Working in Photoshop Gray to Indesign to PDF help..
Apr 9, 2010 7:49 PM
CAN SOMEONE HELP ME save out a PDF in the final tagged color space:  Gray Dot Gain 20%
I am saving my Photoshop .tif files with embedded profile: Gray Dot Gain 20%
My InDesign Working CMYK is: US Web Coated SWOP v2
I place my .tif files in InDesign.
What is confusing me is InDesign's no Gray settings.
My first Question is TARGETING my PDF to the desired print space:  Gray Dot Gain 20% — THERE IS NO GRAY CONVERSION OPTION!
As my InDesign book is in Working CMYK, and my placed .tif files are in Gray Dot Gain 20% — I have determined I will need to Convert to my print profile in Acrobat — but what would be the best Adobe PDF Preset setting to get my tagged CMYK and tagged Gray into a PDF so I can Convert Colors to Dot Gain 20% in Acrobat?
No Gray support in In Design has be baffled — I am thinking I should avoid Gray all together and just feed InDesign RGB to be sure InDesign passes through my .tiff profile to Acrobat...
    Apr 10, 2010 2:45 AM   in reply to gator soup
    I have never had any problems with greyscale images, I create them in photoshop and embedd grey icc-profile into them while saving. Then I place them to Indesign and when I export PDF, I choose a CMYK profile that matches to paper that printer is going to use.
    As a Color Conversion, you may use either No Conversion or Convert To Destination (preserve numbers), just don´t include profiles to PDF. They may cause some unwanted re-conversions later in the process...
    Here´s few PDF samples made from same indd (1 page with one 20% dot gain photo placed)
    Export with no color conversions:
    http://dl.dropbox.com/u/133381/noConv.pdf
    Export with colors converted to destination profile (Fogra Coated), profiles not included
    http://dl.dropbox.com/u/133381/ConvToDest.pdf
    Export Export with colors converted to destination profile (Fogra Coated), profiles included
    http://dl.dropbox.com/u/133381/ConvToDestWithProf.pdf
    Last one is risky... you can check those out yourself by opening them to Acrobat and using Output Preview. With first and second PDF,  if you hide black channel, whole image disappears, meaning it will be printed to black plate only.
    With last one, image will be converted to CMYK if you use any other simulation profile than one has been used as Destination profile. It means that there is a risk that your image will be converted to CMYK image in RIP.
    Apr 10, 2010 6:05 AM   in reply to gator soup
    You are not alone in your frustration. Gray profile support is a longstanding request for many users.
    InDesign treats grayscale images as being on the K plate of the CMYK working space. It's possible to create a custom CMYK gray space, and that has been discussed here a number of times. In all honesty I've never really completely understood how this is done (involves assigning curves in Photoshop, if I remember), and I've never tried to do it. Instead I use a gray profile approriate to the stock on which the job will be printed (and 20% dot gain is a good choice for coated stock), then use a similarly approrpiate CMYK working space in ID. Like Petteri, I've never been unhappy with the results, but your mileage may vary.
    It is possible to convert your CMYK PDF to Dot Gain 20% in Acrobat, but I was not happy with the appearance on screen the last time I tried it ( I think I lost my 100% K levels), but it may be that the porblem came from a lack of complete understanding of what I was doing in Acrobat.
    Apr 10, 2010 10:29 AM   in reply to gator soup
    In the CMYK working space, K is the Black plate. ID treats grayscale coming in as if it is in the current CMYK working space and as if the file has no data in C, M, or Y channels, so all of the grayscale numbers you have are preserved, but the gray profile is not. Instead, the gray numbers are now tagged as the current CMYK space.
    If the numbers were correct coming in, and you export without doing another conversion, the numbers will remain correct in the exported PDF. My impression, and as I said before I don't claim to understand color conversion in Acrobat 100%, is that if you do a conversion in Acrobat, your images will print lighter as the conversion factors in the dot gain to achieve the appearance of the numbers you started with, which I think should already be asjusted for the dot gain. Maybe someone else can do a better job on this and enlighten us both.
    So for me, at least, I don't see a need to have the PDF tagged as Dot Gain 20%, or anything else for that matter. My presumption is that the images were properly prepared in Photoshop, and if the numbers are passed through on the K plate, it makes no difference what the profile is at output since they will not have changed.  You can see this for yourself by checking the gray values in photoshop, then looking at the separations preview in ID, and at the Output Preview in Acrobat.
  • Rob Day
    Oct 16, 2007
    Apr 11, 2010 5:04 AM   in reply to gator soup
    In Photoshop a grayscale's grayscale profile has no effect on the output values, so if you fill a grayscale doc with 50%, 50% gets output whether the profile is 20% dot gain or 30% dot gain. The profile does effect the conversion back to RGB for display or if you print to an RGB driven printer (the preview of 30% dot gain is darker than 20%) .
    ID doesn't have a grayscale space and it also ignores incoming grayscale profiles. As Peter mentioned grayscales are generally color managed as if they are on the black plate of CMYK, which makes sense because, unless there is a 5th plate on the press, that's where they have to go. So, in ID when Separation or Overprint Preview is turned on, the conversion back to RGB for display is driven by your doc's CMYK profile and not the 20% Dot Gain profile, which was used in PS. If your ID (US SWOP) CMYK profile is an accurate profile of the destination press, then the ID preview is the more accurate of the two.
    If you want matching previews, you can use the US SWOP profile as the grayscale profile in Photoshop either by assigning it or making it the gray working space (Color Settings>Gray Working Space>Load...). If you assign your ID CMYK profile to the grayscale in PS, and then export using either the PDF/X1-a or PDF/X-4 presets, you should see consistent grayscale previews in the 3 apps
  • Rob Day
    Oct 16, 2007
    Apr 11, 2010 7:04 AM   in reply to gator soup
    If your final destination is an offset press RGB would be a problem—you would get 4-color grays.
