Home/Support/
Forums
1130 Views 9 Replies Latest reply: Aug 12, 2011 7:44 AM by Ged_mc RSS
cubelogic Calculating status... 7 posts since
Mar 16, 2010
Apr 6, 2010 1:48 PM
How to optimize text editing performance in Flash Builder 4?
I am running Flash Builder 4.0.0 (build 272416) on a Macbook Pro 2.4 Ghz with 4Gb RAM. I am experiencing extremely poor performance while simply editing moderately complex MXML files.
By poor performance I mean noticeable lag between keystrokes. Type one char, wait 2 or 3 seconds on a 700 lines MXML with about 20 buttons, 2 AdvancedDataGrids, 1 text area. Fairly complex, but that's what I need.
Opening said MXML file takes around 12 seconds.
Saving said MXML results in around 8 seconds: no automatic building, nothing else being done.
On trivial MXMLs there's still a noticeable lag while typing, around 0.5 seconds per char.
At this point Flash Builder 4 is unusable for me: editing .as files is still decent, but for MXMLs is almost impossible to work with, as you can see from the numbers above.
Is there *anything* I can do to improve text editing performance? I've disabled all sort of niceties (automatic completion, indentation and so on) in the prefs, sadly to no avail. This is a major inconvenience for us.
  • Jason San Jose Adobe Employee 432 posts since
    May 28, 2009
    1) Are you using plug-in or standalone? If standalone, the default memory settings should be ok. If plug-in and in an external Eclipse distribution (i.e. not the bundled Eclipse), you'll want to change your memory settings. See this blog post http://blogs.adobe.com/jasonsj/2010/02/improving_compiler_performance. html. You can monitor memory usages simply within Eclipse under Preferences > General > Show heap status.
    2) Try turning off mark occurrences (the highlighter button in the toolbar)
    I tried to reproduce this in a similarly sized Flash Catalyst MXML file and didn't see any issues. Opening a file shouldn't take 12 seconds unless for the initial hit for loading the project the first time.
    I'd be curious to see if a clean workspace would fix your issue. That might indicate a cache problem.
    Jason San Jose
    Software Engineer, Flash Builder
    May 28, 2009
    Oops. Sorry, I should have clarified how to get a clean workspace.
    1) Go to File > Switch Workspace > Other... and choose an new, empty folder.
    2) Import your existing project by going to File > Import, General > Existing projects, and find the location of your project in the old workspace. The default location on mac is /Users/you/Documents/Adobe Flash Builder 4/your_project
    Jason San Jose
    May 28, 2009
    Say what? If I read that right...
    1) Under Build Path > Library Path, you have foo.swc
    2) Under Build Path > Source Path, you had a path to the source of foo.swc
    And your solution was to remove the source path and add the source attachment? The definitions from the source would clobber the definitions read from the SWC. That could perhaps lead to some issues, but what I'm not sure.
    If the SWC you're using is open source, I'd like to file the bug and get it reproduced here. Perhaps there's some characteristic of that project that presents some issues.
    I'm glad you were able to figure that out on your own. I wouldn't have guessed that one.
    Jason San Jose
  • vibsgupta User 27 posts since
    May 14, 2009
    Here is one method that I have found successful.
    Actually super slowing of my Flash Builder 4.0.1 doesn't happen always. Its more like twice or thrice in a week at most but when it happens it happens consistently.
    One SURE Shot way to get your text editor working back is to follow the follow steps:
    1. Make sure that you have disable 'Mark Occurences' button.
    2. After disabling that button 'Right Click' on your project and Export it was a Single Archive File as shown in the pic below
    3. http://i28.tinypic.com/rhsnsp.jpg.
    4. Delete your Project (from the hardrive as well)
    5. Import it again by going into 'import'
    6. Hopefully editor should work fine now.
    Vibs
  • Ged_mc Calculating status... 20 posts since
    Jan 23, 2002
    My Flash Builder 4.5 became super-slow, constantly rebuilding workspace.
    The issue stopped after I removed the project folder from Jungle-Disk synch folder ( a cloud online back up program )
    Hope this helps
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
