Peter,
I have the same issue with IE8 and TCS 1.0 (ie Robohelp 7) the first time the help is called all is fine.
[Poster is referring to thread http://forums.adobe.com/thread/574820 but issue is not the same as it relates to different versions of both RH and the browser. In RH8 it was a known bug. For RH7 the cause remains to be identified.]
If you don't close the help window and call the help again I get the blank page the third time, I get an error message as described in the thread.
Any suggestions?
We tried to use the file you posted and it doesn't work.
I would appreciate any ideas.
Laura
I think you will have to point your developers to my Calling Help pages, in particular the one on Calling WebHelp Using URL's. The bug was with RH8.
Peter, I wrote about this same problem with RH7 & IE8 about two months ago. Our developers use map ids to call the help. We still have this problem. The help pages display correctly with IE 6 & IE 7 - we only have the problem with IE 8. I opened a support case online with Adobe, and I'm still trying to get an answer from them after two months. (They requested additional information yesterday, and I will send them more information.) Anyway, I'm posting again because I wanted Laura to know that she's not the only one who has encountered this problem using RH7 & IE8, and I wondered if her developers use map ids too.
Julie
I have branched this into a new thread as it is a different problem.
I don't have any suggestions as this is not something I can test. Sorry.
Hi Laura,
If you have a support contract, you can call the Adobe tech support phone number. If you do not have a support contract, you can open a case online (log into your account and look for Support Portal and submit your problem.) I would call tech support first if you are not sure about the contract. They should be able to give you more information about opening a case.
Julie
I also opened a case #0181441598. I attached a screen shot so you can see what is happening.
Laura Novich
It is an answer but I believe the problem is being investigated.
If you do decide to upgrade, check the trial version fixes your problem first, and not on your production machine.
