:18 AM   in reply to Edved_22
    I was able to finally get the submit button to come up by choosing
    button as type and then clicking on submit in the control type.
    Then the submit tab appeared and the only thing that I found was that the for was going to be sent to a URL, not an email address.
    Nov 10, 2010 8:24 AM   in reply to Rick7808
    In the URL field type in:      mailto: name@email.com
    It works the same way, I have setup several that way and it works everytime.
    Nov 12, 2010 5:02 AM   in reply to Edved_22
    Thank you for the tips.  That worked.
    Office:  501-5553
    Mobile:  349-2322
    Aug 3, 2011 6:52 AM   in reply to (Paul_Urgero)
    Got it to work by changing the xml source
    type from xml to pdf. Then opening the file
    in Acrobat to "Extend the services". The
    only issue I have now is how to allow MAC
    user's to submit the form. I had a MAC user
    tell me that when they click on the SUBMIT
    button nothing happens. Is there something
    special in the code that will allow them to
    submit the form?
    Troy
1 2 3 Previous Next
Actions
