john_86
HOw do i uninstall adobe reader 9
Mar 11, 2010 12:04 PM
How do I uninstall adobe reader 9 ?
    Mar 11, 2010 12:09 PM   in reply to john_86
    Don't have a clue...  I asked a question and all I get is other questions...
    This things sucks...
    Mar 12, 2010 5:47 PM   in reply to john_86
    Dear Asker,
    (Start Menu/Control Panel/Add or Remove Programs) and find Adobe Reader, Click change\remove (Assuming you are the administrator)
    Now be advised, removing Adobe reader will cause you to no longer be able to open PDF's, if this function is crucial to your home or business i would advise against its removal.
    Hope this helps
    Mar 11, 2010 1:05 PM   in reply to machattertov
    I wish you had said that earlier.
    Apr 21, 2010 2:27 PM   in reply to john_86
    I am unable to remove adobe reader 9 from the add/remove programs utility.
    I keep getting the message:
    The installation source for this product is unavailable. Verify that the source exists and that you can access it.
    I have administrator priveleges.
    I tried deleting individual Adobe folders/files from the Program files but some access is denied.
    Now I cannot install Adobe as I get the same error message.
    Please inidcate specific steps I need to do.
    Apr 26, 2010 6:16 AM   in reply to deldds2002
    Try Windows Installer Cleanup Utility to remove all traces of reader from your machine.
    Jun 17, 2010 12:39 PM   in reply to vbhv_malik
    I'm having the exact same problem but I have run the windows utility and still can neither remove nor reinstall adobe.  I was hoping to delete and start fresh with a new reinstall.  Any help?
    Jun 18, 2010 1:04 AM   in reply to john_86
    The Windows Installer Cleanup Utility is good but does not work in all circumstances. Try this: (Caution, this is not for the faint-hearted.)
    http://kb2.adobe.com/cps/400/kb400769.html
    It's the instructions for manually removing v8 but may be relevant. There are other links on this page that might also help.
    Oct 13, 2010 8:12 AM   in reply to john_86
    HOW TO UNINSTALL ADOBE READER 9 in WINDOWS 7
    Go to START>MY COMPUTER>C: DRIVE>PROGRAM FILES (X86) "IF YOU HAVE 64BIT">ADOBE> READER 9> SELECT {AERDS-42323-...} "LIKE
    THAT LOOK FOLDER" "LOL"> AND THEN CLICK ON "set up".              Your Done follow the instructions and it will uninstalled.
    WORKED FOR ME..!! =]
    Oct 13, 2010 10:29 AM   in reply to john_86
    To un install the Adobe reader 9 or evey any software from your computer, there are two ways to do.
    1. You can click on Start then Settings Then Control Panel Then Ad Remove Programs, there you will see Adobe Reader 9 simply click it and an option of remove will apear. So click it and then click uninstall. It will automatically un install adobe reader 9 from your computer. You can remove or uninstall any software safely from your computer with this method.
    2. Click on start then programs and there you will see an un install option on the specific software which you wants to un install. By the way this 2nd way maybe not used for Adobe reader, cause there is no uninstall option for this in the progrms meneu while installing. But you can uninstall it with the 1st method.
    Nov 8, 2010 4:18 PM   in reply to john_86
    I had a similar problem. Adobe reader 9 would not work and I tried without success to uninstall with the intention of reinstalling it. I tried the usual methods without success.
    I then tried to find the original installation file using the Start, Search and "File or part of a File" and entered Adobe Reader. My Os is XP Pro.
    I let the search run until it finished. It showed about 100 results, mostly small files, but included was a 42MB file named C;\System Volume\_restore........
    I dobled clicked on this file and the Adobe Installer box appeared and Reader was reinstalled successfully.It tried to stop halfway through by showing the usual message about incorrect path but I kept clicking "next".
    I am now enjoying using Adobe Reader again.
    Nov 27, 2010 9:22 AM   in reply to john_86
    Using START menu, go to CONTROL Panel, Choose, How do I Unistall,
    find Adobe reader 9 and uninstall. This should work
    Nov 27, 2010 11:10 PM   in reply to john_86
    Why do you want to uninstall it?
    Nov 29, 2010 12:47 PM   in reply to warrenwater
    I used the Start Menu:  I am Windows Vista
    Choose Start:
    Choose:  Control Panel  and Enter
    Brings up a list of items in Control Panel
    Choose: Remove Programs and Enter
    You will see an alphabetical list that comes up of all programs.
    You will choose the version of Adobe Reader you want to uninstall.
    Dec 13, 2010 3:34 PM   in reply to l006016
    I have tried the usual method through Control Panel previously but it won't uninstall Adobe Reader. An error message shows that the path is incorrect.
    There are many versions of Adobe Reader in the Adobe file in Programs. As a last resort I will manually delete all Reader version files in Programs, bur I am not sure what effect this will have on my system.
    Dec 13, 2010 6:47 PM   in reply to Surfer6
    That is not a good idea.  Better use the Windows Installer Cleanup Utility to remove the corrupted installation.  It is no longer supported by Microsoft, but you can still download it from 3rd-party sites like http://majorgeeks.com/download.php?det=4459
    Dec 14, 2010 8:55 PM   in reply to Pat Willener
    I did as you suggested and the Cleanup Utility got rid of all the trash on my PC including 5 updates of Reader..
    I was then able to install Reader X. As you mentioned I had to replace a few Microsoft programs, like Google Earth and use Microsoft Update to download a few updates that had been uninstalled. Everything now is fine.
    Many thanks for the advice.
