A question often asked is what system to build for NLE.
Basically you can think along three roads, a budget PC, an economical PC and the warrior PC. Notice that MAC is not mentioned here. There are three reasons for that, one is I'm not qualified to really advise on MAC's, two is that they are way overpriced and three they are severely limited in component choices. So this is all about PC.
Whether you want to have a budget, economical or warrior PC, there are a number of common components that you will always need, a case, a PSU, CPU cooler, monitor, keyboard, mouse, DVD/BR burner and stuff like that so I'm not going into those components.
So what is this all about?
1. CPU
2. Motherboard
3. Memory
4. Disk setup
5. Video card
This is certainly not intended to be a full description of what to buy, but only to point you in a direction that will make it easier to make your own list of components required.
CPU
Budget: i7-860, Economical: i7-930, Warrior: Dual X5680
Motherboard
Budget: ASUS P7P55D, Economical: ASUS P6T WS Pro, Warrior: SuperMicro X8DAH+
Memory
Budget: 8 GB, Economical: 12 GB, Warrior: 24+ GB
Disk setup
Budget: 3-4 SATA disks, Economical: 5-8 SATA disks (plus raid controller), Warrior: 12+ disks and Areca ARC 1880iX-16/24 controller
Video card
Budget: ATI HD 5670, Economical: nVidia GTX-285, Warrior: nVidia Quadro FX 3800+
Effectively at this moment (March 2010) that means in approximate costs for the 5 components and not counting everything else you may need,
| Type PC | Approximate budget |
| Budget | $ 1,200 |
| Economical | $ 2,100 (excluding RAID controller) |
| Warrior | $ 8,500 (including Areca RAID controller) |
These figures are around minimum to budget for. I hope this gives you something to ponder about.
Very nice little guide!
the only thing i would make comment on.
the 860 and 920/930 are the same price.
the boards for each are only $30 apart. (p55 being slightly less)
so the cost of a P55 vs X58 are not that big a jump.
4 vs 6 gig or 8 vs 12gig not a big stretch..
however for many the 860 is more than they need. (DV, HDV)
FYI the 860 overclocks very nicely to 3.6GHz without voltage increases.
As to the Apple my biggest reason for not recommending them to clients right now is not about cost or choices.
its all about OSX inability to properly mutli-thread.
at least Adobe is much better on an Apple right now that Final Cut! FC is rather embarressing.
Scott
ADK
I was on the verge of pulling the trigger on this deal :
http://www2.dell.com/ca/en/home/desktops/desktop-studio-xps-9000/pd.as px?refid=desktop-studio-xps-9000&s=dhs&cs=cadhs1&~oid=ca~en~70702~stud io-xps-9000-en-feat_3~~
From $1,938
You Save $440
Now $1,498 (before taxes)
Then a friend looked around for me and assembled this hypothetical build :
Microsoft Windows 7 Professional Edition 64BIT Dvd OEM
•Limit 5 per customer.
•Usually Ships in 1 to 2 Business days.
Yes $145.87 $145.87
Western Digital WD1001FALS Caviar Black 1TB SATA2 7200RPM 4.2MS 32MB 3.5IN Dual Proc Hard Drive OEM
Yes $98.88 $98.88
XFX Radeon HD 5850 XXX Edition 755MHZ 1GB GDDR5 4.5GHZ 2XDVI HDMI Display Port PCI-E Video Card
Yes $334.80 $334.80
LG BH10LS30 Bluray Writer 10X BD-R 16X DVD-RW Lightscribe SATA Retail Box
•Limit 2 per customer.
