Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
SOLVED
Customize body of Submit as PDF email?
Avatar
Level 2
How do I change default text in Subject ("Form Returned") and Body ("The attached file is the filled-out form. Please open it to review the data.") of email that results from Submit as PDF to mailto:email address? Is there a .txt file somewhere that contains this information? Thanks!         ~Carol
1 Accepted Solution
Avatar
Correct answer by
Level 10
Hi Carol,
Here is a sample: https://acrobat.com/#d=awe4XZzrtamYOUcs8pKiPA
You can use a regular button instead of a Submit by Email button. Setting it up is straight forward, the following is script in the click event of the regular button.
// First give a messageBox with instructions
xfa.host.messageBox("This will open your email client and prepare an email for you. " +
     "Please make sure you send the email to complete the process." +
     "\n\nIf you experience any difficulties or if you are using a " +
     "web based email client, then please save this form and " +
     "manually email it to someone@acompany.ie\n\nThank you!", "Email Instructions", 3, 0);
xfa.host.beep("3");
// then pass instructions through to email client
var vEmail = "someone@acompany.ie";
var vSubject = "A9100 - Example of Email Button Script";
var vBody = "Hi\n\nPlease find attached the completed form in PDF format.\n\nRegards,\n\n" + nameField.rawValue + "\n" + companyField.rawValue;
event.target.submitForm({cURL:"mailto: "+ vEmail +"?subject=" + vSubject +"&body=" + vBody,cSubmitAs:"PDF",cCharset:"utf-8"});
You can hardwire the email addresses, subject line and message into the script or you can have elements of these set to the values of objects on the form.
Hope that helps,
Niall
Avatar
Correct answer by
Level 10
Hi Carol,
xfa.host.beep("3");
Hope that helps,
Niall
Avatar
Level 2
This worked great, Niall. Thanks! Is it possible to apply bold, underline, color, etc. to any text in that messageBox? If so, where do I find a list of available codes?             ~Carol
Avatar
Level 10
I am not sure - it may be possible with unicodes, but I don't have the particular codes. I tried \uF3C7 and \uF3C6 but that didn't work.
Maybe someone else will have an answer,
Niall
