Let's start off by stating that I'm not a WAS expert.
I'm currently busy installing ES2 on a WAS / Windows 2003 machine which connects to an Oracle 10g DB. I've following the installation instructions quite carefully, but I ran into a brick wall that I can't seem to move myself. Hopefully someone over here can help me out.
Over many attempts I've had various different issues while running the configuration manager. Most of these issues pop up after the ear files are configured and are ready to be deployed. Reviewing the log files I noticed that the I get a java.lang.OutOfMemoryError at the times when the issues pop up. The server itself doesn't have a shortage of RAM (16GB) and I did increase the deployer heap size as described in the manual.
Eventually I've now given up searching and decided to throw myself at the mercy of the forums for some help
. Since I don't really even know where to begin investigating the issue (besides confirming that I followed the steps in the manual), I'd be appreciative of almost any suggestions.
Greg
Greg:
The OutOfMemoryExceptions are probably related to this:
http://blogs.adobe.com/livecycle/2010/01/outofmemoryerror_on_deploying .html
You seem to be beyond those now.
The one recommendation I have for you is to deploy the LiveCycle EAR files to WebSphere manually, instead of letting LCM do it. This is especially true if you're deploying to a distributed WebSphere cluster.
Thanks for the quick response Jayan.
As you've guessed I've already read most of what is available regarding the out of memory error and also followed most of the advice provided. Here's a summary of what I've done already:
I've tried to deploy the configured ears manually, but there's a catch there as well - The ears are already deployed from a previous (uncompleted) run of the configuration manager. Until now all attempts to undeploy and redeploy with the updated ears have been unsuccessful (non-responsive or OutOfMemoryError as well)
The server involved is also running EMC Documentum (in a seperate Tomcat container) and I'm concerned that the issue lies wuth the configuration of the %JAVA_HOME% environment variable which now has two values (one for tomcat and one for WAS). Could this be a potential source of problems?
Manual deploy has not been 100% successful either, but I'm slowly progressing. I was able to undeploy the old apps with some effort. Bounced the box and then resolved the issue with the multiple JAVA_HOME environment variables. Then came the deployment of the LC ears...
On this machine I'm trying to deploy 2 ears
The ...native... ear deploys without issues. However, when I try deploy the bigger ear I get the OutOfMemoryError.
Since attchments are current unavailable, here is an extract from my errorLog (if it helps):
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R AppDeploymentException: [Unexpected exception processing archive file.]
java.lang.OutOfMemoryError: ZIP002:OutOfMemoryError, MEM_ERROR in deflate_init2
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R java.lang.OutOfMemoryError: ZIP002:OutOfMemoryError, MEM_ERROR in deflate_init2
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at java.util.zip.Deflater.init(Native Method)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at java.util.zip.Deflater.<init>(Deflater.java:148)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at java.util.zip.ZipOutputStream.<init>(ZipOutputStream.java:86)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at org.eclipse.jst.j2ee.commonarchivecore.internal.strategy.ZipStreamSav eStrategyImpl.<init>(ZipStreamSaveStrategyImpl.java:59)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at org.eclipse.jst.j2ee.commonarchivecore.internal.strategy.ZipStreamSav eStrategyImpl.createNestedSaveStrategy(ZipStreamSaveStrategyImpl.java: 89)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at org.eclipse.jst.j2ee.commonarchivecore.internal.strategy.SaveStrategy Impl.save(SaveStrategyImpl.java:130)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at org.eclipse.jst.j2ee.commonarchivecore.internal.strategy.ZipStreamSav eStrategyImpl.save(ZipStreamSaveStrategyImpl.java:215)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at org.eclipse.jst.j2ee.commonarchivecore.internal.strategy.SaveStrategy Impl.save(SaveStrategyImpl.java:143)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at org.eclipse.jst.j2ee.commonarchivecore.internal.strategy.SaveStrategy Impl.saveFiles(SaveStrategyImpl.java:165)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at org.eclipse.jst.j2ee.commonarchivecore.internal.strategy.SaveStrategy Impl.save(SaveStrategyImpl.java:107)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at org.eclipse.jst.j2ee.commonarchivecore.internal.impl.ArchiveImpl.save (ArchiveImpl.java:1498)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at org.eclipse.jst.j2ee.commonarchivecore.internal.impl.ModuleFileImpl.s ave(ModuleFileImpl.java:173)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at org.eclipse.jst.j2ee.commonarchivecore.internal.impl.ArchiveImpl.save AsNoReopen(ArchiveImpl.java:1630)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at org.eclipse.jst.j2ee.commonarchivecore.internal.impl.ArchiveImpl.save As(ArchiveImpl.java:1527)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at org.eclipse.jst.j2ee.commonarchivecore.internal.impl.ArchiveImpl.save (ArchiveImpl.java:1477)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at