Dec 27, 2009 11:16 AM
Jerky Playback Premiere CS4 and Win 7?
Like (0)
Hey
I tried scanning through a bunch of posts to see if anyone else was getting a similiar issue, but couldn't find an answer.
I recently just upgraded my system :
Windows 7 64bit
Adobe CS4 suite
i7 920 processor
Asus P6T SE mobo
6gigs of RAM
ATI Radeon 4800hd graphics card
250gig 7200rpm OS and Prog Drive
640gig video Drive
300gig Scratch Drive
Fresh Install, not an upgrade.
Did all the win 7 and premiere updates and the ATI updates.
My problem is I have loaded up a project that I originally edited in CS3 premiere, loaded it into CS4, let everything load and index.
My playback is pretty jerky. My new system is way faster then my last setup and yet it is running very very poor.
The footage in question is DV footage. shot on DVX100b (24pa) I made sure and checked that CS4 imported it into a proper sequence and everything seems to be lined up properlly.
Am I doing something wrong?
I checked some HDV footage that wasnt playing on my previous set up, which now playsback in a premiere timeline on current setup.
Are there any codecs that I should download? I dont want to rape the system with random codecs and crap.
any info would be greatly appreciated.
Abes
Abes,
With this footage on the Timeline, is there a red, a green or a yellow line above the Timeline? How is playback when you hit Enter, to Render it? Yellow will indicate that you have a mis-match between your footage and your Project/Sequence Preset.
Also, check your Hardware Acceleration settings. If min, try max. If max, try min. If you get an improvement, test by incrementing up, or down, until you get problems and then go back one increment.
Check your OpenGL settings, and test.
You've got the very latest ATI driver, right?
God luck,
Hunt
I forgot to mention that.
Footage doesnt need to be rendered, no green, yellow, red lines, this is strictly on footage that should be played back realtime.
I checked, and double checked ati settings, played around, tried, nothing. I even played around with project settings, sequence, playback in premiere as well. Nothing.
I tried running, automatic quality, draft and high quality and they are all the same. Even still, my old set up cruised at High quality so I wouldnt accept anything but.. I hate being that guy who complains, I am not trying to complain, love adobe would not switch, but I have to be that guy at the moment. haha.
What else, I made sure that all the graphic card drivers were for win 7 as well.
I just dont know.
It shouldnt be a codec thing though either right? I havent downloaded any, like k-lite or such. Just what came with win7, and cs4. Which shouldnt need a additional codecs for cutting DV footage that premiere CS3 captured.
I did however download quicktime.. Not pro, just the basic version. But I cant see that causing conflict.
Thanks so far Hunt.
Any more suggestions?!?!
A.bes
Well, at this point, I am out of ideas. You should NOT need any additional CODEC's with that footage. I am also a big fan of not installing any CODEC's (especially any "packs") that are not needed. Then, I will install just the one(s) that I need and try to go to the source for those, even if they cost $, and similar are free. I agree with what you have done so far.
Now, for playback of non-AVCHD footage, the I/O sub-system is highly important, but IIRC your I/O on this machine (3x HDD's allocated well), that should not be an issue.
Maybe others will spot something important that I am missing. Here's hoping.
Good luck,
Hunt
Try running my Premiere Pro CS4 hardware benchmark (PPBM4) and lets see how well your system is set up and tuned. Email me the results and I will try to comment to you on how it looks in comparison to the others shown on the results page.
The benchmark is totally Adobe DV format, see how it works!
Did the Benchmark
hopefully I did it right. (the test and the comp set up)
I emailed them to your benchmark email address that was included in the files.
1 last thing I forgot to mention, that I just realized now. And have yet to tested.
I have my old Hard Drive from previous comp plugged in (has the old version of win xp) on that disk. I didnt boot from that disk, I was just using it to transfer files that I needed from that particular hard drive.
