MadManChan2000
New Nikon D3 and D700 "Camera" v2 beta profiles
Mar 23, 2010 1:23 PM
I have posted a zip file containing updated "Camera" color profiles (Camera Standard, Camera Neutral, etc.) for the Nikon D3 and Nikon D700. The zip file contains a copy of the readme, but I'll post it here for convenience, too:
BETA RELEASE NOTES
Overview
These updated Camera v2 beta profiles for the Nikon D3 and Nikon D700
are designed to reduce banding and highlight color artifacts. Note
that highlight areas may appear a little brighter compared to the
earlier profiles.
Installation
If you are on Mac OS X, drag the "Camera v2 beta" folder to:
    /Library/Application Support/Adobe/CameraRaw/CameraProfiles
If you are on Windows XP, drag the "Camera v2 beta" folder to:
    C:\Documents and Settings\All Users\Application Data\Adobe\CameraRaw\CameraProfiles
If you are on Windows Vista or Windows 7, drag the "Camera v2 beta"
folder to:
    C:\ProgramData\Adobe\CameraRaw\CameraProfiles
Note that the above path on Windows Vista and Windows 7 may be hidden
by default. Check your folder settings.
Feedback
The profiles are currently in beta status. Please provide feedback via
the online Adobe user-to-user forums here:
http://forums.adobe.com/community/cameraraw
http://forums.adobe.com/community/lightroom
Thank you!
    Community Member
    Mar 23, 2010 9:07 PM
    Excellent!  Just tried out the new Camera profiles on a couple of my more problematic D700 files, and the color posterization I used to see seems to be gone.  Thanks for making these new beta profiles available.  Good work!
    Community Member
    Mar 26, 2010 11:58 AM
    This is absolutely great! I was waiting for this day for a long time! I think this is the main thing I wanted from LR version 3!
    However there significant changes in overall colour rendering, especially in lightr-blue\green colours but I can live with it.
    Thank you!
    Community Member
    Mar 27, 2010 11:48 AM
    It is definitely an  improvement, the question is whether the profile is still good enough,  there is still room for improvement, but definitely a step in the right  direction.
    Wbr.
    Per
    Community Member
    Mar 27, 2010 12:54 PM
    Hi Eric,
    Thanks for those profiles! My comments :
    - Posterization is gone! That is great.
    - Colors are pretty much like the one you get from Capture NX and more accurate than previous profile (at least they seem to)
    - The previous tone curve was closer to the CNX one than the v2 beta profiles. This one is closer with highlights (except the clipping point) but not mid tones that are brighter.
    - Highlights are still clipping 0.5EV earlier than CNX, giving too often burnt highlights (BaselineExposure).
    Romain
    Community Member
    Mar 27, 2010 4:38 PM
    Just downloaded the v2 D3/D700 profiles.  This now give a much better match to the native camera picture controls as rendered with Capture NX.  Now I have consistency of images in my workflow from camera to lightroom without having to go via NX.
    V. 1 gave much too flat colors, especially a brightly sunlit yellow house facade was washed out, but now is very close to NX.  In addition, NX skin tones were warmer, and contrast not as agressive as V1.  V2 seems to have gotten so close now, that for it is in the range of very acceptable.
    Also, the de-mosaic of D700 raw fines with fine density leaves, foliage seems to be improved compared to NX.  Nikon D700 always had a tendency to render this type of scenes mushy compared to Canon 5D (just look at Ken Rockwells examples), and I have also experienced the same.  Seems like the new lightroom engine has improved on this.  Also, the sharpening seems to be improved by being able to apply much more sharpening without objectionable artifacts creeping in as soon.  It would be nice to know if I am just hallucinating, or if the developers really have worked on this;-)
    For the profiles to match I have to turn off Active D-lighting, a feature which reduces dynamic range in a very fine manner with the D700.
    In addition the D-lighting (fine) is NX does a better job than what I can figure out in Lightroom, so this is an area of technology that Adobe should work on (or I need to figure out how to do it better using Lightroom).  As far as I can see, Fill lighting is nowhere near as good, but highlight recover is Lightroom appears better.  I suspects Lightroom "cheats" by extrapolating values from clipped channels, while NX refuses to guess at what non-capture values might be.   (again, I would welcome if the LR developers could comment on this conjecture ;-)
    Finally, the U point editing in NX in really brilliant and in addition ViewNX is much faster at previewing and zooming on NEF files.
    And one more "final", what about the automatic chromatic abberation correction done by NX, would be nice if LR could do it so I don't have to worry about it.
