Type was not found or was not a compile-time constant: ImportExportConfiguration
Feb 25, 2010 2:58 AM
     I am using text layout framework and getting an error type was not found or was not a compile-time constant: ImportExportConfiguration. I am using Flex Builder 3 , Flex SDK version flex_sdk_4.0.0.10485 and flash player 10.0.12 , Surprisingly this error not located in my project workspace.
In my code i uses
import flashx.textLayout.container.DisplayObjectContainerController;
Help
Gaurav kumar Pandey
    Feb 25, 2010 10:29 AM   in reply to gauravk.pandey
    You are using an older version of our code. I suggest you update to the latest code, see: http://opensource.adobe.com/wiki/display/flexsdk/Flex+SDK.
    You don't need to use the Flex Framework, but it comes with the latest textLayout libraries and source code.
    Hope this helps,
    - robin
    Mar 1, 2010 10:02 PM   in reply to gauravk.pandey
    Can you tell me what is the code you are trying to run? You have TLF, and you are trying to run it with some code. Can you tell me what that code is? Does it work with a very simple example? ITextLineCreator is an old API, that is not present in the new code. But if you are trying to run TLF with some old example code, that could explain your difficulty.
    - robin
    Mar 2, 2010 8:50 PM   in reply to gauravk.pandey
    Glad you got it working!
    If you build the build.xml that comes with TLF, it will build the docs for you. You can do this using Ant. The docs for TLF are not posted online yet.
    - robin
    Mar 2, 2010 9:16 PM   in reply to robin.briggs
    You can also get the documentation for a particular Flex SDK 4 build under the "Language Reference" links here:
    http://opensource.adobe.com/wiki/display/flexsdk/Download+Flex+4
    This will include the docs for the TLF build that SDK uses.
    Aug 30, 2010 2:27 AM   in reply to gauravk.pandey
    Hi Gaurav,
    How were you able to solve that problem... "" 1046: Type was not found...:ImportExportConfiguration""
    I want to shift my project from flex SDK 3.5 to 4.0 and m facing this error.
    Were you earlier working in flex 3.5.
    Help
    Nitika Agarwal
    Jul 21, 2011 4:00 AM   in reply to gauravk.pandey
    hi,
    I got same issue but in custome componets.
    like:
    Type was not found or was not a compile-time constant: spinner
    Type was not found or was not a compile-time constant: winprogress
    Is any one know why this happen ?
    dhruv
    Aug 3, 2011 5:23 PM   in reply to singh.dhruv
    I don't think these are TLF errors. Can you tell me what you're trying to build?
    - robin
    Aug 5, 2011 12:49 AM   in reply to gauravk.pandey
    I have same problem with can't use  TextConverter.importToFlow(...) , it show "type was not found or was not a compile-time constant: ImportExportConfiguration".My lib have a textLayout.swc component and I use it,my code as flow :
    import .... ;
    public class SimpleEditor extends MovieClip
      private var _textFlow:TextFlow;
      public function SimpleEditor ()
       var loader:URLLoader = new URLLoader();
       loader.load (new URLRequest("SimpleText.xml"));
       loader.addEventListener (Event.COMPLETE, loadCompleteHandler);
      private function loadCompleteHandler (e:Event):void
      _textFlow = TextConverter.importToFlow( e.target.data,TextConverter.TEXT_FIELD_HTML_FORMAT);
    why ? if I delete  textLayout.swc  from my lib, it can work !