Yes $169.88 $169.88
Asus P6T X58 ATX LGA1366 DDR3 3PCI-E16 PCI-E1 2PCI CrossFire SLI SATA2 GBLAN Motherboard
Yes $253.80 $253.80
Antec Truepower New 750W Modular Power Supply ATX Active PFC 80 Plus SLI Ready Blue 120MM PWM Fan
Yes $125.01 $125.01
Antec P183 ATX Tower Case Black 11 Drive Bay 4X5.25 1X3.5 6X3.5INT No PS Front USB & Sound
Yes $146.65 $146.65
2 X OCZ XTC Platinum OCZ3P1333LV6GK DDR3-1333 6GB 3X2GB CL7-7-7-20 Triple Channel Memory Kit
•$20.00 CAD Mail in Rebate for this item - click here
Yes $168.71 $337.42
Intel Core i7 920 D0 Stepping Quad Core Processor LGA1366 2.66GHZ Bloomfield 8MB LGA1366 -SLBEJ-
Yes $324.32 $324.32
Payment Detail
Shipping & handling $0.00
Insurance $29.05
Sub Total $1,936.63
GST(5%) $98.28
No PST - Outside BC residents $0.00
Total $2,063.96
In both cases, I was going to add at least 1TB as a 2nd HD.
Rig will be for Photoshop, Sonar audio editing, and full screen HD video playback (not editing). No gaming. No overclocking.
Dell's video card is a 5770. The custom build is a 5850. Both may be overkill. Dell's PSU is 475W. The custom build's is 750W. Dell's OS is Win7 Home, the custom build's is Win7 Pro. Dell's blu-ray only writes CD/DVD. The custom build writes BD/CD/DVD.
Is either one of these a no-brainer? Any red flags? Please note that price *is* an issue right now, as I'm being hit with all kinds of emergencies simultaneously... but my current rig (7 years old, upgraded to an Opteron 180 somewhere along the way) is falling apart on me. After a false-alarm HD failure scare this past weekend, I don't want to keep pushing my luck.
PS: I'm in Canada, these are all in CND prices.
Dell XPS is brain damaged from the start: The BIOS is crippled, not allowing any overclocking.
In your custom system, I would definitely add a smallish 150+ GB disk for OS & programs, not waste a 1 TB dirve. The 5850 may be a bit pricey in comparison to the 5670 and not deliver any measurable benefits. For MPE you may consider the approved cards, although they do come with an additional price tag. And we are not even sure when MPE will come.
Did you miss the part where I went out of my way to mention that I wouldn't be overlocking? ![]()
The part about not wasting a 1TB drive as the OS drive makes a lot of sense, though. Thanks.
as mentioned the Dell is silly the power supply is barely enough to boot the default config.
add harddrives and a serious video card forget it....
IMHO a 700W is minimum and a qualoty one at that not some off brand.
the only good for video dells are in the workstation area and then they are way more than a custom builder.
Scott
ADK
I plan to build a 64bit computer later this year, after CS5 is out, with my CURRENT plan being...
Intel i7 CPU + ASUS P6 motherboard + Win7 Pro 64bit (have that from site license @work) and 12Gig Ram
320Gig boot drive and 320Gig scratch drive and 1T data drive (SD video only, to make home movie DVDs)
Since I'm not sure the CUDA/MPE engine will do anything for me with SD video, I am still deciding between nVidia GTX 285 and an ATI with 1Gig of display ram (will also use Photoshop)
I also do NOT overclock
If you insist on a notebook, this may be worth looking at:
http://eurocom.com/products/showroom/specselectnew.cfm?model_id=207
but prices may be a multitude of desktop systems. I can get it for around € 8,000
Sorry Harm, that wasn't intended to come across as snarkily as it did.
I'm slowly walking away from the Dell set-up, mostly because of the inadequate PSU.
My main question now is... if my sole points of interest are :
1) Photoshop (ridiculously high resolutions, ie 4GB+ psd files)
2) HD video playback (full screen - currently 1920x1200 but could potentially go even higher)
3) Very intensive multi-layer / live FX / 24b wav music editing
No gaming, no overclocking, and very little video editing (I'm leaving that door open, but I've no immediate plans to).
In this scenario, would an ATI 5850 or even a 5770 be a waste of money that could be put into more or better ram?
