Please explain with examples
regards
spvr
For example you have an XML file of name "myxml.xml" inside the same directory of your fla with the following contents:
<?xml version="1.0" encoding="UTF-8"?>
<myrootnode>
<mychildnode id="1">Something111</mychildnode>
<mychildnode id="2">Something222</mychildnode>
</myrootnode>
var cXmlLoader:URLLoader = new URLLoader();
var cUrlReq:URLRequest = new URLRequest("myxml.xml");
cXmlLoader.addEventListener(Event.COMPLETE, onXmlLoad);
cXmlLoader.load(cUr
...Copy link to clipboard
<myrootnode>
</myrootnode>
cXmlLoader.load(cUrlReq);
function onXmlLoad(oEvent:Object):void
XML.ignoreWhitespace = true;
var cXmlData:XML = new XML(oEvent.target.data);
trace(cXmlData.mychildnode[0]);
trace(cXmlData.mychildnode[1]);
If you had more child nodes under each of the child nodes then you could access them by simple dot notation using their node names.
Adobe Forum (but i think YOU) wrote:
thanks harry.
i have a another problem with xml data load if i use class.
please check following code
package {
import flash.xml.*;
import flash.net.URLLoader;
import flash.net.URLRequest;
import flash.events.Event;
import flash.errors.IOError;
import flash.events.IOErrorEvent;
import flash.display.MovieClip;
public class xmldata {
public var loader:URLLoader = new URLLoader();
public function xmldata() {
loader_fun();
private function loader_fun(){
loader.addEventListener(Event.COMPLETE, onLoadXML);
loader.load(new URLRequest("carData.xml"));
public function onLoadXML(ev:Event) {
try {
var myXML:XML = new XML(ev.target.data);
trace(myXML);
} catch (e:TypeError) {
trace("Could not parse the XML");
trace(e.message);
you can try this example.it uses URLLoader in flex to extract XML data
http://flexparsexml.blogspot.com/
