Adobe opensource SVN and all the authentication trouble
Jan 30, 2010 12:15 PM
Has anyone at Adobe looked into this yet.
I know you're busy boys and girls but this is just driving me nuts.
it's the same on all the projects hosted there. no matter what you do, at some point they will just start asking for user/pass. then you need to delete and start over.
Has anyone even got a clue as to why this started happening?
it looks as if at some point in the update the url root is called and thats what triggers the auth request?
Im sure you most likely have other non public repositories on there but couldnt you just put those somewhere else so you can open the root url and stop this from driving me over the edge :-)
really though, it's been going on for a while now and could do with fixing. Im sure if you just make the root url open, in fact so we could just see all the OS projects on there together then the problem would stop. wouldnt it be possible to move anything you dont want the public to see to somewhere thats not on the opensource repository root?
just a thought.
cheers
glenn
    Jan 30, 2010 12:50 PM   in reply to Glenn Williams
    The root url guess is new actually, our tests had shown corrupted files which we couldn't figure out.  I'll pass the root url idea on.
    Matt
    Jan 30, 2010 1:31 PM   in reply to Glenn Williams
    Glenn, do you have any logs that show when the auth request is occurring and what files worked before that occurred?  Our team is still pretty confused and we seem to not be running into it internally.
    Also, does your SVN client support 1.6 (it's not an older client)?  Which client are you using?
    Matt
    Jan 31, 2010 12:22 PM   in reply to Glenn Williams
    You have a sandbox right? Is anyone who doesn't have a sandbox account running into this?
    Jan 31, 2010 2:36 PM   in reply to Glenn Williams
    It's possible, I don't know exactly how the svn groups are set up.
    Feb 4, 2010 11:26 AM   in reply to Glenn Williams
    I was trying to update flex/sdk/trunk, and i got authorization request.
    I run sniffer to find out what happened.
    Sniffer showed:
    Request:
    OPTIONS /svn/opensource HTTP/1.1
    Host: opensource.adobe.com
    User-Agent: SVN/1.6.2 (r37639)/TortoiseSVN-1.6.2.16344 neon/0.28.4
    Keep-Alive:
    Connection: TE, Keep-Alive
    TE: trailers
    Content-Type: text/xml
    DAV: http://subversion.tigris.org/xmlns/dav/svn/depth
    DAV: http://subversion.tigris.org/xmlns/dav/svn/mergeinfo
    DAV: http://subversion.tigris.org/xmlns/dav/svn/log-revprops
    Content-Length: 104
    Authorization: Basic Og==
    <?xml version="1.0" encoding="utf-8"?><D:options xmlns:D="DAV:"><D:activity-collection-set/></D:options>
    Response:
    HTTP/1.1 401 Authorization Required
    Date: Thu, 04 Feb 2010 19:19:06 GMT
    Server: Apache
    WWW-Authenticate: Basic realm="Opensource Subversion Repository"
    Content-Length: 471
    Content-Type: text/html; charset=iso-8859-1
    Cache-Control: max-age=900
    Expires: Thu, 04 Feb 2010 19:34:06 GMT
    <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
    <html><head>
    <title>401 Authorization Required</title>
    </head><body>
    <h1>Authorization Required</h1>
    <p>This server could not verify that you
    are authorized to access the document
    requested.  Either you supplied the wrong
    credentials (e.g., bad password), or your
    browser doesn't understand how to supply
    the credentials required.</p>
    <hr>
    <address>Apache Server at opensource.adobe.com Port 80</address>
    </body></html>
    Feb 4, 2010 11:50 AM   in reply to Daniil Tutubalin
    Very helpful I hope, I will pass this on the to the eng team.
    Feb 4, 2010 2:53 PM   in reply to Daniil Tutubalin
    Hey guys,
    I think I may have finally figured out what's going on.  Unfortunately, it's a huge nasty bug in Subversion.  http://subversion.tigris.org/issues/show_bug.cgi?id=3242
    Basically SVN for some reason goes up to the root to find out certain things like OPTIONS and PROPFIND and we don't allow access to the root.  Glenn asked before whether our username/passwords have root access, and I think within Adobe they do.
    SO...
    We have to figure out if it's OK to allow the client to basically see what's going on at the root and then deny access further down, or what.
    This is going to take some more time, but now we at least have a path...
    Matt
