I have posted a zip file containing updated "Camera" color profiles (Camera Standard, Camera Neutral, etc.) for the Nikon D3 and Nikon D700. The zip file contains a copy of the readme, but I'll post it here for convenience, too:
BETA RELEASE NOTES
Overview
These updated Camera v2 beta profiles for the Nikon D3 and Nikon D700
are designed to reduce banding and highlight color artifacts. Note
that highlight areas may appear a little brighter compared to the
earlier profiles.
Installation
If you are on Mac OS X, drag the "Camera v2 beta" folder to:
/Library/Application Support/Adobe/CameraRaw/CameraProfiles
If you are on Windows XP, drag the "Camera v2 beta" folder to:
C:\Documents and Settings\All Users\Application Data\Adobe\CameraRaw\CameraProfiles
If you are on Windows Vista or Windows 7, drag the "Camera v2 beta"
folder to:
C:\ProgramData\Adobe\CameraRaw\CameraProfiles
Note that the above path on Windows Vista and Windows 7 may be hidden
by default. Check your folder settings.
Feedback
The profiles are currently in beta status. Please provide feedback via
the online Adobe user-to-user forums here:
http://forums.adobe.com/community/cameraraw
http://forums.adobe.com/community/lightroom
Thank you!
Hi Per, thanks for the feedback, but you'll have to be more specific if you want further improvements. I should add that comparisons to DxO are not useful for this project, because the purpose of these "Camera" profiles is to match the results from NX (whether "good" or "bad"). Just FYI.
Eric
Hi Eric,
Thanks for those profiles! My comments :
- Posterization is gone! That is great.
- Colors are pretty much like the one you get from Capture NX and more accurate than previous profile (at least they seem to)
- The previous tone curve was closer to the CNX one than the v2 beta profiles. This one is closer with highlights (except the clipping point) but not mid tones that are brighter.
- Highlights are still clipping 0.5EV earlier than CNX, giving too often burnt highlights (BaselineExposure).
Romain
Just downloaded the v2 D3/D700 profiles. This now give a much better match to the native camera picture controls as rendered with Capture NX. Now I have consistency of images in my workflow from camera to lightroom without having to go via NX.
V. 1 gave much too flat colors, especially a brightly sunlit yellow house facade was washed out, but now is very close to NX. In addition, NX skin tones were warmer, and contrast not as agressive as V1. V2 seems to have gotten so close now, that for it is in the range of very acceptable.
Also, the de-mosaic of D700 raw fines with fine density leaves, foliage seems to be improved compared to NX. Nikon D700 always had a tendency to render this type of scenes mushy compared to Canon 5D (just look at Ken Rockwells examples), and I have also experienced the same. Seems like the new lightroom engine has improved on this. Also, the sharpening seems to be improved by being able to apply much more sharpening without objectionable artifacts creeping in as soon. It would be nice to know if I am just hallucinating, or if the developers really have worked on this;-)
For the profiles to match I have to turn off Active D-lighting, a feature which reduces dynamic range in a very fine manner with the D700.
In addition the D-lighting (fine) is NX does a better job than what I can figure out in Lightroom, so this is an area of technology that Adobe should work on (or I need to figure out how to do it better using Lightroom). As far as I can see, Fill lighting is nowhere near as good, but highlight recover is Lightroom appears better. I suspects Lightroom "cheats" by extrapolating values from clipped channels, while NX refuses to guess at what non-capture values might be. (again, I would welcome if the LR developers could comment on this conjecture ;-)
Finally, the U point editing in NX in really brilliant and in addition ViewNX is much faster at previewing and zooming on NEF files.
And one more "final", what about the automatic chromatic abberation correction done by NX, would be nice if LR could do it so I don't have to worry about it.
Although I have not yet gotten to a single software package for post-processing, LR3 will probably reduce my dependency on NX, but not VIEW NX.
Sorry about these last off-subject comments, I know this is a camera profile forum...., but mimicing the Picture controls is a big step forward.
Carsten
My purpose in showing the raw converting from DXO was not to compare programs, but to show that there is still, albeit smaller, is a problem with Posterization, as I often have tasks that includes white walls or light pastel colors, this is a very annoying problem because it is very time consuming to remove.
It has been a recurring problem with Nikon profiles, but D3 is worse than ever, so I for that reason have been forced to use other converters do not have the problem. It has actually been so problematic that I have had 2 times the camera with Nikon because I was convinced that it was an error in the camera. But I am very pleased that Adobe is addressing the problem and hopefully get it resolved
In addition, I can only give CarstenPix right to automatic CA correction will be very helpful. Although it has nothing to do with profiles.