    Although I have not yet gotten to a single software package for post-processing, LR3 will probably reduce my dependency on NX, but not VIEW NX.
    Sorry about these last off-subject comments, I know this is a camera profile forum...., but mimicing the Picture controls is a big step forward.
    Carsten
    Community Member
    Mar 27, 2010 7:31 PM
    My purpose in showing the raw converting from DXO was not to compare programs, but to show that there is still, albeit smaller, is a problem with Posterization, as I often  have tasks that includes white walls or light pastel colors, this is a  very annoying problem because it is very time  consuming to remove.
    It has been a recurring problem  with Nikon profiles, but D3 is worse than ever, so I for that reason  have been forced to use other converters do not have the problem. It has actually been so problematic that I have had 2 times  the camera with Nikon because I was convinced that it was an error in  the camera. But I am very pleased  that Adobe is addressing the problem and hopefully get it resolved
    In addition, I can only give  CarstenPix right to automatic CA correction will be very helpful. Although it  has nothing to do with profiles.
    Here are some more examples  showing the problem. camera std. V.2 left./ V.1 Right.
    Regards.
    Per
    Community Member
    Mar 28, 2010 5:03 AM
    Hi, overall tonality/contrast rendition are improved.
    Reds specifically crimsons and to lesser extent orange are still not rendering true natural colours compared to custom calibrated profiles from a colour chart.
    D700 - LR2
    Thanks, Rudi
    Community Member
    Mar 28, 2010 1:12 PM
    Just tried the new D700 profiles, great improvement, far less posterization and strange blocked out dark when using the D2x modes. Keep up the great work, all looks promising!
    Community Member
    Mar 29, 2010 8:41 AM
    Thank you MadManChan2000 for your effort! I have tried new profiles and they looks great, but I found out some un-smoothness in photo of rainbow.  The transitions of Camera x v2 are not smooth as older Camera x. There is a leap between yellow and green and between cyan and blue. Very similar unsmooth transitions are visible in profile Adobe Standard.
    On this link you can download original raw + xmp and exported jpg (Camera Standard v2 vs. Camera Standard beta1):
    http://www.edisk.cz/stahni/97416/LR3.ZIP_21.11MB.html
    Community Member
    Mar 29, 2010 3:14 PM
    Eric, thanks very much for your efforts!  Here is a sample where your changes have helped me (LR rendering done in LR3B2).
    The Nikon NX and v2 camera neutral renderings are almost identical, while the v1 camera neutral rendering is blotchy in comparison.
    I will look for ones that do not work as well, but this is looking good Eric.
    Regards
    Rory
    Community Member
    Apr 6, 2010 4:17 AM
    Is this just for the D3 or also for the D3s?
    Community Member
    Apr 6, 2010 1:24 PM
    function(){return A.apply(null,[this].concat($A(arguments)))}
    I saw somewhere that Eric said the profiles for the D3s are different and already "corrected".
    Rory
    Community Member
    Apr 10, 2010 8:10 AM
    It would be helpful to have a confirmation that the D3s profiles are already "optimized". Thanks!
    Jeff
    Community Member
    Apr 16, 2010 4:06 PM
    I feel silly asking this, but I am using Vista and I don't have a file called ProgramData
    , and for that matter I can't even find one called Camera Raw.  That being said, if I go through adobe labs I have no proble
    m istalling their camera profiles, so I am sure there is a place for yours to go.  Do you have any other suggestions
    on a way to install there files?  I am so frustrated with my D700's NEF files.
    Community Member
    Apr 16, 2010 7:30 PM
    In the windows explorer, under the folder options > view: make sure you have "show hidden files, folders and drives" checked.
    Community Member
    Apr 19, 2010 12:47 AM
    I hope that this update to the D3/D700 Nikon Camera profiles will eventually flow through to other Nikon models.  I have very noticable
    cyan/magenta banding in some raw images from my D90 camera when Camera profiles are applied, such as Camera Standard.  This banding reduces significantly when I apply the Adobe Standard profile, but doesn't elimate it completely.
    Tony
    Community Member
    Apr 27, 2010 4:01 PM
    Eric,
    Thank you so much for taking action on this! It must be a daunting task to maintain, update and add to the camera profile list and therefore we all do appreciate your work!
    Another profile that caught my eye since quite some time is the Canon 5D Mark II Standard profile. In contrary to the camera's behavior (or that of DPP) this profile renders images in warm light and with low exposure not very well. Especially with skin tones this shows up negatively.
    Thanks for listening!
