bfolder22
Spark ItemRenderer and removedEffect
Mar 13, 2010 3:25 PM
I want to fade Items in/out when adding/removing from a spark list. Since there is no itemsChangeEffect on a spark list, I´m trying to assign the addedEffect/removedEffect on the ItemRenderer of the List. AddedEffect works great but when I use a remove effect, flex is throwing this error:
"Error: DataGroup manages its own display objects, and you should not call addChildAt() directly. To add, remove, or swap items, modify the dataProvider."
That pretty much sounds like I shouldn´t do it that way .
Code looks like this:
<s:List id="list">
          <s:itemRenderer>
               <fx:Component>
                    <s:ItemRenderer removedEffect="{remove}" alpha="0">
                         <fx:Declarations>
                              <s:Fade id="remove" duration="250" alphaTo="0" />
                         </fx:Declarations>
                         <s:Label text="{data}" color="red" />
                    </s:ItemRenderer>
               </fx:Component>
          </s:itemRenderer>
          <s:ArrayCollection>
               <fx:String>TestString</fx:String>
          </s:ArrayCollection>
</s:List>
Is there another way to achieve these effects?
    Mar 13, 2010 4:08 PM   in reply to bfolder22
    Have you tried placing the removedEffect on the list itself, This effect is triggered by a parent container so if it is in the item-renderer its going to cause issues(I think).
    <s:List removedEffect="{remove}">
    </s:List>
    Maybe after the weekend Chet can chime in he's the effects guru.
    David.
    Mar 13, 2010 10:12 PM   in reply to David_F57
    Does this happen when you set useVirtualLayout=false on the List?
    Mar 14, 2010 12:50 PM   in reply to bfolder22
    The current effects were not made to work with data components.  Data effects is something that we'll look at adding in the future.  I think if you need this, your best option would be subclass DataGroup and work off of that.  I haven't looked too closely, but itemAdded() and itemRemoved() might be good methods to start with.
    -Ryan
    Mar 15, 2010 5:29 AM   in reply to bfolder22
    a workaround (perhaps dirty ?) would be to play a remove effect on the list.dataGroup item and remove corresponding dataProvider item when the effect has finished.
    here is an example which works with SDK 4.0.0.13951
    <?xml version="1.0" encoding="utf-8"?>
    <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
                    xmlns:s="library://ns.adobe.com/flex/spark"
                    xmlns:mx="library://ns.adobe.com/flex/mx">
         <fx:Style>
         </fx:Style>
         <fx:Script>
             <![CDATA[
                 private var removeIndex:uint;
                 protected function addListItem():void {
                     var i:uint = Math.floor(Math.random()*list.dataProvider.length);
                     list.dataProvider.addItemAt("new Item", i);
                 protected function removeListItem():void {
                     removeIndex = Math.floor(Math.random()*list.dataProvider.length);
                     var listTarget:DisplayObject = list.dataGroup.getChildAt(removeIndex);
                     removeEffect.target = listTarget;
                     removeEffect.play();
         </fx:Script>
         <fx:Declarations>
             <s:Fade id="removeEffect" duration="1000" alphaTo="0" effectEnd="{list.dataProvider.removeItemAt(removeIndex)}"/>
         </fx:Declarations>
         <s:List id="list" useVirtualLayout="false" horizontalCenter="0" verticalCenter="0">
             <s:itemRenderer>
                 <fx:Component>
                     <s:ItemRenderer addedEffect="{addEffect}" alpha="0">
                         <fx:Declarations>
                             <s:Fade id="addEffect" duration="1000" alphaFrom="0" alphaTo="1" />
                         </fx:Declarations>
                         <s:Label fontSize="15" text="{data}" color="red" />
                     </s:ItemRenderer>
                 </fx:Component>
             </s:itemRenderer>
             <s:ArrayCollection>
         </s:List>
        <s:HGroup id="container" horizontalCenter="0" bottom="25" gap="25">
             <s:Button id="removeBtn" label="removeListItem" click="{removeListItem()}"/>
             <s:Button id="addBtn" label="addListItem" click="{addListItem()}"/>
         </s:HGroup>
    </s:Application>