In your custom setup, you already have 12 GB of memory (with nice timings BTW) so I don't see any benefit of adding more memory at this time.
With CS4 the video card is often overrated, but does not bring you any measurable benefit. A $ 30 card will do nearly as good as a $ 2K card.
Dorris Day once sung: "Que sera,sera. Whatever will be, will be, The future is not ours to see..."
and that still applies. We just don't know when MPE will come out, what it will bring, what it may mean in video cards, ...
but based on what we currently know and have, any $ 30 card will suffice.
You mentioned "nice timings". As someone who knows very little about ram, I'm not sure what that means, but thought I'd ask you what you thought of another opinion I got in another forum telling me to ditch the 1333 and go with 1600.
Keeping in mind I'd be on an i7 920, I'm budget-conscious, what the difference would cost and what I'd get in return, how wise is that advice at this point in time?
OCZ Platinum is my brand. That means I have it myself, so I may be biased. I know others here have had troubles with Platinum/mobo combo's, but it appears to me those were mobo problems, not memory problems (correct me please if I am wrong, BG).
The nice thing about your memory is the 7-7-7 timings and the 1333 speed is more than enough to support overclocking to around 3.6 GHz. If you want to go further, let's say to 4.0 GHz, then 1600 memory would definitely be advisable, but keep the CAS at 7.
You can find some background info here: How to get the best from a PC? Some guides...
I WILL NOT BE OVERCLOCKING!!! ;-)
If the real benefit of going 1600 is overclocking, then all the more reason to stick with 1333. Right?
Scott,
I agree with you, but there is one handicap, who do you trust to set those settings in BIOS? Not the average editor. I don't mind to help, but if people want to change their BIOS settings to get the most out of their systems, they better know what they are doing, and unless you are willing to give all the support needed, they are on their own. I will not help on BIOS settings, if people screwed up, but if you volunteer...
shoot no! i am not helping either. we have thought about looking our clients out of the bios
but then i couldn't rag on Dell for it ![]()
it also depends on what board you use and ram you use.
XMP profiled (correctly profiled) Ram.
if you choose use XMP profile in the bios
"Should" auto profile.
past that i dont give out bios setting.
i dont have the patience (thank God my support guys do...)
Peace!
Scott
ADK
Of course I would not operate in a normal video editing mode at that speed. The motherboard is my ASUS P6T7 WS Supercomputer. While it may be an ideal CUDA platform, it is a lousy disk performer. I have a faster (R)AID array than Harm (because a risky eight disk RAID 0), but cannot even come close to his disk intensive AVI encoding score of 1.4 seconds, the best I have seen is about 3.9 seconds. Also if you scan the Results page you will see it is not my setup, all AVI results for this MB are lousy. I cannot verify this but I suspect that the two nVidia N200's that are on this board may be the cause.
Thank you very much for your extensive efforts to educate...your advice is succinct and pertinant, the fruit of many years experience, I'm sure. Thanks for sharing with us. I've read the links you sent & printed them to use while I compare options.
If I had more time, I'd build one...best way to learn! Thanks again.
Greetings, I've read this thread with eager (but, admittedly ignorant) interest.
I'm creating patient-education programs with audio/video/graphics/animation etc... and need to keep my focus on the content vs. the technology.
Are there any technically sound, pre-configured and optimized for "Adobe CS5" available for those of us who don't know enough about hardware to build a sytem ourselves?
Sara
There are many configurations posted here in different price brackets. Depending on your budget, I would take the list of components that were used in good and stable performing systems that fit your budget and ask a system builder in your area for his comments or suggestions and ask him to make you an offer you can't refuse. You will then also have the support close by.