    Thomas
    Community Member
    May 13, 2010 12:52 PM
    Eric outstanding job on these. Just downloaded these profiles and compared them to the profiles that were in Camera Raw 6.
    These profiles are much better than the default profiles in Camera Raw 6, much less banding and much better neutrals.
    Now if you could just create a set of profiles that would match the colors and curve that Capture One Pro 5 produces
    I'd pay good money for that.
    Lance
    Community Member
    May 14, 2010 7:20 PM
    Eric, any plans to produce these for the D3X?  Thanks.
    Community Member
    May 16, 2010 4:13 AM
    Hi Eric
    It's my birthday today and you've just sent me an unexpected but very welcome present!
    I don't post much on this forum but thought I'd make the effort to thank you for the hard work and effort you've put into improving this - and other - areas of Camera Raw. I've been working with Photoshop since it's first release here in the UK and have been shooting Nikons about as long. Since the change to digital I've always felt that the Adobe conversions - in Lightroom and Camera Raw - didn't quite give the quality I was getting from NX and NX2.
    With the updates to the Camera Raw engine and the new camera profiles - which I presume is replicated in the Lightroom 3 v2 beta that I've been testing - the quality has come on leaps and bounds, so much so that I'm seriously considering moving the majority of my work over to Lightroom 3 when it's released but certainly to Camera Raw in the short to mid-term.
    I'll get on with some more serious testing later this week but just thought I drop by and leave a token of my appreciation.
    Keep up the good work!
    Jason
    Replica Imaging Limited - UK
    www.replica-imaging.co.uk
    Community Member
    May 21, 2010 11:26 AM
    Confused as to which are the latest versions of these profiles.  Are the profiles listed as the download "v.2 beta" updated profile with files dated March 10, 2010 intended to supercede the profiles included in the Camera Raw update 5.7 with file dates of April 7, 2010,  are they the same as those with the most recent Raw update, or what?
    Community Member
    May 24, 2010 11:15 PM
    MadManChan2000 wrote:
    The goal is simply to produce the same rendition that NX produces (whether good or bad, natural or not) -- and hopefully artifact-free. To be clear: The original feature request was, "Please give us colors similar to the camera maker's colors."
    Eric, thanks very much for the work you've done on these profiles. After working on my own custom camera profiles, I know how much work this takes. So thanks again for the noticeably improved results.
    Quick question for you: The following website has some sample images that seem to demonstrate some weaknesses in the way Lightroom produces almost banding-like artifacts when rendering color gradients or defocused areas of color (I see his happen, for example, if there are out-of-focus flowers in the background of wedding images (usually deep reds and deep purples are the worst culprits).
    See near the bottom of this page:
    http://ishootshows.com/2010/01/22/lightroom-3-vs-nikon-capture-nx-2/
    So my other question is: Is this more a function of better calibrating and tweaking for the color table within the DNG Profile Editor? Or is it more a function of tweaking the Tone Cuve?
    Community Member
    Jun 9, 2010 2:45 PM
    When are these going "Gold"? (shipping)
    Carsten
    Community Member
    Jun 9, 2010 7:09 PM
    These profiles are very close to the in camera JPG.  Perfect!
    Community Member
    Jun 11, 2010 9:01 AM
    Would it be possible to get an updated profile for a D300 as good quality as these?
    Community Member
    Jun 11, 2010 4:28 PM
    Really dumb question here, but in my Camera Profiles folder I've got folders named 'Camera', 'Camera beta 1', 'Camera beta 2', and now 'Camera v2 beta'. How do I know which camera profiles are being used in LR3?
    Community Member
    Jun 11, 2010 6:07 PM
    Not a dumb question.
    In the LR3 Develop Module, scroll down to Camera Calibration.  The second setting down is Profile and it is a dropdown list from which you can choose which profile you want to use.
    The question I have is which of the profiles is the most recent?  For example, I show Camera Portrait, Camera Portrait beta 1 and Camera Portrait v2 (for the Nikon D3).  It's the same assortment of choices for Landscape, Natural, Standard and Vivid.  Am I correct that v2 is the most recent version of each set of profiles?
    John
    Community Member
    Jun 12, 2010 7:12 PM
    Thanks, Eric.  Your quick reply and the great profiles are much appreciated.
    John
    Community Member
    Jun 24, 2010 9:58 PM
    I put the two folders "Nikon D700" and Nikon D3 inside the CameraProfiles folder (Mac - 10.5) and also put the Camera v2 beta folder in there as well (first) but LR3 under Camera Calibration/Profile all is see is "Embedded." Any sugestions?
    thanks much.