It does however have all my old install files. Not sure if that would cause a conflict, as everything else seems to be running fine. CS4 progs, load quick and work nice, its just this jerky playback on DV footage that I am seeing. I havent tested HDV footage fully yet as I have a couple of projects I needed to finish that were done in DV and from CS3.
Driving me crazy.
thanks for the help so far gents.
A.Bes
Update:
I ran through the windows 7 optimization instructions from the Black Viper site. I got my processes down to about 28. And Cleaned up my services. Disabled antivirus software and ceased connection to the internet. Same thing.
I am running dual monitors. So I tried a single one, and same thing. Its extremely jerky when I enlarge the soure mointor screen to playback the timeline.
I unplugged that other hard drive that had my old files on it.
Defragged my project drive.
Same thing.
I tried HDV footage. Exact same thing as the DV footage. Jerky playback. Laggy playback, whatever you want to call it.
I havent tried re-installing CS3 yet. To see if the issue persists. Does CS3 even work on win7 pro 64bit?
The footage was perfectly fine one my previous set up, I had no issue with playback or anything. So I know its not the footage. And I tried multiple footage as well.
Again, everything loads and renders and works perfectly fine in CS4 and super quick too. Just on playback it seems to be having issues. Im thinking it has to be something with the graphics card then?!?!
Maybe I am just thinking aloud.
ill keep troubleshooting.
A.bes
A.Bes,
Try these two things:
If that fails, you might try exporting an EDL from your CS3 project (via CS4), do a new project import the EDL and relink the media. This is a shot in the dark, but it's worth a shot.
Dennis
Dradeke,
Prefrences have been cleaered, and new projects have been created from scratch, imported , you name it.
It actually only seems to get jerky, when I enlarge the source window, or if I output to second monitor for viewing, Even disabled second monitor used a single monitor set up, enlarged the video for playback, and its jerky. Small seems to be fine, which makes me think graphics card or something. But like I previously stated, Graphics card worked on cs4 and cs3 perfectly fine on my old set up. Just upgarding processor, mobo and OS to Win 7 i have been experienceing this issue. And before I had CS3 installed.
Thanks for the suggestion though.
A.Bes
Ok... card worked on "old setup" but not on Win7
My GUESS is that the vendor needs to update their device driver
Note that this happens every time Windoze (or Apple Mac!) comes out with a new OS... it takes the hardware and software vendors "some" amount of time to issue updates... and some never do for old products, they just develop new products
John,
Your assumption is probably right.
I just went out and grabbed a new graphics card. Went from ATI Radeon HD4800 to a BFG GeForce GTX260 oc.
Upgraged to a 700watt powersupply as well. Took off the Ati, through on the GTX260 and problem isnt there. Single Monitor enlarged source window, works fine, if I spand the work area over two displays, still fine. If I adjust the playback to have the timeline playback on second monitor, works pretty good, every now and then there might be a slight stutter. BUT nothing like it was doing..
I guess I could have been patient and hoped ATI would throw another update that may or maynot fix the issue, but this seems to work, didnt cost me all that much, i was able to get it on staff price for a decent price.
Anyone have any comments on the card?!?! any settings that make it perform the best?
Thanks for all the help gents.
A.Bes
Hi
Saw your thread post on the Adobe Premiere Forum - whilst searching for inspiration on almost exact same scenario I have.
I have upgraded to CS4 and Win 7 64 bit / i7 processor - new AVCHD camera.
On Win 7 64 bit and ATI Radeon 5750 card - performance is horrible
Same as you - if I enlarge program window playback - it looks like 5 frames per second
Has your setup totally stablised OK now with your new Graphics card?
Maybe I will have to return the ATI card ?? - I'm more or less convinced it is my Radeon 5750 causing the problem.
I found that CS4 can run AVCHD on my Win XP computer (Intel Dual Core) without these issues (Radeon 1950 graphics).
render to Blu ray takes a long time though - hence reason to go Win 7 / i7 CPU Quad core.....
Seems quite a few people have same issues.........
Regards
Nigel
Nigel,
Before you chuck the card, do you have the very latest driver for it?
