flexastic
mx:tree not getting populated.. help plz!
Mar 9, 2010 2:54 PM
I am using Flex with BlazeDS. From Java remote object, I am sending an XML and trying to populate that in mx:tree component. The tree component shows no data. Below are code snippets -
.mxml file -
<mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" xmlns:ilog="http://www.ilog.com/2007/ilog/flex" layout="absolute" autoLayout="false"
    initialize="init(); ">
    <mx:RemoteObject id="ro" destination="mgmtConsole"/>
    <mx:RemoteObject id="srv" showBusyCursor="true" result="resultHandler(event)" destination="mgmtConsole"/>
    <mx:Script>
        <![CDATA[
            import com.jpmc.ibanker.*;
            import mx.events.*;
            import mx.rpc.events.*;
            import mx.controls.Alert;
            [Bindable]
            public var myXml:XML;
            public function init():void    {
                srv.getRegionHierarchy();
            private function resultHandler(event:ResultEvent):void {
                if (event.result != null) {
                       myXml = event.result as XML;
    </mx:Script>
    <mx:Tree id="tree" dataProvider="{myXml}" labelField="@label" top="321" left="10"
         height="184" width="457" showRoot="false" verticalScrollPolicy="on"
    alternatingItemColors="[#FFFFFF,#EEEEEE]"
    showScrollTips="true" />
</mx:Application>
.java -
    public String getRegionHierarchy() {
                return "<root><node label=\"Parent 1\"><node label=\"Child 1\" /><node label=\"Child 2\"><node label=\"Grandchild 1\" /><node label=\"Grandchild 2\" /></node><node label=\"Child 3\" /><node label=\"Child 4\" /></node></root>";
Can someone please help?
    Mar 9, 2010 6:57 PM
    try setting up event handlers for the server call:
    srv.getRegionHierarchy.addEventListener(ResultEvent.RESULT, resultHandler);
    srv.getRegionHierarchy.addEventListener(FaultEvent.FAULT, faultHandler);
    private function faultHandler(event:FaultEvent):void {
         //handle fault
    Basically you must have a handler for each server function that returns some data. Hope this helps.
    -sebastian
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