    Aug 8, 2011 1:34 AM   in reply to gauravk.pandey
    It still can't work ! I use Flash CS5 and sdk is 4.0.In publish setting it have textLayout.swc and flex.swc form path of lib.When I add  TextConverter.export(..),it show Error 1046: Type was not found or was not a compile-time constant: importExportConfiguration.My code as flow :
    package
    import flashx.textLayout.elements.TextFlow;
    import flashx.textLayout.formats.IParagraphFormat;
    import flashx.textLayout.formats.ParagraphFormat;
    import flashx.textLayout.formats.ICharacterFormat;
    import flashx.textLayout.formats.CharacterFormat;
    import flashx.textLayout.formats.IContainerFormat;
    import flashx.textLayout.formats.ContainerFormat;
    import flashx.textLayout.formats.TextAlign;
    import flashx.textLayout.edit.EditManager;
    import flashx.textLayout.edit.UndoManager;
    import flashx.textLayout.edit.ElementRange;
    import flashx.textLayout.edit.IEditManager;
    import flashx.textLayout.events.StatusChangeEvent;
    import flashx.textLayout.events.SelectionEvent;
    import flash.events.Event;
    import flash.events.KeyboardEvent;
    import flash.events.IOErrorEvent;
    import flash.net.URLLoader;
    import flash.net.URLRequest;
    import flash.display.MovieClip;
    import flash.display.Stage;
    import flash.display.StageScaleMode;
    import flash.display.StageAlign;
    import flash.ui.Keyboard;
    import flash.text.Font;
    import flash.geom.Rectangle;
    import flashx.textLayout.conversion.ConversionType;
    import flash.events.MouseEvent;
    import flashx.textLayout.conversion.TextConverter;
    import flashx.textLayout.container.ContainerController;
    import fl.events.ColorPickerEvent;
    import fl.motion.Color;
    import flash.geom.ColorTransform;
            private var testFlow:TextFlow;
       TextFlow.defaultConfiguration.noFocusSelectionFormat = TextFlow.defaultConfiguration.focusSelectionFormat;
       //initWidgets ();
       //initStage ();
       myTextLayout.xmlText = e.target.data;
       initTextFlow ();
           private function initTextFlow ():void
       _textFlow = myTextLayout.textFlow;
                _textFlow.addEventListener (StatusChangeEvent.INLINE_GRAPHIC_STATUS_CHANGED, graphicChanged);
       _textFlow.addEventListener (SelectionEvent.SELECTION_CHANGE,selectionChangeListener,false,0,true );
       _textFlow.flowComposer.updateAllContainers ();
       _textFlow.interactionManager.setSelection (0,0);
       _textFlow.interactionManager.setFocus ();
      var xmlOut:XML = TextConverter.export(_textFlow,TextConverter.TEXT_LAYOUT_FORMAT,Conve rsionType.XML_TYPE) as XML;
           private function initWidgets ():void
       populateFontFamily ();
       direction.addEventListener (Event.CHANGE, changeDirection);
       blockprogression.addEventListener (Event.CHANGE, changeBlockProgression);
       verticalalign.addEventListener (Event.CHANGE, changeVerticalAlign);
       columngap.addEventListener (KeyboardEvent.KEY_UP, changeColumnGap);
       columncount.addEventListener (KeyboardEvent.KEY_UP, changeColumnCount);
       textindent.addEventListener (KeyboardEvent.KEY_UP, changeTextIndent);
       textalign.addEventListener (Event.CHANGE, changeTextAlign);
       lineheight.addEventListener (KeyboardEvent.KEY_UP, changeLineHeight);
       fontsize.addEventListener (KeyboardEvent.KEY_UP, changeFontSize);
       fontfamily.addEventListener (Event.CHANGE, changeFontFamily);
       btnItalic.addEventListener (MouseEvent.CLICK, changeFontItalic);
       btnBold.addEventListener (MouseEvent.CLICK, changeFontBold);
       fromPicker.addEventListener (ColorPickerEvent.CHANGE, changeColor);
      private function initStage ():void
       stage.scaleMode = StageScaleMode.NO_SCALE;
       stage.align = StageAlign.TOP_LEFT;
       stage.addEventListener (Event.RESIZE, resizeHandler);
          private function populateFontFamily ():void
       // try to add fonts to the drop down
       var fonts:Array = Font.enumerateFonts(true);
       fonts.sortOn ("fontName", Array.CASEINSENSITIVE);
       for (var i:int = 0; i< fonts.length; i++)
        fontfamily.dataProvider.addItem ({label: fonts[i].fontName, data: fonts[i].fontName});
        //trace( fonts[i].fontName);
        private function graphicChanged (sce:StatusChangeEvent):void
       _textFlow.flowComposer.updateAllContainers();
      private function selectionChangeListener (e:SelectionEvent):void
       // set display according to the values at the beginning of the selection range
