Locked
Type was not found or was not a compile-time constant: ImportExportConfiguration
Feb 25, 2010 Feb 25, 2010
     I am using text layout framework and getting an error type was not found or was not a compile-time constant: ImportExportConfiguration. I am using Flex Builder 3 , Flex SDK version flex_sdk_4.0.0.10485 and flash player 10.0.12 , Surprisingly this error not located in my project workspace.
In my code i uses
import flashx.textLayout.container.DisplayObjectContainerController;
Help
Gaurav kumar Pandey
Text layout framework
13.2K
Adobe Employee , Feb 25, 2010 Feb 25, 2010
You are using an older version of our code. I suggest you update to the latest code, see: http://opensource.adobe.com/wiki/display/flexsdk/Flex+SDK.
You don't need to use the Flex Framework, but it comes with the latest textLayout libraries and source code.
Hope this helps,
- robin
Adobe Employee ,
Hope this helps,
- robin
Feb 26, 2010 Feb 26, 2010
Thanks Robin,
    I have solved the problem but fall under the new problem what i did used the sdk version flex_sdk_4.0.0.6175 and it shows a new prblem Severity and Description    Path    Resource    Location    Creation Time    Id
1046: Type was not found or was not a compile-time constant: [flashx.textLayout.elements]::ITextLineCreator.
plese help me
Thanks and regards ,
Gaurav kumar pandey
Adobe Employee ,
Mar 01, 2010 Mar 01, 2010
Can you tell me what is the code you are trying to run? You have TLF, and you are trying to run it with some code. Can you tell me what that code is? Does it work with a very simple example? ITextLineCreator is an old API, that is not present in the new code. But if you are trying to run TLF with some old example code, that could explain your difficulty.
- robin
Thanks Robin fro ur help i got the error i was using the old API now i have
solved this but can there is any document that enlist the API for the new
TLF changes
Adobe Employee ,
Mar 02, 2010 Mar 02, 2010
Glad you got it working!
If you build the build.xml that comes with TLF, it will build the docs for you. You can do this using Ant. The docs for TLF are not posted online yet.
- robin
Guest
You can also get the documentation for a particular Flex SDK 4 build under the "Language Reference" links here:
http://opensource.adobe.com/wiki/display/flexsdk/Download+Flex+4
This will include the docs for the TLF build that SDK uses.
Aug 30, 2010 Aug 30, 2010
Hi Gaurav,
How were you able to solve that problem... "" 1046: Type was not found...:ImportExportConfiguration""
I want to shift my project from flex SDK 3.5 to 4.0 and m facing this error.
Were you earlier working in flex 3.5.
Help
Nitika Agarwal
Sep 01, 2010 Sep 01, 2010
Hi Nikita,
Sry for the delayed response, there is two possibility for that:
1. If you using Flex  Builder
  •   Then put your sdk uncompressed folder in your flex builder sdk/ directory path, do one thing also first remove your flex sdk 3.5 from /sdk folder of flex bulder refrenced your flex 4 sdk as a default sdk and cleane your Flex builder from run , and write following command:
      path of your flex bulder exe //pro file/adobe... put a space and write -cleane option
  • Also check your fash player it must target flash player 10.
  • go to adobe site how to extrenally point flash player 10, since there is a good tutorial there so i wont write it.
After error removed put back your removed sdk 3.5 to it's original location
2. If you using flash builder 4 then no need to do all the above exercise just change the Flex sdk version(if point flex sdk 3.5 ) to sdk 4.0.
Hope above solve your problem.
FAny further query or suggestion is most welcome
Gaurav Kumar Pandey
Jul 21, 2011 Jul 21, 2011
hi,
I got same issue but in custome componets.
like:
Type was not found or was not a compile-time constant: spinner
Type was not found or was not a compile-time constant: winprogress
Is any one know why this happen ?
dhruv
Adobe Employee ,
Aug 03, 2011 Aug 03, 2011
I don't think these are TLF errors. Can you tell me what you're trying to build?
- robin
Guest
Aug 05, 2011 Aug 05, 2011
I have same problem with can't use  TextConverter.importToFlow(...) , it show "type was not found or was not a compile-time constant: ImportExportConfiguration".My lib have a textLayout.swc component and I use it,my code as flow :
import .... ;
public class SimpleEditor extends MovieClip
  private var _textFlow:TextFlow;
  public function SimpleEditor ()
   var loader:URLLoader = new URLLoader();
   loader.load (new URLRequest("SimpleText.xml"));
   loader.addEventListener (Event.COMPLETE, loadCompleteHandler);
  private function loadCompleteHandler (e:Event):void
  _textFlow = TextConverter.importToFlow( e.target.data,TextConverter.TEXT_FIELD_HTML_FORMAT);
why ? if I delete  textLayout.swc  from my lib, it can work !
hi,
What I am guseeyou uses Flex4 sdk with your application and your lib folder contain older version of textlayout.swc. Once you removed this swc from lib folder your code will point textlayout.swc from Flex 4 sdk folder, and when you have older version of textlayout.swc in your lib folder your code will target to that swc .