    D.
    Community Member
    Jun 24, 2010 11:56 PM
    You're using JPEGs.
    Community Member
    Jun 25, 2010 1:05 AM
    What Dorin said.
    Camera profiles are used for converting raw images, so you need to be working on your raw files, not files which have already been converted.
    Community Member
    Jun 25, 2010 6:51 AM
    Ah, sorry. I had the NEF and the JPEG next to each other and picked the wrong one.
    Thanks again.
    D.
    Community Member
    Jul 6, 2010 7:56 AM
    Is there an estimate for when the final profiles will be out?
    What happens if I then remove those beta profiles? Will LR fall back to the official profiles or will it not find any profile?
    Thomas
    Community Member
    Jul 12, 2010 9:26 AM
    Am I assuming (hoping) correctly that the upgrade installation of Lightroom 3 doesn't update these camera profiles? I've been noticing a lot of posterizing as well as magenta and green colour artifacts in neutral tones since upgrading to my D700. I'm really hoping that updating my profiles when I get home will fix things.
    Community Member
    Sep 2, 2010 4:36 PM
    LR 3.2 final - any news? Is there an estimated release date for the final profiles?
    Thomas
    Community Member
    Sep 3, 2010 9:30 AM
    Any word on when these will be out of beta?  Will they be replacing the D3 and D700 profiles that are currently included in the Camera Raw 6.2 and LR 3.2 releases or are they going to be added as permanent alternate profiles alongside the current "V1" versions?
    I tried searching Adobe Labs for updated information and can't even find any references to the beta profiles ... is there any place to keep tabs on their status?  It's been a long time since the betas came out.
    SJH
    Community Member
    Oct 11, 2010 10:11 AM
    Will a D3 fit into this Pelican camera case?
    http://www.pelicanonline-ralphs.com/1200-case.htm
    Community Member
    Oct 25, 2010 12:40 PM
    I'm also wondering if there any sort of ETA on the final versions of these profiles; it's basically been a half year since the V2 beta. Seems like sort of an indefinite project right now?
    Community Member
    Nov 8, 2010 11:53 PM
    I may be doing something wrong, but I'm getting drastically different results when I open an NEF file in Capture NX2 versus Lightroom 3 (using both the boxed camera profiles and these beta v2 profiles) from images shot on a D700.
    In NX2, I ensured that I was using the "Standard" profile, and in the case of LR3, "Camera Standard v2".
    Here are the two different results:
    NX2
    http://brucebracken.com/photography/v/pptest/1a.jpg.html
    LR3
    http://brucebracken.com/photography/v/pptest/1b.jpg.html
    The LR3 image looks much more color saturated, among other things, but from what I remember, the NX2 image was much closer to how the scene looked when I was doing the shooting.
    Can someone help me understand why LR3 produces such a different default image from the NEF file than NX2?
    Thanks in advance!
    Community Member
    Nov 9, 2010 3:35 AM
    There were many posts about this in the past. So I took a look into Adobe's profiles for D700 (original and beta v2). I have some experience with this, because I made my own program for making dng profiles for some Canon cameras, that are not supported by Adobe. I noticed several things:
    First, in the lookup table of both versions of the profile, values for Value segment 0 (= total black) are a simple copy of segment 1 (=dark midtones). My opinion is that this approach is a bit oversimplified, resulting with big differences in dark tones between ACR and NX (oversaturated blue and orange/brown on your picture). Midtones and highlights are much better
    Obviously, points for total black can't be calibrated at all. What I did in my program was that I made calibration on very dark tones, and did some recalculation to aproximatelly match camera jpegs. It's not possible to get total match, but I came much closer
    Second, there is a difference in tone curve between original D700 profile and beta v2. Tone curve in the original profile has a "notch" in the lowest part, caused by the fact that blacks slider default value should be 5 (according to Adobe). On the beta v2 profile, bottom part of the tone curve is smooth and looks similar to what I got on my profiles with blacks slider set to 0. So I suppose that for this profile (and some other latest profiles), blacks should be set to 0.
    It would be nice to get some comment about this from Eric or Jeff
    I attached a printscreen from my program that can display a lookup table in the profile, and this is how Hue segment 0 (= red) looks like.
    On the left pane, there are value and saturation remapping points (in Photo Pro color space), and on the right, there are hue shifts
    Also, there is a tone curve on the left pane (displayed in 3 different scales)
1 2 3 Previous Next
Actions
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
