Sergey Landar Calculating status...
Error #1009: Cannot access a property or method of a null object reference.
Apr 13, 2010 6:16 AM
can anybody help please?
in output i have:
+++ Welcome screen +++
+++ Levels screen +++
>>> array: 0,0,1,1
>>> random numbers: 3
>>> random numbers: 2
>>> random numbers: 1
>>> random numbers: 0
****** Icons creationg finished ******
Level: 1 started
TypeError: Error #1009: Cannot access a property or method of a null object reference.
at MyMatching/stopwatch()[D:\#_Flash_Games\MatchingThings\MyMatching.as:70]
Icon 0 was clicked
Icon 0 was clicked
+ added 20 points because matching of 2 icons. Now player has: 20 points
--- deleted 2 icons ---
Icon 1 was clicked
Icon 1 was clicked
+ added 20 points because matching of 2 icons. Now player has: 40 points
+++ Gameover Screen +++
code:
package
import adobe.utils.CustomActions;
import flash.display.MovieClip;
import flash.events.MouseEvent;
import flash.text.TextField;
import flash.events.*;
import flash.utils.getTimer;
public class MyMatching extends MovieClip
public var xIconsContainer;//all icons start to draw from this x
public var yIconsContainer;//all icons start to draw from this y
private var iconsVertical=2;//icons columns
private var iconsHorizontal=2;//icons rows
private var firstIcon;//player click to first icon
private var secondIcon;//player click to second icon
private var deletedIcons:int = 0;//if firstIcon==secondIcon we will delete 2 icons
public var numberOfLevels:int = 2;//2 for 1 level; 4 for 1, 2 levels; 6 for 1, 2, 3 levels
public var startTime:int = getTimer();
public var timeString:String;
public var playerScoreSum:int = 0;//sum of all players points
public var iconsList:Icon;
public var iconsArray:Array;
public var iconWidth:int = 51;//width of icon
public var iconHeight:int = 51;//height of icon
public var levelNumber:int = 1;
public var matchPoints:int = 20;//if player match 2 icons we add 20 points to his playerScoreSum
public var missPoints:int = 1;//if miss we delete 1 points from playerScoreSum
//constructor
public function MyMatching()
welcomeScreen();
public function welcomeScreen():void
trace("+++ Welcome screen +++");
gotoAndStop('WelcomeScreen');
playBtn.addEventListener(MouseEvent.CLICK, goToLevels);
public function startingStopwatch():void
addEventListener(Event.ENTER_FRAME, stopwatch);
public function stopingStopwatch():void
removeEventListener(Event.ENTER_FRAME, stopwatch);
public function stopwatch(event:Event)
var timePassed:int = getTimer()-startTime;
var seconds:int = Math.floor(timePassed/1000);
var minutes:int = Math.floor(seconds/60);
seconds -= minutes*60;
timeString = minutes + ":" + String(seconds + 100).substr(1, 2);
stopwatchPreview.text = String(timeString);
public function goToLevels(event:MouseEvent)
xIconsContainer=stage.stageWidth/2 - (iconWidth*iconsHorizontal)/2;//all icons start to draw from this x
yIconsContainer=stage.stageHeight/2 - (iconHeight*iconsVertical)/2;//all icons start to draw from this y
startingStopwatch();
trace("+++ Levels screen +++");
iconsArray = new Array();//creating new object iconsArray
gotoAndStop('Levels');
for (var i:int; i < iconsVertical*iconsHorizontal/2; i++)
iconsArray.push(i);
iconsArray.push(i);
trace(">>> array: " + iconsArray);
for (var x:int = 0; x < iconsVertical; x++)
for (var y:int = 0; y < iconsHorizontal; y++)
iconsList = new Icon();
addChild(iconsList);
iconsList.buttonMode = true;//if we move cursor to icon we can see hand
iconsList.stop();//stoping our icons on Flash IDE, because on one layer we have all our icons
iconsList.x=x*iconWidth+xIconsContainer;
iconsList.y=y*iconHeight+yIconsContainer;
var myRandom:int=Math.floor(Math.random()*iconsArray.length);//creates a random number that will be related to an index of the array named "iconsArray"
//var showIcon;//cast as whatever type of element the array is holding
iconsList.showIcon=iconsArray[myRandom];//assigns the randomly selected element of iconsArray to the variable showIcon
iconsArray.splice(myRandom,1);//removes the randomly selected element (now showIcon) from the array (not the last one, the random one) //we use the splice command to remove number from the array so that it won’t be used again
//iconsList.gotoAndStop(iconsList.showIcon+2);//showIcon+2 would be the next frame in the timeline after the frame for the random item deleted, so that code is essentially moving in the timeline to the frame just after the frame for the item that was removed from the array
trace(">>> random numbers: " + myRandom);
iconsList.addEventListener(MouseEvent.CLICK, clickToIcon);
deletedIcons++;//when we draw icons we every time add +2 icons to our deletedIcons variable, in future we will deleted 2 icons from this variable if firstIcon==secondIcon
//added score to the sceen
trace("****** Icons creationg finished ******");
trace("Level: " + levelNumber + " started");
//levelNumberPreview.text = String(levelNumber);
public function clickToIcon(event:MouseEvent)
var thisIcon:Icon = (event.currentTarget as Icon);//what icon player clicked...
trace("Icon " + thisIcon.showIcon + " was clicked");//trace clicked icon to the output pannel
if (firstIcon==null)
firstIcon=thisIcon;
firstIcon.gotoAndStop(thisIcon.showIcon + 2);
else if (firstIcon == thisIcon)
firstIcon.gotoAndStop(1);
firstIcon=null;
else if (secondIcon==null)
secondIcon=thisIcon;
secondIcon.gotoAndStop(thisIcon.showIcon + 2);
if (firstIcon.showIcon==secondIcon.showIcon)
playerScoreSum += matchPoints;// add matchPoints for all existing player points
scoreGamePreview.text = String(playerScoreSum);
trace("+ added " + matchPoints + " points because matching of 2 icons. " + "Now player has: " + playerScoreSum + " points");
removeChild(firstIcon);
removeChild(secondIcon);
deletedIcons -= 2;
trace("--- deleted 2 icons ---");
if (deletedIcons == 0)
if (iconsVertical >= numberOfLevels)
iconsVertical = 2;
iconsHorizontal = 2;
levelNumber = 1;
MovieClip(root).playerScoreSum = playerScoreSum;
stopingStopwatch();
startTime = getTimer();
gotoAndStop('GameoverScreen');
trace("+++ Gameover Screen +++");
else
iconsVertical += 2;
iconsHorizontal += 2;
levelNumber += 1;
xIconsContainer+=2;
yIconsContainer+=2;
goToLevels(null);
else
playerScoreSum -= missPoints;// delite missPoints from all existing player points
trace("- deleted " + missPoints + " points because missing of 2 icons. " + "Now player has: " + playerScoreSum + " points");
else
secondIcon.gotoAndStop(1);
firstIcon = null;
secondIcon = null;
firstIcon=thisIcon;
Latest reply:
Kartik Mehta, Apr 14, 2010 9:11 PM
