Time ruler display question
Guest
Feb 15, 2010 Feb 15, 2010
How do you switch time ruler units from frames to seconds? I'm new to AE and I can't find it under preferences.
26.2K
See "Time-display units".
Change time-display units
  • To cycle through Timecode Base, Frames, and Feet + Frames, Ctrl-click (Windows) or Command-click (Mac OS) the current-time display. The current-time display is in the upper-left corner of the Timeline panel and at the bottom of the Layer, Composition, and Footage panels.
  • To change time display units, choose File > Project Settings, and choose from the options in the Display Style section.
Guest
Thanks for the reply. In the project settings I switched from auto to 30 fps and that changed the units from f to s which is what I was looking to do. I appreciate your help. Here's another silly question. I'm having trouble hearing audio files on my Mac Pro. It's probably something simple in my settings but I'm brand new to After Effects and I'm a little overwelmed by the program. Maybe I'll have a grip on it by the time I die. At the rate it's going it'll probably kill me first though. Thanks again for the help.
Feb 16, 2010 Feb 16, 2010
FAQ: How can I play or preview sound (audio)?
FAQ: Why is there no sound in my output file?
Everyone is new at some time.
I recommend starting here: "Getting started with After Effects"
Oct 16, 2017 Oct 16, 2017
it doesnt work it still appears in frames.. is there any another solution ?
Theres a time ruler bug for certain frame rates in the recent version. There are post about it in the forums. If you get strange time increments like 01:00f 01:12f 00:18f then that's the bug. Just to check, change the FR to 25, is it ok now? Then it's the bug. If that's not it, show full screenshots
Thank you so much it worked in 25 frames
*EDIT:
if you have strange time increments, check your Ae version - this bug should be fixed by now. if you are seeing 00:00, 00:15f and so on - that's o.k
it could say f but it really means s.
00:15f means 00:15s.
here's at 25fps
it all depends how stretched is your timeline.
Dec 26, 2017 Dec 26, 2017
This was my problem too. Thanks!
Laurizzle7​ please check my edited post again. it's only a bug if you have weird time increments.