com.ibm.websphere.management.application.client.ArchiveDeploymentInfo .close(ArchiveDeploymentInfo.java:398)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at com.ibm.websphere.management.application.client.AppDeploymentControll er.close(AppDeploymentController.java:706)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at com.ibm.websphere.management.application.client.AppDeploymentControll er.saveAndClose(AppDeploymentController.java:718)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at com.ibm.ws.console.appmanagement.action.AppInstallSummaryAction.execu te(AppInstallSummaryAction.java:124)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at org.apache.struts.action.RequestProcessor.processActionPerform(Unknow n Source)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at org.apache.struts.action.RequestProcessor.process(Unknown Source)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at org.apache.struts.action.ActionServlet.process(Unknown Source)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at org.apache.struts.action.ActionServlet.doPost(Unknown Source)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at javax.servlet.http.HttpServlet.service(HttpServlet.java:763)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at javax.servlet.http.HttpServlet.service(HttpServlet.java:856)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(ServletWrapper .java:1146)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(ServletWrapper .java:1087)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilte rChain.java:145)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at com.ibm.ws.console.core.servlet.WSCUrlFilter.setUpCommandAssistence(W SCUrlFilter.java:792)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at com.ibm.ws.console.core.servlet.WSCUrlFilter.continueStoringTaskState (WSCUrlFilter.java:363)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at com.ibm.ws.console.core.servlet.WSCUrlFilter.doFilter(WSCUrlFilter.ja va:229)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at com.ibm.ws.webcontainer.filter.FilterInstanceWrapper.doFilter(FilterI nstanceWrapper.java:190)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilte rChain.java:130)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at com.ibm.ws.webcontainer.filter.WebAppFilterChain._doFilter(WebAppFilt erChain.java:87)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at com.ibm.ws.webcontainer.filter.WebAppFilterManager.doFilter(WebAppFil terManager.java:837)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at com.ibm.ws.webcontainer.filter.WebAppFilterManager.doFilter(WebAppFil terManager.java:680)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletW rapper.java:588)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at com.ibm.ws.wswebcontainer.servlet.ServletWrapper.handleRequest(Servle tWrapper.java:525)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at com.ibm.ws.webcontainer.webapp.WebApp.handleRequest(WebApp.java:3548)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at com.ibm.ws.webcontainer.webapp.WebGroup.handleRequest(WebGroup.java:2 69)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at com.ibm.ws.webcontainer.WebContainer.handleRequest(WebContainer.java: 818)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at com.ibm.ws.wswebcontainer.WebContainer.handleRequest(WebContainer.jav a:1478)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at com.ibm.ws.webcontainer.channel.WCChannelLink.ready(WCChannelLink.jav a:126)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleDiscrimina tion(HttpInboundLink.java:458)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleNewInforma tion(HttpInboundLink.java:387)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at com.ibm.ws.http.channel.inbound.impl.HttpICLReadCallback.complete(Htt pICLReadCallback.java:102)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at com.ibm.ws.ssl.channel.impl.SSLReadServiceContext$SSLReadCompletedCal lback.complete(SSLReadServiceContext.java:1818)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at com.ibm.ws.tcp.channel.impl.AioReadCompletionListener.futureCompleted (AioReadCompletionListener.java:165)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at com.ibm.io.async.AbstractAsyncFuture.invokeCallback(AbstractAsyncFutu re.java:217)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at com.ibm.io.async.AsyncChannelFuture.fireCompletionActions(AsyncChanne lFuture.java:161)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at com.ibm.io.async.AsyncFuture.completed(AsyncFuture.java:136)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at com.ibm.io.async.ResultHandler.complete(ResultHandler.java:196)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at com.ibm.io.async.ResultHandler.runEventProcessingLoop(ResultHandler.j ava:751)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at com.ibm.io.async.ResultHandler$2.run(ResultHandler.java:881)
[3/31/10 7:30:17:087 CAT] 00000020 SystemErr R at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1497)
Hi Jayan
Just a quick update on my results. After getting a WAS expert to have a look at my server he eventually proposed a reinstall of WAS. The version I was working on was ND 6.1.0.29 and it seemed to introduce unexpected issues.
After replacing with a stand-alone WAS all was fine with no problems, well almost no problems, but nothing that belongs on this forum.
Thanks for the help