  • Rob Day
    Oct 16, 2007
    Apr 11, 2010 1:16 PM   in reply to gator soup
    However — it will not display correctly (without soft proofing trickery) and it will not Convert to another profile correctly because the DotGain20% profile was stripped (and a CMYK profile was Applied).
    If your final destination is a CMYK offset press you can't have two different profiles color managing the black plate—50% black can't accurately get converted back to RGB for display two different ways (DotGain 20% and US SWOP Coated) because that wouldn't happen on press. ID rightfully ignores your 20% Dot Gain profile and assigns the doc's CMYK profile so that 50% grayscale is color managed the same as 0|0|0|50 CMYK. If US SWOP Coated is in fact an accurate profile of the destination press, then it should also be used as the profile for your grayscale's in PS.
    That means the 'genius' downstream can't Convert my Gray TIFFs to Monitor RGB to PROOF them correctly on screen, and s/he can't Convert my Gray TIFFs to any other print space because the InDesign> ExportPDF process stripped my DotGain20% profiles and moved my Gray 'numbers' into a CMYK profile.
    Why have you decided that 20% Dot Gain is the correct profile for your grayscales? If you use your CMYK profile as the grayscale space in PS then there won't be a conflict. In that case you can save as PDF/X-1a or, if you want to allow further conversions PDF/X-4—either way Acrobat's output simulation softproof will be correct.
  • Rob Day
    Oct 16, 2007
    Apr 12, 2010 4:23 AM   in reply to gator soup
    You can also create a CMYK profile, which uses a 20% dot gain curve for the black plate, and use it InDesign as your CMYK profile (Peter alluded to that in post 2), in that case ID and Acrobat's previews will match your PS 20% dot gain preview.
    First generation profiles were curved based and you can still save them out of Photoshop using the legacy separation setup, which by default is 20% for the black plate. So from Photoshop it would be: Color Settings>CMYK>Custom CMYK. In the Custom CMYK dialog change the name to something like IDGrayscale20, leave the Dot Gain setting as 20%. Then save the profile (CMYK>Save CMYK...) into your profiles folder and it will be available in ID as a CMYK profile.
    The legacy profile would be fine for all grayscale documents, but I would not use it for color work.
  • Rob Day
    Oct 16, 2007
    Apr 12, 2010 10:59 AM   in reply to gator soup
    There's an issue with 10.6.x and CS4 and profiles. You have to alias your profiles folder into your  /Library/Application Support/Adobe/Color/Profiles folder. This thread has the details:
    http://forums.adobe.com/message/2554280#2554280
  • Rob Day
    Oct 16, 2007
    Apr 12, 2010 12:58 PM   in reply to gator soup
    Keep in mind all of this effects the only previews in the apps and not the output values:
    You can see the curve that's used in your custom CMYK profile by choosing Dot Gain>Curves>Black
    http://www.zenodesign.com/scripts/Blackcurve.png
    And then you can see the same curve is used when you use Dot Gain 20% by choosing Gray>Dot Gain 20% and then Gray>Custom Dot Gain
    http://www.zenodesign.com/scripts/gsDotgain.png
    You could then screen capture the previews from PS and ID and take RGB readings to confirm the previews match:
    http://www.zenodesign.com/scripts/gspreviews.png
    One other twist to watch out for in ID is: by default (with Overprint and Separation Preview turned off) the preview of grayscales is not color managed—they effectively preview as 2.2 gamma and your profiles have no effect. So, you have to turn on Overprint to see the 20% Dot Gain preview.
  • Rob Day
    Oct 16, 2007
    Apr 12, 2010 1:38 PM   in reply to gator soup
    Policy: "Preserve" — What is being preserved, numbers or appearance?
    Preserve refers to the CM Policy you set when the doc was created—Preserve Embedded Profiles.
    "Assign " Profile —  Why would I ever want to Assign Profile in this case (CMYK-to-CMYK) unless Assign Profile wants me to select the original source profile this document was created under (not the new Working CMYK destination profile)?
    You do want to assign in this case—assigning the custom CMYK profile you made will change the preview of black values, which is what you want (you didn't like the US SWOP Coated preview).
    Further, I assume Assign Profile it is talking about my document space, not my Placed Photoshop tagged Gray images?
    Yes it's your ID document space, which is going to CM the preview of your grayscales
    Placed Content — yes I want InDesign to honor and use my embedded profiles in all Placed content.
    ID ignores grayscale profiles—even with Enable All Profiles. Again, the black plate can't be CM'd by two different profiles, that's why grayscale profiles get ignored and the document's CMYK profile gets assigned.
  • Rob Day
    Oct 16, 2007
    Apr 12, 2010 1:45 PM   in reply to gator soup
    Thanks, I appreciate you taking the time to help me understand how InDesign is working.
    Just make sure you don't use the legacy profile for color work—make a Color Settings named something like ID Grayscale...
    Sep 24, 2010 8:18 AM   in reply to gator soup
    i have just come across this thread as it was a problem i just encountered, whether its still of any use or not my solution is...
    In photoshop set the colour model of the image to CMYK
    Thenuse channel mixer to convert the image to monochrome and adjust the image accordingly.
    (you'll notice that when you click monochrome you lose the colour depth as like when your previewing in indesign hence the need to adjust).
    Once saved the image will preview and out put correctly.
    All the best
    Andy Barrington
  • Rob Day
    Oct 16, 2007
    Sep 24, 2010 9:56 AM   in reply to Andrew Barrington
    You can also transfer the grayscale values directly to the black plate when you convert GS to CMYK—just set your CMYK working space to a Maximum Black Generation via Color Settings>CMYK>CustomCMYK.