Hope you get the answer .Happy programming with TextLayoutFramework.
Gaurav Pandey
Guest
Aug 08, 2011 Aug 08, 2011
It still can't work ! I use Flash CS5 and sdk is 4.0.In publish setting it have textLayout.swc and flex.swc form path of lib.When I add  TextConverter.export(..),it show Error 1046: Type was not found or was not a compile-time constant: importExportConfiguration.My code as flow :
package
import flashx.textLayout.elements.TextFlow;
import flashx.textLayout.formats.IParagraphFormat;
import flashx.textLayout.formats.ParagraphFormat;
import flashx.textLayout.formats.ICharacterFormat;
import flashx.textLayout.formats.CharacterFormat;
import flashx.textLayout.formats.IContainerFormat;
import flashx.textLayout.formats.ContainerFormat;
import flashx.textLayout.formats.TextAlign;
import flashx.textLayout.edit.EditManager;
import flashx.textLayout.edit.UndoManager;
import flashx.textLayout.edit.ElementRange;
import flashx.textLayout.edit.IEditManager;
import flashx.textLayout.events.StatusChangeEvent;
import flashx.textLayout.events.SelectionEvent;
import flash.events.Event;
import flash.events.KeyboardEvent;
import flash.events.IOErrorEvent;
import flash.net.URLLoader;
import flash.net.URLRequest;
import flash.display.MovieClip;
import flash.display.Stage;
import flash.display.StageScaleMode;
import flash.display.StageAlign;
import flash.ui.Keyboard;
import flash.text.Font;
import flash.geom.Rectangle;
import flashx.textLayout.conversion.ConversionType;
import flash.events.MouseEvent;
import flashx.textLayout.conversion.TextConverter;
import flashx.textLayout.container.ContainerController;
import fl.events.ColorPickerEvent;
import fl.motion.Color;
import flash.geom.ColorTransform;
        private var testFlow:TextFlow;
   TextFlow.defaultConfiguration.noFocusSelectionFormat = TextFlow.defaultConfiguration.focusSelectionFormat;
   //initWidgets ();
   //initStage ();
   myTextLayout.xmlText = e.target.data;
   initTextFlow ();
       private function initTextFlow ():void
   _textFlow = myTextLayout.textFlow;
            _textFlow.addEventListener (StatusChangeEvent.INLINE_GRAPHIC_STATUS_CHANGED, graphicChanged);
   _textFlow.addEventListener (SelectionEvent.SELECTION_CHANGE,selectionChangeListener,false,0,true);
   _textFlow.flowComposer.updateAllContainers ();
   _textFlow.interactionManager.setSelection (0,0);
   _textFlow.interactionManager.setFocus ();
  var xmlOut:XML = TextConverter.export(_textFlow,TextConverter.TEXT_LAYOUT_FORMAT,ConversionType.XML_TYPE) as XML;
       private function initWidgets ():void
   populateFontFamily ();
   direction.addEventListener (Event.CHANGE, changeDirection);
   blockprogression.addEventListener (Event.CHANGE, changeBlockProgression);
   verticalalign.addEventListener (Event.CHANGE, changeVerticalAlign);
   columngap.addEventListener (KeyboardEvent.KEY_UP, changeColumnGap);
   columncount.addEventListener (KeyboardEvent.KEY_UP, changeColumnCount);
   textindent.addEventListener (KeyboardEvent.KEY_UP, changeTextIndent);
   textalign.addEventListener (Event.CHANGE, changeTextAlign);
   lineheight.addEventListener (KeyboardEvent.KEY_UP, changeLineHeight);
   fontsize.addEventListener (KeyboardEvent.KEY_UP, changeFontSize);
   fontfamily.addEventListener (Event.CHANGE, changeFontFamily);
   btnItalic.addEventListener (MouseEvent.CLICK, changeFontItalic);
   btnBold.addEventListener (MouseEvent.CLICK, changeFontBold);
   fromPicker.addEventListener (ColorPickerEvent.CHANGE, changeColor);
  private function initStage ():void
   stage.scaleMode = StageScaleMode.NO_SCALE;
   stage.align = StageAlign.TOP_LEFT;
   stage.addEventListener (Event.RESIZE, resizeHandler);
      private function populateFontFamily ():void
   // try to add fonts to the drop down
   var fonts:Array = Font.enumerateFonts(true);
   fonts.sortOn ("fontName", Array.CASEINSENSITIVE);
   for (var i:int = 0; i< fonts.length; i++)
    fontfamily.dataProvider.addItem ({label: fonts.fontName, data: fonts.fontName});
    //trace( fonts.fontName);
    private function graphicChanged (sce:StatusChangeEvent):void
   _textFlow.flowComposer.updateAllContainers();
  private function selectionChangeListener (e:SelectionEvent):void
   // set display according to the values at the beginning of the selection range
