Hello,
I have a public PDF with no Copying Restrictions. When I try to copy text from the PDF highlighted text to WORD I only get unreadable garbage.
I can select the desired text and copy it into word but when I paste the text it is pasted like symbols and lines.
I tried Special Paste and does not works. It says the font is a Gill Sans something (with numbers and so on), no really a font it seems but when i change it to Arial i still get symbols.
Any help or ideas,
Cheers,
Sebastian
Thanks for the idea Bill, but it does not work. Even if i change the font in Word it will be still strange symbols. By the way if i save the PDF as a Word file I just get a lot of pages full of symbols, as you can see in the attach.
Is there any way to replace the fonts of the original PDF by changing it by a different one?
Cheers,
S
If the fonts don't have unicode tables and they do not use a standard encoding for mapping the glyph indices to characters then you get garbage characters during copy/paste. You can try using the PDF Fixup Profile "Embed Fonts" in the Preflight tool to embed the font (if you are unable to reauthor the document). However, the font does need to be installed on your system and license to allow embedding in order to do this.
Hi Lori, thanks for the good info! I open the Preflight windows, but there is no "Embed Fonts" in the Fixed up. I guess i do not have that font or the PDF enconding is just bizarre. The font is Gill Sans and Futura, which i have installed both in my system but maybe is a weird version of the font.
It is very frustrating to see how somebody at the Ministry of Health could be so dumb to upload a public PDF in Internet which is supposed to be copy/pasted by researchers all over without knowing this very basic stuff.
By the way, i supposed that i cannot try anything else? I thought i could somehow "force" the actual font by highlighting text and putting Arial, for example, like if it was a Word Document.
Cheers,
Sebastian
Hi Songpark, Thanks for your help! i just attached a short version of this PDF in this reply.
Cheers,
After looking inside the PDF it turns out that no usable encoding information is present (neither in the PDF nor in the embedded font data) to derive the meaning of the characters/glyphs that are displayed on the pages in the document.
The fonts actualy are all embedded, but in a way that all encoding information has been removed. This is a typical example of a PDF that is syntactically fully compliant with the PDF spec but where important information about the meaning of the text in it has been thrown away during the process of making the PDF. As far as I can tell it would be very difficult to recover the encoding info. Strange as it may sound the best option may be to convert the pages to oixel and then run OCR on them....
According to the document info PageMaker 7 and Distiller 5 have been used - not sure whether that combination wasn't quite up to the task but I am on Acrobat 9 now and haven't seen Pagemaker for years...
HTH.
Olaf Drümmer
callas software
One approach is a bit of work, but might meet your need. I saved the file to TIFF (600dpi). I then went through each TIFF to converted it to B&W. I think copied the text to WORD. The result was not perfect, but it was in English and could be clipped. The resolution and the B&W were important to the project completion.
Thanks Olafdruemer and Bill for a very complete answer and good help in this matter. I will try the option on going on to TIFF mode and i might also call this Ministry (i do not hold much hope) to see if the can change a series of PDF made in the same way. It is interesting that you mention Pagemaker which is a Dinosaur in editorial design, almost nobody use it anymore.
NOTE: On another subject, this is my firs tread in this "new" Adobe Forum. I just realized the "Correct" and the "Helpful" answer which has also brings a point system. I have to say i find it quite unfair compared to the older Adobe forum when people just collaborate with info for the shake of helping. As an example most of the replies i got to my specific question in this tread were substantially helpful to me and i find it limitating or unfair to one have ONE chance to give a helpful answer to a particular member.
Cheers,
Sebastian
I have this exact same problem. It is very frustrating. How is it not possible to "grab" onto the text in the pdf ??!!
SO WHY CAN'T I COPY THE TEXT! AAARGH!
No, the file is not protected.
Yes, I have tried saving as different formats. (The "save as tiff file workaround" idea is very time consuming and greatly degrades the quallity.)
The font is shown as being: "Arial083.313"
Something in the pdf program is recognizing the text, translating the 1's and 0's (that make up all computer files) into the letters that display on the screen that I can read and select with the mouse. So why can't that same "something" allow me to copy it? So frustrating.
Somebody please help. If you can solve this problem you are awesome.
I grab text every once in a while and it typically works fine. For me to be able to view the proper font on my system, I have to have that font available. The Arial you listed is not a typical system font and is probably why you are having problems. When you copy, what font name is shown in WORD or other word processor. Your problem is likely the fonts. Acrobat will display that font if has been embedded in the file. However, Acrobat will not copy a font to your machine, only the character information.
Thanks for the reply Bill. The font name shown in WORD or other word processor is the same--Arial083.313.
Example: The text I copy in the pdf reads: "Check heating circuit sensors / heating system"
When I paste in word processor I get this: "3_ __&_ _____&_______&_ ____&4&_"
or this: & &
Can I post my problematic file in this forum?
As PDF Reader is just designed for viewing PDF, you can read, highlight it easily but cannot always copy text from PDF to Word. It is normal.
If you want to copy text from PDF to Word and want to perserve the layouts and hyperlinks, evern graphics, you could use PDF to Word Converter, by which, you can preserve the original contents from PDF to Word. This PDF to Word Converter is a free desktop program providing batch partial and encrypted PDF conversion, which is better than free online software. Just go to try it and hope it helps.
Good idea. Here is a link to the file on Google docs.
There should be a download link in the upper left corner.
Yes, I know some of the text is in German, but I should still be able to copy and paste the text as it is regardless. But honestly, my main objective is to be able to search for text within the document. If there is an error message saying "G2 Fault" I want to be able to search and find all references to this in the manual.
Here's the solution. When you open the PDF document in "Preview", do not do any "saves" on it before you have copied the data you want to paste into Word. Before you do anything, Do a "save as" on the document and keep one fresh copy just in case you forget and do a save on it. Once you do a "save" on a PDF document, it will convert the text to garbage when pasted into Word. It works.
A PDF file does not store enough information to enable you to re-create it as a Word document (that's why it was invented, to prevent people copying files).
I agree with your opinion, PDF is end or export file and in order to preserve layout and any other content, it is existed independent from OS and applications. It displays like a photocopy of original file and the codes of it is totally different from Word, so there are many uncompatible issues out there.
Basically, a well-tagged PDF file can be copied successfully but the failing instances varies by multiple reasons.
The CutePDF fix looks like it completely works for me!!!
Printed document through CutePDF, selecting settings that minimized optimization and requested native True Type fonts (sorry didn't document exactly.....didn't think it would work right away!) .
Then did Acrobat OCR, and now I can copy and paste from Acrobat to other programs without garbage here and there.
