rasmikant
Switching from Flash-AS2 to Flex
Mar 11, 2010 1:05 AM
Hello !!! I am new in this flex tech
I have made a project in AS2 with Flash. and communicating with the data through XMLs
here is that link http://sanjoghelpline.in/Application_RWSS/default.asp
Now I have to play with large set of data with graphs, grids, different options etc on this maps. I think Flex will be best for it. it will directly connect to the database to fetch datas. I am planning to use webservice.
So I need your suggestion and tips for this. And what serverside language I should choose.
    Community Member
    Mar 11, 2010 3:00 AM
    Good choice. Best you can do is making a new project with Flex Builder.
    Probably you can use (parts of) your existing AS2 code (be aware of the differences with AS3).
    Is there a particular reason why you want to use webservices?
    If not, you can considering calling the data-XML's directly by HTTPService for example.
    This tool will help as well:
    http://www.adobe.com/devnet/flex/tourdeflex/web/#sampleId=0;illustInde x=0;docIndex=0
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
