I'm probably wishful thinking, but I would love to see an extension that would put ALL pages updated by a template to the server with a click of one button. If you have a web site with 50 pages that are based on a template, sometimes you have to pick and choose manually which files get put to the server. I would think this should be something built-in to dreamweaver. Anybody know of anything like what I'm describing out there?
Not a one click solution, but once you've made a change, open a file from the site you're working on, then right-click on the Files panel, go to Select, Recently Modified files. Select the top option: "Files Created or Modified in the Last", and change the days to 1. I think you may even be able to use parts of a day if you use decimals, such as 0.5 for half a day, but not sure. You can then use the Put button in the Files panel to upload all of the changed files.
Here's the CS4 help page on synchronizing. one button, one menu option, then done.
http://help.adobe.com/en_US/Dreamweaver/10.0_Using/WSc78c5058ca073340d cda9110b1f693f21-7ea4a.html
In case it matters, I didn't recommend Synchronize is that it can be pretty slow as it can check every file on the remote site against the local and that cna take quite a while, especially on larger sites. The method I suggested, while not a single button click is quite fast to select the files so taht you can upload just those files.
Anyway, if Synchronize works for you, best of luck.
Wow that's amazing..... if only worked...When i try to select that option Dreamwever shows an error window with
"Javascript Errors occurred while processing onClick in SelectRecentlyModified.html: Line 370 of file ".\Configuration\Menus\MM\SelectRecentlyModified.js": DWFile.getAttributes(listItem) has no proprieties.
DOH