Hi Harm Millaard,
First of all I would like to thank you for the great posts I've seen here, about hardware in general, and the rich information you have been providing for long. Then, as I need to assemble a NLE PC capable of dealing with 2 or 3 simultaneous layers of AVCHD and TOD video files with average 35GB size, with a 2.500,00 € [$ 3.000,00] budjet, after reading most of your articles I've managed to come with the following configuration:
CASE:
- 1x CoolerMaster RC-690 II Advanced (89,90 €)
- 1x Fan 80mm NoiseBlocker Silent X1 Black/ Blue (4,40 €)
- 2x Fan 120mm NoiseBlocker Silent XL2 Black/ Blue (6,00 €) (12,00 €)
PSU:
- 1x Corsair HX-850W (165,00 €)
MOTHERBOARD:
- 1x Asus P6X58D-E Skt1366 iX58 (224,00 €)
PROCESSOR:
- 1x Intel Core Quad i7 930 2.8Ghz Skt1366 8Mb (277,00 €)
COOLER:
- Noctua NH-D14 Fan 140mm (69.90 €)
GRAPHICS:
- Asus GeForce PCI-E GTX470 1280Mb GDDR5 (359,90 €)
RAM:
- 2x Pack 3x 2048Mb DDR3 GSkill PC3-16000 (2000) CL9 RipJaws Tri-Channel (194,90 €) (389,80 €)
HDD-SYSTEM:
- SSD Intel 2,5" SATA-2 80Gb X25-M (225,00 €)
HDD-PRODUCTION [RAID0]:
- 4x Western Digital SATA-2 1TB 7200rpm 32Mb Black (85,90) € (343.60 €)
HDD-STORAGE:
- N/A [available USB 2.0 2TB device]
BR-RW:
- 1x DVDRW Blu-Ray LG BH10LS30 8x SATA LightScribe bulk (189,00 €)
DVD-RW:
- 2x DVDRW SATA Asus 24B1LT 24x LightScribe Black bulk (26,00 €) (52,00 €)
OTHERS:
- PCI OEM w/ 2 Firewire + 1 Mini-Firewire (9,90 €)
- Sharkoon Media III Card-Reader (5.25/3.5/USB) (10,90)
OS:
- 1x Microsoft Windows 7 Home Premium 64Bit PT OEM (112,90 €)
TOTAL: approximately 2.500,00 €
Well, what can you say about this assembled machine? What modifications would you do? Any recomendations?
Regards.
Two questions and one remark.
Question 1: Doesn't the motherboard have two on board firewire connectors? If so, you don't need the PCI card.
Question 2: Do you need two DVD burners PLUS a BR burner? The BR can also burn DVD's.
Remark: I know SSD is a hype nowadays, but is boot time that important? For editing it makes no difference and you can save a bit by choosing a Velociraptor for boot and another WD disk for expanding a raid.
Thank you for your fast reply!
Notes: The "2x" DVD is a typo!
It was from another custom machine! And extra Firewire is needed for several peripherals [client arguing]. And I guess you may be right with the SSD HDD..
Now, imagine you can spend more 500,00 € [maybe $ 750,00], what would you do to increase performance and reliability? And for Win7 what are the main settings that I should do?
Software to use: Adobe Premiere, Sony Vegas, Corel Video Studio Pro, Pinnacle Studio HD Ultimate Collection.
PS: I had some problems in the past with some PC configurations that used to stuck / crash during HD editing [not rendering], that's why I chose that particular graphic card.
Regards.
Harm:
I'm a video editor using a Sony ZI and editing in HDV burning in SD. Hope to up grade to NX5. Need a new computer to use Cineform Neo 4k and CS5 Production Studio.
The following suggestion has been made:
Gigabye GA-P55M motherboard with Gigabit Ethernet, Firewire and eSATA ports,
8 GB 1333 MHz DDR3 RAM (4x2 GB)
Intel Core i5 750 quad core processor (2.66 GHz)
2x1 TB 7200 rpm WD "Black Series" HDs-32 MB cache
nVIDIA GTX 285 video card - dual monitir support
2x LG DVD Rewritable drives with Nero software
Mini tower case with room for 3 Hard Drives
Win 7 Pro 64 bit
Rosewill 650 watt 80 plus Certified power supply- energy efficent and quiet
3 yr warranty
$1700 approx
What do you think of such a set-up? How can it be improved and hopefully lower cost or at least not increase it too too much?
