textAlign justify and linkElement problem
Feb 17, 2010 1:47 AM
I have a paragraph with text and a link.
The link contains a span (backgroundColor = blue, fontWeight=bold) and all properties of each link format (format, linkNormalFormat, linkActiveFormat, linkHoverFormat) inherit from the paragraph format.
I added event listener on the link to manage tooltip.
It works perfectly if paragraph.textAlign = "left" or "right" as shown in attached pictures.
But if I change my code to paragrah.textAlign="justify" (without changing anything else), I obtain a bad result (as shown in attached picture) :
- the backgroundColor on the span doesn't work anymore (but the bold is still working)
- my tooltip event listener doesn't work anymore.
I don't understand why, thanks for your help !
Olivier
PS : I used the build 13875.
    Feb 17, 2010 9:19 AM   in reply to ojuin
    I can't quite duplicate the bug.  Can you send your markup or even better a small actionscript example demonstrating the problem that can be built?  Also does removing the event listener make a difference?  Finally have you tried it with the 10.1 player?
    Richard
    Feb 20, 2010 9:58 AM   in reply to ojuin
    I can duplicate the bug with the 10.0 player - it doesn't reproduce with the 10.1 player.  Looks like its one of the player bugs that was fixed in 10.1.
    You can download player 10.1 beta 2 here:
    http://labs.adobe.com/technologies/flashplayer10/
    I'm using a more recent 101 player than beta 2 so I can't guarantee the fix is in beta2.
    I don't have a 10.0 workaround.
    It seems to work in this case but why are you using UIComponent?  Why not use a Sprite and add it to the textArea's rawChildren?  Is there an advantage to UIComponent?  A sprite is fully interactive in this case.  Switching to Sprite doesn't solve the bug but I was just curious.
    Richard
    Mar 22, 2011 5:28 AM   in reply to ojuin
    It is displayed as a letter without being linked in Flex SDK development here when I meet the following conditions.
    flex_sdk_4.5.0.18623 -- It is not linked.
    flex_sdk_4.1.0.16076 -- I work definitely.
