Hi
I receive the error in the title bar as a result of the following code but I can't see what I'm doing wrong:
<cfcomponent hint="sets background colour to help users see where they are during booking">
<cffunction name="cellcolour" returntype="struct">
<cfargument name="progressstage" type="string" required="true">
<cfset var stagecol="StructNew()">
<cfset oncolour="red">
<cfset offcolour="white">
<cfswitch expression="#progressstage#">
<cfcase value="progressstage1">
<cfset stagecol.colour1="#oncolour#">
<cfset stagecol.colour2="#offcolour#">
<cfset stagecol.colour3="#offcolour#">
<cfset stagecol.colour4="#offcolour#">
<cfset stagecol.colour5="#offcolour#">
</cfcase>
........... etc
Thew line where the error occurs is <cfset stagecol.colour1="#oncolour#">.
Thanks in advance for any advice
Dave
1. Are you using cftry/catch in our component? In some CF verison (at least), var scoped variables couldn't be referenced in cfcatch block.
2. What is your function returning? Is it a structure? Try removing the returntype attribute of the function.
3. Double check for overlapping variable names - try to change your variable names in the function and check if that helps.
And P.S. <cfset stagecol.colour1="#oncolour#"> is better and clearer written as <cfset stagecol.colour1 = oncolour>
Never use pound signs until you're outputting something, or dynamically evaluating a variable name.
-Fernis
Look more closely at that line of code.
What's wrong with it?
Adam
Those cannot be seen by the human eye!
...Which is exactly why the habit of using extra "#quotes#" is shooting oneself in the leg.
-Fernis
Thank you both so much for your help and "I promise I'll never do that again"........
Best wishes
Dave
No worries mate. We've all done it.
Adam