Dave514
Scottsdale AZ
Dave,
A couple of remarks:
1. Only two disks. That is cutting it thin, unless you did not mention a separate OS/program disk.
2. Mid tower. I would always opt for a big tower because of the better cooling and expansion room.
3. A P55 board limits you effectively/economically to 8 GB memory. A X58 board allows for 12 GB.
4. 650W PSU with a GTX-285 may be on the low side.
Hi Harm Millaard
I seriously need help choosing the components for my next pc!
I’ve been trying to come up with a decent configuration over the last few weeks but each time I star to choose components I seem to blow my budget. I live in New Zealand where PC components tend to be more expensive than what they are in the US/ Europe.
I am currently a media assistant at a marketing firm and find that I often need to take my work home to work to tight deadlines. I plan on using on my future PC CS5 (for work) and Avid Media Composer (for my own personal projects). Potentially I would like to play around with Maya as well at some point.
I’ve never built my own PC before but I’ve decided that I would like to give it a try. That said while I can use a computer (fairly well) I still have allot to learn in terms of putting one together.
My budget is $4000.00 (New Zealand dollars)
I have come up with the following list of components so far:
CPU: Intel® Core™ i7-960 3.2GHz Quad-core with Hyperthreading
MB: Asus® P6X58D Premium Supporting SLI/CrossFire, USB 3.0, SATA 6Gb/s
MEMORY: 12GB Kingston HyperX Triple-Channel DDR3-1600MHz Low Latency
GRAPHICS CARD: NVIDIA® Quadro™ FX580 512MB GDDR3
DVD-RW: LG Electronics GH22NS50 DVD Writer, DVD 16R/22W/8RW, CD 48R/48W/32RW, Internal, SATA, Black, OEM
SOUND CARD: Creative Sound Blaster 5.1 VX Sound card, 5.1, PCI
WIRELESS ADAPTER: D-Link DWA-520 Xtreme-G, Wireless Adapter, 108Mbps, 802.11b/g, PCI
HARD DRIVES:
(RAID 0) 2x VelociRaptor WD1500HLFS, 150GB, 10000rpm, 16MB Cache, SATA-2
Caviar Black WD1002FAEX, 1000GB, 7200rpm, 64MB Cache, SATA-3
As you can see so far I’m missing cooling, a case and a power supply, potentially a RAID Controller card, usb ports (i would also like to add a HDMI output port) etc
Could you please give me a hand and modify what I have above in any way that you see fit and help me by completing the list of all the other components that i will need?
I would really appreciate your help!!!!
Well, you asked for it.
Lose the i7-960 and get an i7-930 instead and overclock it a bit. Half the price and the same performance when OC' ing.
Lose the FX580, get the GTX-480, much much faster and has the HDMI port.
Lose the sound card, use on board sound instead. Saves $$$, compatibility issues and bloated software.
What is the use of the wireless adapter? Lose it or if you really need one, get a 802.11 b/g/n version.
Do not raid your boot disk. One Velociraptor is sufficient.
Get at least 2 or better yet 3 Caviar Black's.
Cooler: Noctua NH-14D
Case: many to choose from, as long as it is a big tower. For instance CM HAF932, Lian Li PC-A77B
PSU: CoolerMaster is very good. Look here for requirements: eXtreme Power Supply Calculator Pro v2.5
The mobo has a number of USB ports on board.
Consider a LG GGW-H20L BR/DVD burner.
How does this fit into the budget?
I second all of Harm's comments, but when you get through a very important step is to make sure you tune your OS (hopefully Win 7 64) to get rid of the garbage that Microsoft has to include to cover every possible use but features that are not necessary for an editing machine. As an example one function that you will not need is Tablet PC components, there are about two dozen or more of these that I turn off.