Here are some more examples showing the problem. camera std. V.2 left./ V.1 Right.
Regards.
Per
Hi Carsten,
Thanks for your comments. I'll try address some of them here.
Regarding demosaic, sharpening, etc. in Lightroom 3 beta 2: yes, these have all undergone refinements relative to Camera Raw 5 / Lightroom 2. No hallucinations on your part (at least not in this regard!).
Regarding fill light: note that the fill light threshold has been adjusted in LR 3 beta 2 and this should result in some reduce artifacts compared to earlier versions. Naturally there is always room for improvement going forward, but that is where things stand today.
The other items you've mentioned are generally already in the Lightroom Feature Requests forum. If you would like to elaborate on any of these, I request that you find the corresponding feature request threads in that sub-forum and append to those appropriately. Thanks.
Eric
Thanks Per. It is clear now. Could you please provide the raw files corresponding to these sample images? They would help me refine further. If so, please use YouSendIt.com with target email address madmanchan2000@yahoo.com.
Eric
Hi Rudi, I think you may be misunderstanding the purpose of these profiles. The goal of these profiles is not to produce natural colors. The goal is simply to produce the same rendition that NX produces (whether good or bad, natural or not) -- and hopefully artifact-free. To be clear: The original feature request was, "Please give us colors similar to the camera maker's colors."
Eric
Thank you MadManChan2000 for your effort! I have tried new profiles and they looks great, but I found out some un-smoothness in photo of rainbow. The transitions of Camera x v2 are not smooth as older Camera x. There is a leap between yellow and green and between cyan and blue. Very similar unsmooth transitions are visible in profile Adobe Standard.
On this link you can download original raw + xmp and exported jpg (Camera Standard v2 vs. Camera Standard beta1):
Eric, thanks very much for your efforts! Here is a sample where your changes have helped me (LR rendering done in LR3B2).
The Nikon NX and v2 camera neutral renderings are almost identical, while the v1 camera neutral rendering is blotchy in comparison.
I will look for ones that do not work as well, but this is looking good Eric.
Regards
Rory
I feel silly asking this, but I am using Vista and I don't have a file called ProgramData
, and for that matter I can't even find one called Camera Raw. That being said, if I go through adobe labs I have no proble
m istalling their camera profiles, so I am sure there is a place for yours to go. Do you have any other suggestions
on a way to install there files? I am so frustrated with my D700's NEF files.
I hope that this update to the D3/D700 Nikon Camera profiles will eventually flow through to other Nikon models. I have very noticable
cyan/magenta banding in some raw images from my D90 camera when Camera profiles are applied, such as Camera Standard. This banding reduces significantly when I apply the Adobe Standard profile, but doesn't elimate it completely.
Tony
Eric,
Thank you so much for taking action on this! It must be a daunting task to maintain, update and add to the camera profile list and therefore we all do appreciate your work!
Another profile that caught my eye since quite some time is the Canon 5D Mark II Standard profile. In contrary to the camera's behavior (or that of DPP) this profile renders images in warm light and with low exposure not very well. Especially with skin tones this shows up negatively.
Thanks for listening!
Thomas
Eric outstanding job on these. Just downloaded these profiles and compared them to the profiles that were in Camera Raw 6.
These profiles are much better than the default profiles in Camera Raw 6, much less banding and much better neutrals.
Now if you could just create a set of profiles that would match the colors and curve that Capture One Pro 5 produces
I'd pay good money for that.
Lance
Hi Eric
It's my birthday today and you've just sent me an unexpected but very welcome present! ![]()
I don't post much on this forum but thought I'd make the effort to thank you for the hard work and effort you've put into improving this - and other - areas of Camera Raw. I've been working with Photoshop since it's first release here in the UK and have been shooting Nikons about as long. Since the change to digital I've always felt that the Adobe conversions - in Lightroom and Camera Raw - didn't quite give the quality I was getting from NX and NX2.
With the updates to the Camera Raw engine and the new camera profiles - which I presume is replicated in the Lightroom 3 v2 beta that I've been testing - the quality has come on leaps and bounds, so much so that I'm seriously considering moving the majority of my work over to Lightroom 3 when it's released but certainly to Camera Raw in the short to mid-term.
I'll get on with some more serious testing later this week but just thought I drop by and leave a token of my appreciation.