Good luck,
Hunt
Thx Hunt
No chance of chucking the card (not at £150) - I want to get to the bottom of this with Adobe Support.
Have tried nearly everything suggested on the Forums now.
I'm convinced this is a SW issue and not a configuration issue.
If anyone has the Radeon 5750 card working 100% with Win 7 64 Bit on Premiere CS4 please tell me the magic formula
Thx
Nigel
Im really struggling here and with a s
erious deadline looming. Made the stupid mistake of thinking downloading and installing the CS4 version of
Premiere Pro would solve some of my issues I had with Premiere pro 1.5 W
RONG yes I can export to useable media much more easily but, my imported tiff rendered sequences are
impossible to edit properly because of the extreme jerkyness of the playback monitor box. same thing when I view the section in the preview monitor.
Simple dissolves are missed completely in the monitor just jump on by . Even worse, installing cs4 has stopped my PP1.5 from functioning has a bunch of catastrophic errors
Anyone got a toupe I could use ??
or an answer of some kind the the impossible Jerkies ?
regards Paul Buckland
I'm convinced of the contrary. I have to trouble with 4 tracks of AVCHD 29.97i, XDCAM-EX 25i and HVD 25i intermixed on the same time line, with multiple effects like 3-way CC, Gaussian blur, tint, motion/scale/position and opacity effects and some others, plus a number of transitions in one time line to play back smoothly without rendering. Even when these effects are keyframed with bezier curves. Fast scrolling is no problem either. All with previews set to high quality. And my video card is only a HD4870.
Paul,
Please tell us about your TIFF sequences, especially their pixel x pixel dimensions.
Then, tell us about both your Sequence Preset and full details of your other Assets in that Timeline.
Do you have red lines about any of these Assets in the Timeline? Does playback improve if you Render?
Last, please give us complete details of your system, paying special attention to the I/O sub-system, i.e. full details of your HDD's, and also your video card and driver version.
Good luck,
Hunt
The Tiffs are 1280x720 24 bit with alpha along with it. I however have told PP to ignore the alpha channel. Yes I have red lines and yellow ones and I have made aboslutely certain that the project is configured precisely to my HD format. My system is a BOXX Dual Core Dula processor ADM 1.8ghz with 8 gig of RAM and a raided drive of half a terrabyte. in other words two 500gig drives (WDC WD2500) seen as one 500gig drive within windows XP pro x64. Nvidia Quadro FX 1500 card. It has the latest driver dated 1/26/2010 and is 6.14.11.9187 Presets 1280x720 Progressive scan, Video preview as default Microsoft AVI Codec: DV 24p advanced
is that it ?
hope so and thanks for responding
Thx Harm
But your 4870 is not the 5750 Radeon card ....so when I said SW issue I did not mean CS4 - my suspicions are with the card / SW driver combination and CS4...Win 7 64 bit.
I'm still trying to find out if anyone has successfully deployed this ATI Radeon 5750 card (relatively new) with CS4 and Win 7 64 Bit...
If yes - please let me know - then I need the magic formula to configure Win 7....Step by Step
This should be repeatable if this has been done before
Do Adobe certify any graphic card combinations in their valildation labs?...is 5750 in the list?.
Btw - I have spent all day on the links you sent - CC cleaner is a neat tool - thx...that cleared an previous fragment of a non valid ATI SW install
Also tried some stuff on servces.msc Win 7 tuning from blackviper site - but all made no difference I'm afraid
Br
Nigel
Of course, when I typed:
I have to trouble
I meant NO trouble. Sorry. Probably fatigue, a lousy keyboard that I need to exchange, and the stupid thing that often my thoughts are faster than my typing, so I have a tendency to skip typing words that were in my mind, but not in the post.
Nigel, you may have seen it before, but this third guide here also applies to Win7, at least for the majority.
Thank you for the details. All looks good there.
How about the HDD's? What speed (7200 RPM min.), and free space?
How do the TIFF's play, when you Render them by hitting Enter - red line will turn green?
