You have attempted to dereference a scalar variable of type class java.lang.String as a structure wi
Mar 25, 2010 2:59 PM
You  have  attempted to dereference a scalar variable of type class  java.lang.String as a  structure with members
Hi
I receive the error in the title bar as a result of the following code but I can't see what I'm doing wrong:
<cfcomponent hint="sets background colour to help users see where they are during booking">
<cffunction name="cellcolour" returntype="struct">
<cfargument name="progressstage" type="string" required="true">
<cfset var stagecol="StructNew()">
<cfset oncolour="red">
<cfset offcolour="white">
<cfswitch expression="#progressstage#">
<cfcase value="progressstage1">
<cfset stagecol.colour1="#oncolour#">
<cfset stagecol.colour2="#offcolour#">
<cfset stagecol.colour3="#offcolour#">
<cfset stagecol.colour4="#offcolour#">
<cfset stagecol.colour5="#offcolour#">
</cfcase>
........... etc
Thew line where the error occurs is <cfset stagecol.colour1="#oncolour#">.
Thanks in advance for any advice
Dave
    Mar 25, 2010 3:25 PM   in reply to daveioi
    1. Are you using cftry/catch in our component? In some CF verison (at least), var scoped variables couldn't be referenced in cfcatch block.
    2. What is your function returning? Is it a structure? Try removing the returntype attribute of the function.
    3. Double check for overlapping variable names - try to change your variable names in the function and check if that helps.
    And P.S. <cfset stagecol.colour1="#oncolour#"> is better and clearer written as <cfset stagecol.colour1 = oncolour>
    Never use pound signs until you're outputting something, or dynamically evaluating a variable name.
    -Fernis
    Mar 25, 2010 3:55 PM   in reply to daveioi
    Look more closely at that line of code.
    What's wrong with it?
    Adam
    Mar 25, 2010 10:40 PM   in reply to Adam Cameron.
    Those cannot be seen by the human eye!
    ...Which is exactly why the habit of using extra "#quotes#" is shooting oneself in the leg.
    -Fernis
    Mar 26, 2010 10:34 AM   in reply to daveioi
    No worries mate.  We've all done it.
    Adam
