Home/Support/
Forums
824 Views 11 Replies Latest reply: Apr 5, 2010 3:18 PM by 370H55V RSS
jevchance Calculating status... 8 posts since
May 4, 2009
Oct 23, 2009 2:00 PM
Dreamweaver CS4 Crashes Regularly
Hi all,
Dreamweaver is causing me a lot of headaches. Hopefully someone can shed some light on this for me.
It seems to crash often, several times a day and its extremely aggravating. I'll provide as much information about the issue as I can.
24" iMac
Intel 2.66 Ghz Core 2 Duo
4GB RAM
620GB HDD (332GB Free)
OS X 10.5.8 with all the latest updates
CS4 Web Premium
Behavior: It seems DW crashes when I:
  • try to paste something (but not always)
  • right-click to access a contextual menu, either inside a document, or in the Files window (but not always)
  • try to access the menus at the top of the screen, particularly 'Edit' and 'Modify' (but not always)
I have attached the crash log.
It may be related that I'm also having an issue with Photoshop. I frequently receive the error "Could not import the clipboard because an unexpected end-of-file was encountered". This happens frequently when switching between programs, regardless of what I have recently copied to the clipboard. It will also sometimes happen when I open a Photoshop file from the Finder, in which case the open action will likely fail.
Additionally, these lines from the crash log seem related, and applicable:
Exception Type:  EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
Crashed Thread:  0
Thread 0 Crashed:
0   Fireworks                     0x04cde9b1 FWImaging::SetSourceImageFromClipboard(unsigned short**, unsigned long&) + 735 (FWImaging.cpp:1016)
Is it possible that there is an issue with my clipboard that is causing these crashes? If so, is there a way to recreate the clipboard to avoid corruption?
  • EvelynMangiru Calculating status... 4 posts since
    Nov 9, 2009
    1. Nov 9, 2009 1:29 PM (in response to jevchance)
    Re: Dreamweaver CS4 Crashes Regularly
    I have the same problem. I use to work with both Dreamweaver and Fireworks opened in the same time, but lately every time I start working in Fireworks, Dreamweaver crashes. I receive the same error like you.
    It would be great if someone would suggest a solution for this problem as I use CS4 every day.
  • Chris-Designart Calculating status... 9 posts since
    Nov 9, 2009
    3. Nov 9, 2009 2:38 PM (in response to jevchance)
    FWIW, I was having similar sounding problems with DW CS4 causing a fair bit of hair loss (as I am having with the whole CS4 suite!) There was a suggestion on Adobe's site that Font management software might be at fault. I was using Extensis Suitcase X1 but had not updated to the latest version (as I am annoyed they are charging over 30% more for the exact same software, just because I live in the UK)
    For the past two weeks I have been running without Suitcase (using Apple's FontBook instead) and the frequent crashes have stopped!
    I am currently having one problem, however. EVERY time the app is stopped for any reason (including a normal closing of the application) my site FTP information is lost and has to be re-inserted manually. (This is similar to the problem with DW8 which was solved with the DW8.1 update).
    I can't find any reference to this anywhere else - I am awaiting a response from Adobe Tech Support at the moment
    ChrisH
  • EvelynMangiru User 4 posts since
    Nov 9, 2009
    4. Nov 9, 2009 3:11 PM (in response to jevchance)
    Hi, jevchance!
    Thanks for your suggestion, but it didn't work for me. I've just downloaded and run the Adobe Licensing Manager repair tool, then I restarted my computer (same configuration as yours), but it seems the issue persists. When I use Copy and Paste in Fireworks, Dreamweaver crashes. I receive the same Dreamweaver Quit Unexpectedly error as you.
    A few days ago I had similar problems with Flash. Every time I tried to open a .fla file (any .fla file) or to create a new file, Flash crashed - the same Quit Unexpectedly error. I finally solved it this way:
    (1) I've opened Users/[User name]/Library/Fonts. (2) I've deleted all the fonts I found in the Fonts folder. (There were three fonts there: Aardvark Normal.Ttf, Old Script.ttf, TrajanPro-Regular.otf. All these three fonts had been used in a .fla file some time ago and I still had that .fla file on my computer. After deleting those fonts, I replaced them with other fonts in that .fla file.). Since then I was able to use Flash normally.
    It seems Dreamweaver is craving to be in the spotlight now and it needs a different solution for the QU error, which I really hope I'll find on this forum.
    Evelyn
  • Douggerz Calculating status... 4 posts since
    Nov 12, 2009
    5. Nov 12, 2009 12:33 PM (in response to jevchance)
    new user here. 2nd thread I've read on this.
    Running XP SP3 2GB Ram Intel dual core processor.
    I can at most open a single html file. After that everything becomes unresponsive. Cannot open another file.
    Tried deleting the configration folder. That only allows me to relaunch the program and open a file.
    I'm pissed just purchsed the training package for $200, which is nonrefundable. I'm talking to my manager this afternoon to have him dump this product and get something else!
    Nov 9, 2009
    9. Nov 21, 2009 8:21 AM (in response to jevchance)
    Jevchance,
    Sorry for my late reply. I'm very busy these days.
    I haven't tried trashing my Fireworks preferences, but suddenly my CS4 problems seem to have disappeared. I just don't know how. Since my last post here, all I have done that might be related to this is that I allowed my OS to download and install the latest updates, and I have installed Final Cut Pro.
    I don't know if the problem is really solved, but I've had no crash in Fireworks or Dreamweaver since then. I haven't tried the other CS4 programs.
  • 370H55V Participant 1,816 posts since
    Oct 3, 2009
    11. Apr 5, 2010 3:18 PM (in response to jevchance)
    TechTool Pro is great for checking RAM.
    I got a copy of it when I was working at a major software company. We found bad RAM in about a dozen machines. Two in particular would boot and then go to Kernel Panic (The Grey Screen of Death for a Mac).
    Once we replaced the RAM everything worked better.
    I've personally had two iMacs (the old CRT models) that had RAM issues.But they were both used when I bought them.
    It sucks when it's one right out of the box.
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