Keep up the good work!
Jason
Replica Imaging Limited - UK
www.replica-imaging.co.uk
Confused as to which are the latest versions of these profiles. Are the profiles listed as the download "v.2 beta" updated profile with files dated March 10, 2010 intended to supercede the profiles included in the Camera Raw update 5.7 with file dates of April 7, 2010, are they the same as those with the most recent Raw update, or what?
Eric, thanks very much for the work you've done on these profiles. After working on my own custom camera profiles, I know how much work this takes. So thanks again for the noticeably improved results.
Quick question for you: The following website has some sample images that seem to demonstrate some weaknesses in the way Lightroom produces almost banding-like artifacts when rendering color gradients or defocused areas of color (I see his happen, for example, if there are out-of-focus flowers in the background of wedding images (usually deep reds and deep purples are the worst culprits).
See near the bottom of this page:
http://ishootshows.com/2010/01/22/lightroom-3-vs-nikon-capture-nx-2/
So my other question is: Is this more a function of better calibrating and tweaking for the color table within the DNG Profile Editor? Or is it more a function of tweaking the Tone Cuve?
Not a dumb question.
In the LR3 Develop Module, scroll down to Camera Calibration. The second setting down is Profile and it is a dropdown list from which you can choose which profile you want to use.
The question I have is which of the profiles is the most recent? For example, I show Camera Portrait, Camera Portrait beta 1 and Camera Portrait v2 (for the Nikon D3). It's the same assortment of choices for Landscape, Natural, Standard and Vivid. Am I correct that v2 is the most recent version of each set of profiles?
John
Am I assuming (hoping) correctly that the upgrade installation of Lightroom 3 doesn't update these camera profiles? I've been noticing a lot of posterizing as well as magenta and green colour artifacts in neutral tones since upgrading to my D700. I'm really hoping that updating my profiles when I get home will fix things.
Any word on when these will be out of beta? Will they be replacing the D3 and D700 profiles that are currently included in the Camera Raw 6.2 and LR 3.2 releases or are they going to be added as permanent alternate profiles alongside the current "V1" versions?
I tried searching Adobe Labs for updated information and can't even find any references to the beta profiles ... is there any place to keep tabs on their status? It's been a long time since the betas came out.
SJH
I may be doing something wrong, but I'm getting drastically different results when I open an NEF file in Capture NX2 versus Lightroom 3 (using both the boxed camera profiles and these beta v2 profiles) from images shot on a D700.
In NX2, I ensured that I was using the "Standard" profile, and in the case of LR3, "Camera Standard v2".
Here are the two different results:
NX2
http://brucebracken.com/photography/v/pptest/1a.jpg.html
LR3
http://brucebracken.com/photography/v/pptest/1b.jpg.html
The LR3 image looks much more color saturated, among other things, but from what I remember, the NX2 image was much closer to how the scene looked when I was doing the shooting.
Can someone help me understand why LR3 produces such a different default image from the NEF file than NX2?
Thanks in advance!
There were many posts about this in the past. So I took a look into Adobe's profiles for D700 (original and beta v2). I have some experience with this, because I made my own program for making dng profiles for some Canon cameras, that are not supported by Adobe. I noticed several things:
First, in the lookup table of both versions of the profile, values for Value segment 0 (= total black) are a simple copy of segment 1 (=dark midtones). My opinion is that this approach is a bit oversimplified, resulting with big differences in dark tones between ACR and NX (oversaturated blue and orange/brown on your picture). Midtones and highlights are much better
Obviously, points for total black can't be calibrated at all. What I did in my program was that I made calibration on very dark tones, and did some recalculation to aproximatelly match camera jpegs. It's not possible to get total match, but I came much closer
Second, there is a difference in tone curve between original D700 profile and beta v2. Tone curve in the original profile has a "notch" in the lowest part, caused by the fact that blacks slider default value should be 5 (according to Adobe). On the beta v2 profile, bottom part of the tone curve is smooth and looks similar to what I got on my profiles with blacks slider set to 0. So I suppose that for this profile (and some other latest profiles), blacks should be set to 0.
It would be nice to get some comment about this from Eric or Jeff
I attached a printscreen from my program that can display a lookup table in the profile, and this is how Hue segment 0 (= red) looks like.
On the left pane, there are value and saturation remapping points (in Photo Pro color space), and on the right, there are hue shifts
Also, there is a tone curve on the left pane (displayed in 3 different scales)
Copyright © 2012 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