       var paragraphFormat:IParagraphFormat = e.selectedElementRange.paragraphFormat;
       var characterFormat:ICharacterFormat = e.selectedElementRange.characterFormat;
       var containerFormat:IContainerFormat = e.selectedElementRange.containerFormat;
       // update the different comboboxes so their selectedItem matches the current selection
       updateComboBox (fontfamily, characterFormat.fontFamily);// font family
       updateComboBox (textalign, paragraphFormat.textAlign);// text alignment
       updateComboBox (verticalalign,containerFormat.verticalAlign);// vertical alignment
       updateComboBox (blockprogression,_textFlow.computedContainerFormat.blockProgression) ;// block progressions
       updateComboBox (direction,_textFlow.getComputedColumnDirection());// direction
       // update the different text input entries
       fontsize.text = characterFormat.fontSize.toString();// font size
       lineheight.text = characterFormat.lineHeight.toString();// line height
       textindent.text = paragraphFormat.textIndent.toString();// indentation
       columncount.text = containerFormat.columnCount.toString();// number of columns
       columngap.text = containerFormat.columnGap.toString();// gaps/gutter width
       //TextConverter.export(_textFlow,TextConverter.TEXT_LAYOUT_FORMAT,Con versionType.XML_TYPE);
      private function updateComboBox (box:ComboBox,val:String):void
       for (var i:int = 0; i < box.dataProvider.length; i++)
        if (box.dataProvider.getItemAt(i).data == val)
         box.selectedIndex = i;
         return;
       box.text = val;
      private function changeFontFamily (e:Event):void
       if (_textFlow && _textFlow.interactionManager is IEditManager)
        var cf:CharacterFormat = new CharacterFormat();
        cf.fontFamily = ComboBox(e.currentTarget).selectedItem.data;
        IEditManager(_textFlow.interactionManager).applyCharacterFormat (cf);
      private function changeFontSize (ke:KeyboardEvent):void
       if (_textFlow && _textFlow.interactionManager is IEditManager && ke.keyCode == Keyboard.ENTER)
        cf.fontSize = TextInput(ke.currentTarget).text;
      private function changeFontItalic (e:MouseEvent):void
        cf.fontStyle="italic";
      private function changeFontBold (e:MouseEvent):void
        cf.fontWeight="bold";
      private function changeColor (e:ColorPickerEvent):void
        var clipTransform:ColorTransform=new ColorTransform();
        clipTransform.color=fromPicker.selectedColor;
        cf.color=clipTransform.color;
      private function changeLineHeight (ke:KeyboardEvent):void
        cf.lineHeight = TextInput(ke.currentTarget).text;
      private function changeTextAlign (e:Event):void
        var pf:ParagraphFormat = new ParagraphFormat();
        pf.textAlign = ComboBox(e.currentTarget).selectedItem.data;
        IEditManager(_textFlow.interactionManager).applyParagraphFormat (pf);
      private function changeTextIndent (ke:KeyboardEvent):void
        pf.textIndent = TextInput(ke.currentTarget).text;
      private function changeColumnCount (ke:KeyboardEvent):void
        var cf:ContainerFormat = new ContainerFormat();
        cf.columnCount = TextInput(ke.currentTarget).text;
        IEditManager(_textFlow.interactionManager).applyContainerFormat (cf);
      private function changeColumnGap (ke:KeyboardEvent):void
        cf.columnGap = TextInput(ke.currentTarget).text;
      private function changeVerticalAlign (e:Event):void
        cf.verticalAlign = ComboBox(e.currentTarget).selectedItem.data;
      private function changeBlockProgression (e:Event):void
        cf.blockProgression = ComboBox(e.currentTarget).selectedItem.data;
        IEditManager(_textFlow.interactionManager).applyFormatToElement (_textFlow,null,null,cf);
      private function changeDirection (e:Event):void
        pf.direction = ComboBox(e.currentTarget).selectedItem.data;
        IEditManager(_textFlow.interactionManager).applyFormatToElement (_textFlow,null,pf,null);
      private function resizeHandler (e:Event):void
       myTextLayout.width = stage.stageWidth - myTextLayout.x;
       myTextLayout.height = stage.stageHeight - myTextLayout.y;
       _textFlow.flowComposer.getControllerAt(0).container.parent.scrollRect = new Rectangle(0,0,myTextLayout.width,myTextLayout.height);
    Did the problem had old version of flex sdk or not import lib or textLayout component not suppose TextConverter.export() class ? please help me, I have source code to download test.My e-mail : hsu.shan.chuang@gmail.com ,tks !