   var paragraphFormat:IParagraphFormat = e.selectedElementRange.paragraphFormat;
   var characterFormat:ICharacterFormat = e.selectedElementRange.characterFormat;
   var containerFormat:IContainerFormat = e.selectedElementRange.containerFormat;
   // update the different comboboxes so their selectedItem matches the current selection
   updateComboBox (fontfamily, characterFormat.fontFamily);// font family
   updateComboBox (textalign, paragraphFormat.textAlign);// text alignment
   updateComboBox (verticalalign,containerFormat.verticalAlign);// vertical alignment
   updateComboBox (blockprogression,_textFlow.computedContainerFormat.blockProgression);// block progressions
   updateComboBox (direction,_textFlow.getComputedColumnDirection());// direction
   // update the different text input entries
   fontsize.text = characterFormat.fontSize.toString();// font size
   lineheight.text = characterFormat.lineHeight.toString();// line height
   textindent.text = paragraphFormat.textIndent.toString();// indentation
   columncount.text = containerFormat.columnCount.toString();// number of columns
   columngap.text = containerFormat.columnGap.toString();// gaps/gutter width
   //TextConverter.export(_textFlow,TextConverter.TEXT_LAYOUT_FORMAT,ConversionType.XML_TYPE);
  private function updateComboBox (box:ComboBox,val:String):void
   for (var i:int = 0; i < box.dataProvider.length; i++)
    if (box.dataProvider.getItemAt(i).data == val)
     box.selectedIndex = i;
     return;
   box.text = val;
  private function changeFontFamily (e:Event):void
   if (_textFlow && _textFlow.interactionManager is IEditManager)
    var cf:CharacterFormat = new CharacterFormat();
    cf.fontFamily = ComboBox(e.currentTarget).selectedItem.data;
    IEditManager(_textFlow.interactionManager).applyCharacterFormat (cf);
  private function changeFontSize (ke:KeyboardEvent):void
   if (_textFlow && _textFlow.interactionManager is IEditManager && ke.keyCode == Keyboard.ENTER)
    cf.fontSize = TextInput(ke.currentTarget).text;
  private function changeFontItalic (e:MouseEvent):void
    cf.fontStyle="italic";
  private function changeFontBold (e:MouseEvent):void
    cf.fontWeight="bold";
  private function changeColor (e:ColorPickerEvent):void
    var clipTransform:ColorTransform=new ColorTransform();
    clipTransform.color=fromPicker.selectedColor;
    cf.color=clipTransform.color;
  private function changeLineHeight (ke:KeyboardEvent):void
    cf.lineHeight = TextInput(ke.currentTarget).text;
  private function changeTextAlign (e:Event):void
    var pf:ParagraphFormat = new ParagraphFormat();
    pf.textAlign = ComboBox(e.currentTarget).selectedItem.data;
    IEditManager(_textFlow.interactionManager).applyParagraphFormat (pf);
  private function changeTextIndent (ke:KeyboardEvent):void
    pf.textIndent = TextInput(ke.currentTarget).text;
  private function changeColumnCount (ke:KeyboardEvent):void
    var cf:ContainerFormat = new ContainerFormat();
    cf.columnCount = TextInput(ke.currentTarget).text;
    IEditManager(_textFlow.interactionManager).applyContainerFormat (cf);
  private function changeColumnGap (ke:KeyboardEvent):void
    cf.columnGap = TextInput(ke.currentTarget).text;
  private function changeVerticalAlign (e:Event):void
    cf.verticalAlign = ComboBox(e.currentTarget).selectedItem.data;
  private function changeBlockProgression (e:Event):void
    cf.blockProgression = ComboBox(e.currentTarget).selectedItem.data;
    IEditManager(_textFlow.interactionManager).applyFormatToElement (_textFlow,null,null,cf);
  private function changeDirection (e:Event):void
    pf.direction = ComboBox(e.currentTarget).selectedItem.data;
    IEditManager(_textFlow.interactionManager).applyFormatToElement (_textFlow,null,pf,null);
  private function resizeHandler (e:Event):void
   myTextLayout.width = stage.stageWidth - myTextLayout.x;
   myTextLayout.height = stage.stageHeight - myTextLayout.y;
   _textFlow.flowComposer.getControllerAt(0).container.parent.scrollRect = new Rectangle(0,0,myTextLayout.width,myTextLayout.height);
Did the problem had old version of flex sdk or not import lib or textLayout component not suppose TextConverter.export() class ? please help me, I have source code to download test.My e-mail : hsu.shan.chuang@gmail.com ,tks !
