How do you switch time ruler units from frames to seconds? I'm new to AE and I can't find it under preferences.
See "Time-display units".
Thanks for the reply. In the project settings I switched from auto to 30 fps and that changed the units from f to s which is what I was looking to do. I appreciate your help. Here's another silly question. I'm having trouble hearing audio files on my Mac Pro. It's probably something simple in my settings but I'm brand new to After Effects and I'm a little overwelmed by the program. Maybe I'll have a grip on it by the time I die. At the rate it's going it'll probably kill me first though. Thanks again for the help.
FAQ: How can I play or preview sound (audio)?
FAQ: Why is there no sound in my output file?
Everyone is new at some time.
I recommend starting here: "Getting started with After Effects"
it doesnt work it still appears in frames.. is there any another solution ?
Theres a time ruler bug for certain frame rates in the recent version. There are post about it in the forums. If you get strange time increments like 01:00f 01:12f 00:18f then that's the bug. Just to check, change the FR to 25, is it ok now? Then it's the bug. If that's not it, show full screenshots
Thank you so much it worked in 25 frames
*EDIT:
if you have strange time increments, check your Ae version - this bug should be fixed by now. if you are seeing 00:00, 00:15f and so on - that's o.k
it could say f but it really means s.
00:15f means 00:15s.
here's at 25fps
it all depends how stretched is your timeline.
This was my problem too. Thanks!
Laurizzle7​ please check my edited post again. it's only a bug if you have weird time increments.
