Apr 19, 2010 10:12 AM
Error #2046: the loaded file did not have a valid signature
Like (0)
All of a sudden, I started getting this error this morning on my Flex 4 project. I get this even with a trivial "hello world" program. The weird(er) thing is, my projects are *not* configured for RSL linkage--framework linkage is set to "merge into code" (though changing to RSL linkage does not help). Flash Player version ins 10.0.15.3 Linux (Ubuntu 9.10). I'm using FB3 Linux Alpha 5 and Flex 4.0.0. I know that's not exactly a supported configuration, but it worked just fine yesterday (sans code hinting in the new MXML namespaces, but I could live with that). Any idea what's going on? Or how I can diagnose this?
For what it's worth, this also happens just using the command-line compiler. Is there a problem witht he Adobe-hosted RSLs? Also, it seems that the default config file is overriding my framework linkage settings. I'll try to tweak the config file itself and see if I get anywhere.
Ok, if anyone else runs into this, changing $FLEX_HOME/frameworks/flex-config.xml to statically linking RSLs seems to do the trick, but I'd still like to understand why the problem arose int he first place.
You may be missing a required library in your OS. The issue and how to build the required library are described in this bug:
http://bugs.adobe.com/jira/browse/SDK-15282
-Darrell
Thanks, but (1) I'm not convinced this is the issue as it started manifesting after some trivial changes, after my application had been working for a couple of weeks and (2) it's rather discouraging to see a comment like
FlashPlayer team mentioned that everyone who uses Flash on Linux needs to have libflashsupport.so on that system.
in the (closed) bug report. How can Linux Flash Player ship without this if everyone needs to have it?
Maybe a bit out of left field, but saw this answer elsewhere.Check your clock. On my computer was set to six months ago. Reset it to current time and problem fixed.
deleted
Copyright © 2011 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