Good luck,
Hunt
JonesVid,
I can't speak for anyone else. I was unbelievably frustrated with the how it was playing back when i was rocking my ATI 4800, Harm and Bill and the rest were fantastic at giving me ideas on how to remedy the situation.. But nothing man. I ripped, re-installed everything, windows was a fresh install, no unwanted codecs were installed.. I searched everything..
I tried a million different configurations and could not get anything to playback well. So I grabbed a new card as a next trouble shooting step, and figured that if it didnt work I would just return it and scream loudly..
It worked..I dont know what else to say.
I wish I would have bookmarked a post that someone made on a different thread, how he explained it made me think it was my graphics card.. Which still doesnt make sense cause Harm rocks a 4870 and mine was a 4800..so.. I dont know..
If you have the option to swap the cards to just see if its the card or not.. try it out. you can always go back to the ATI card..
I didnt change anything except card. It started to work so I didnt mess around with it anymore..
A.Bes
I have an "experimental system that I push for benchmarking. Originally when I set this system up I grabbed a Quadro FX1700 and went with Windows 7 default drivers. I was not reaching the profrmance I expected from an ASUS x58 based board. I replaced the Quadro card with a GeForce 6200 256 MB PCIe (about $50) card and my benchmarks went up to my expectations! So I guess that there may be some cards and some drivers that can cause problems
Thanks everyone for pitching in. I didnt reply sooner because my deadline was
pressing hard. Finally managed to create output with CS4
. Also found that the reason my old PP1.5 was crashing was because I was trying to load a project that had already been saved out by me in CS4 What an idiot LOL I put it down to pressure.
But, on to the meat of the issue. First, in answer to an earlier question, yes once i have rendered a preview my monitor scrubs and plays properly however, Its totaly counter intuative to the way one edits a movie. the whole pre-rendering twaddle interferes with the creative process in my opinion. In PP1.5 even if sometimes a little scratchy a simple cross or additive dissolve would preview perfectly fine. This meant that the software didnt encroach upon what should be a transparent to the editor process. I come from 16 and 35mm film and video as a background and of course this stuff has come a long way since then, Im talking 1969 by the way.
But surely in so many ways PP CS4 is almost a monster step backwards.
If basic footage needs pre-rendering to work well in the time line, why isnt that an option at import time ? Then at least dissolves and the like would be the only thing the processors need to worry about if the basic image blitting to screen has been taken care of by what I imagine is some kind of proxy.
OK thats my 4 penneth as they say in my mother blighty.
regards Paul C Buckland
Harm
I thought I should come back to draw a line under the thread I started about bad playback in preview window with Radeon 5750 graphics card and CS4 under Win 7 64 bit.
Well I tried every driver going with ATI Radeon 5750 without success.
I cut my losses and purchased an NVidia GTS250 card with 1G DDR3 memory.
Loaded the NVidia CD based Win 7 64 bit driver
Hey presto - problem solved
Conclusion - there is a definite incmpatibility with this ATI Radeon 5750 card/Driver with Win 7/64 bit and CS4.
Unfortunately purchasing the ATI card was an expensive mistake.
I tried to ask Adobe support about this - but I will give them 1 out of 10 score because I received no valuable input.
I am totally un-impressed by quality of Adobe tech Support.
It would be a positive conclusion to this if Adobe Tech Support could actually validate this ATI 5750 Graphics card under Win 7 64 Bit using Catalyst 10_3 drivers/suite and see what results they get too....or is that asking too much?
This is so weird. Of course I have the previous generation ATI HD4870, but use the same 10.3 driver and have never experienced your problem. Now, there were problems with the 5xxx and the 10.2 driver, which was corrected with a hot patch.
Can you run Process Explorer with the 5750 card installed, set it to allways on top and then try to play back your time line and identify all the processes that use the CPU during playback. Also, turn on the View system information and tell your CPU utilization during playback. If you post a screenshot from this info during playback, maybe we can see what is hampering a fluid playback.
