Error while parsing the Tag Library Descriptor
Avatar
Level 1
We are installing LC ES2 on Suse64 / weblogic platform. When the adobe-conmtentservices application is starting, we see a lot od error like this:
<Mar 24, 2010 10:56:53 AM CET> <Warning> <HTTP> <BEA-101196> <[/contentspace]: Error while parsing the Tag Library Descriptor at "/opt/oracle/product/WLS1031/user_projects/domains/LC9/servers/LC9_MS/tmp/_WL_user/adobe-contentservices/4xxkue/war/WEB-INF/contentservices.tld".
com.ctc.wstx.exc.WstxIOException: Tried all: '1' addresses, but could not connect over HTTP to server: 'java.sun.com', port: '80'
        at com.ctc.wstx.sr.StreamScanner.throwFromIOE(StreamScanner.java:683)
        at com.ctc.wstx.sr.BasicStreamReader.next(BasicStreamReader.java:1086)
        at weblogic.servlet.internal.TldCacheHelper$TldIOHelper.parseXML(TldCacheHelper.java:134)
        at weblogic.descriptor.DescriptorCache.parseXML(DescriptorCache.java:380)
        at weblogic.servlet.internal.TldCacheHelper.parseTagLibraries(TldCacheHelper.java:65)
        Truncated. see log file for complete stacktrace
java.net.ConnectException: Tried all: '1' addresses, but could not connect over HTTP to server: 'java.sun.com', port: '80'
        at weblogic.net.http.HttpClient.openServer(HttpClient.java:314)
        at weblogic.net.http.HttpClient.openServer(HttpClient.java:404)
        at weblogic.net.http.HttpClient.New(HttpClient.java:240)
        at weblogic.net.http.HttpURLConnection.connect(HttpURLConnection.java:172)
        at weblogic.net.http.HttpURLConnection.getInputStream(HttpURLConnection.java:356)
The application tries to download something from java.sun.com site but the server can not access internet. The process is repeated for each TLD file !
After a very time (more than 45 minutes!), the server finally starts and all adobe application are active
So, how to correct this behaviror ? is there a patch?
cb.
1 Reply
Avatar
Former Community Member
Did you get solution for this because I am also facing same issue. Please do reply ASAP... it is very uegent.
Srujan
