Illustrator cs4 Eraser Question..
Feb 6, 2010 3:16 PM
Randomly while I was working, my eraser tool started to act up.  Now every time I try to use erase, the area I "erase" ends up surrounded by a thick, black outline- how can I change this or turn it off?  I was using my eraser before and it was working fine, but now it seems to be "outlining" everything I want to erase- any suggestions for a frustrated artist?
Jon
    Feb 6, 2010 3:26 PM   in reply to aboynamedjon
    I’d check my “appearance” panel. I’m guessing you’ve got a stroke of some sort going on.
    Try a new document and see if it is doing it there too.
    Feb 6, 2010 5:20 PM   in reply to aboynamedjon
    Humm. Hard to tell, can you post the offending file?
    Also, it can help to go through the layers pallet and expand things. Sometimes knowing what is there helps.
    Feb 6, 2010 5:46 PM   in reply to aboynamedjon
    Go to the Appearance Panel make sure New Art Has Basic Appearance is checked.
    Make sure your art has no stroke , if it does this is expected behavior.
    Double click the Eraser Tool in the Tool Bar and check the settings and options for the Eraser tool.
    It would be a great feature to have the ability to have strokes on any number of segment6s of an object but not all of them if theuse desired it.
    May 9, 2012 3:45 PM   in reply to Wade_Zimmerman
    I'm having this same problem with CS 5.1. I checked my appearances and my eraser settings, and neither of those did anything. This certainly is frustrating.
    May 10, 2012 1:54 PM   in reply to slong423
    Can you provide a sample .ai file?
    Seasoned with some instructions?