I would definitely file a Bug Report on this, with full details.
When PrElements 8 was released, there were immediately some issues with nVidia and ATI/AMD drivers. Adobe did assign (or he did it on his own time) an employee to investigate this in the forum. He gathered as much data, as he could, and soon PrE 8.0.1 was released and it seems that most video driver issues were handled - at least until the next generation of drivers.
In that case, things were done.
Good luck,
Hunt
Thanks Hunt
I have filed a bug report on this, as you suggest.
By the way - I tried using the Grass Valley Neo 2 booster edit SW that came with the Panasonic camera - before I took out the ATI Radeon card.
This worked perfectly editing AVCHD material with the Radeon card - so definitely some combination of CS4 and this ATI Graphics driver under Win 7 64 bit.
Regards
Nigel
Nigel,
Interesting about the GV Neo. Not sure if that is the product that many others use, but they seem to have good fortune with Neo.
Thanks for reporting and good luck,
Hunt
Just want to throw in my experience. I had:
Win 7 64bit OS
Nvidia 6800 GT video card
4 gigs RAM,
Dual Core E 6750 CPU
Premeire Pro CS4
Everything worked fine until I upgraded to an ATI 5770 card last week. Playback is completely unuseable. I have upgraded to current drivers, no improvement. This is the identical problem others are describing. Sounds like I need to go back to NVIDIA! Loading projects that ran fine before produces extreme jerkiness. Perhaps one frame every 5 to 10 seconds! YEOW!
Another user solved this by rolling his ATI drivers back to version 9.8.
-Jeff
Yes - confirms my concern about the ATI 57XX series Win 7 64 bit and Premiere CS4 combination
Waiting for Adobe Tech support to respond to my request in bug report which I filed, me but heard nothing.
Update on ATI 5770 problems!
Thanks Jeff;
I just removed my Catalyst 10.3 driver and installed 9.8 as you suggested. Video playback is now normal. Jerkiness is gone! I wonder what ATI changed in the newer driver that makes the 5XXX series cards unuseable for Premeire Pro?
Cannot address the ATI Catalyst, but not that long ago, a series of nVidia drivers had two gamer-only modules, that installed by default and turned ON - PhysX and 3D Stereovision. The trick with those was to just disable those two modules. It appears that later nVidia drivers have either fixed the interaction between those two modules and Adobe programs, or now they default to OFF. Probably something similar, but I have no clue what it might be.
Good luck,
Hunt
You're welcome.
According to that same user, you can safely update to 9.11 without compromising your video playback.
-Jeff
I'm having a similiar problem as well. I have a brand new i7 960 3.2ghz computer 6gb ram, 1.5tb 7200rpm HD, ati hd5600gpu. I have premiere installed and what ever video I import it'll play perfectly smooth, even unrendered except every few seconds it'll jerk. This also happens even after a preview renders Almost like it's reapeating 3 frames over every 5 to 10 seconds. It's ever so slight, but i cant seem to get rid of it. It'll scrub fine but no matter where i play the clip, timeline, monotior 1 or 2 it'll behave the same. Play perfectly smooth but every 5 to 10 seconds have a micro stutter However this doesn't affect the final export, only during the editing session. I've tried different drivers and settings but nothing seems to help. Anyone ever have this problem? Thanks.
I think this is linked to the similar issue I was having with ATI Catalyst drivers...I'm still waiting for Adobe Technical Support to get back to me on this. The NVidia GTS 250 card + Win 7 64 bit Drivers have solved the issue
Regards.
1.5tb 7200rpm HD
Is that all? Minimum requirements state a DEDICATED 7200 RPM disk and that is absolutely minimum. For normal editing at least 3 SATA disks are required.
JonesVid,
Yeah that's what I was thinking. I might just live with it for now instead of shelling out for a new card, since it's very slight and doesn't affect the final output. Let me know if you ever hear form Adobe Tech support. Thanks.
Harm Millaard wrote:
1.5tb 7200rpm HD
Harm, I also have another 2tb 7200 rpm and a 500gb 7200 drive but I don't use it with Premiere. I was not aware 3 drives were minium for Premiere. I'm not a professional or editing a feature length film and Premier ran fine on my 4 year old core 2 laptop with a single 500gb drive. Rendering times were a pain in the butt, but it worked. Crashed sometimes but never had any playback problems. Regardless I'm pretty sure it's a software issue. I could be worng though. Thanks.
With those three disks, I would set it up as:
C: (500 G) OS & programs
D: (1.5 TB) pagefile, scratch, media cache, previews
E: (2 TB) media
That is assuming all disks are (e)SATA.
3 drives are not required by Premiere Pro, but Harm's suggested mix is good to have. At a minimum you want to have two drives (one for OS and Apps and one for media).
hope this helps,
Dennis
Harm,
Yeah they are all SATA drives. I appreciate the advice, but I've spent so many hours on this issue that I should count in days. I've lost the spirit to spend anymore time. For now I think I'll just deal with it, since it's not affecting final output. If I get the energy I'll try what you said. Thanks again.
I do hope that your two larger drives are not "Green" drives.
I'm pretty sure neither of them are, I'll check again just to be sure. If they were would that cause my issue? Thanks.
Hmmm the last post in this thread is from April! I bumped into it by accident searching to play back my cs4 pp time line on the tv as well as on the program monitor. In Cs 2 I could see how to direct the output set up (I think in Preference)
But this thread is depicting my problem as well! My display card is a Raedon X300/X550/x1050 (at least this is what I see under Display info (all this is a little much for me!). Perhaps by now all concerned would know if I need to change my card and for which one. I also just checked my older pc for which I had to buy a new card as I used its for the new MB upgrade on my newer pc - unfortunately it's exactly the same!
I was under the impression just for video editing I did not need one of those super card designed for games. Thank you for any advices.![]()
Michelmnr
Have you first tried updating your Display drivers for your current graphics card?. Might solve the issue......
With the Radeon ATI 5750 card I had - various suggestions were to try the very latest drivers - or fall back to an old version
there were certainly issues with drivers and Adobe Premiere CS4.
The latest Catalyst drivers might solve the problem now but I have not opportunity to try them
I had to solve this issue of bad Video quality (jerky) playback on PC quickly - so I ended up installing an Nvidia GTS250 card in the system
This immediately solved the issue and video playback is now smooth.
I can redirect video timeline playback on both the monitor window and external HDMI monitor in parallel in High quality without any problems
You re-direct to external device by right clicking on the top right icon within the right hand monitor window and clicking on Playback settings.
I think this can be accessed via the Preferences menu too
br
Thank you for this
I'll have to try one of this two options then and of course the update first
Hi again. I did a little more reading and also tried my neighbour's Gygabyte ati Radeon 4350, (I think), that was supposed to be one recommended above others for video editing. It did not show much improvement in my case. The drivers were up to date which ruled out a fault in this area. My neighbour also belongs to a Photography Club and at the last meeting he attended, the guess speaker and actually the president of one or our clubs said he heard that CS3 and CS5 have little problem with display but CS4 does. I wonder if anyone could substantiate this too in this forum?
I ended buying a NVDIA gygabyte GT220, I don't know if it's wishful thinking but I think my display has improved.
Hello
There is a bug in the ATI Catalyst drivers. This bug somehow makes the preview video window in PREMIERE CS4 play very laggy. This problem started to appear after the Catalyst 9.11 driver versions. Please note that the 9.12 driver was released in december last year. So yes, this bug has been present for 9 months with many users complaining about it. Unfortunately ATI so far has been reluctant to fix this.
I guess the only way to have this fixed is to keep sending reports to ATI / AMD and keep posting on their forums:
http://www.amdsurveys.com/se.ashx?s=5A1E27D27E29B0E3
http://forums.amd.com/game/categories.cfm?catid=279
And of course my personal lesson is to avoid ATI cards in the future.
Copyright © 2011 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
