I've been running AIR & apps under linux for quite a number of months. One of my favourite applications is "tweetdeck" but since last week the app has core dumped when started, and even after a complete remove/cleanup/reinstall of AIR and all applications is now failing to install.
I'm unclear if this is an AIR problem or Tweetdeck, but it looks as if it might be system, library incompatability so probably AIR itself. Having said that some AIR apps are still working:
sh-4.0# ./Adobe\ AIR\ Application\ Installer ~/Download/TweetDeck_0_31.3.air
Application crashed with an unhandled SIGSEGV
Crashlog has been dumped in /tmp/airCrashLogs/1109_0938_F4htm8
It seems to me that this is rather an Adobe Air issue, since I'm experiencing a segfault when installing ipla lite. This is on pre-release Fedora 12 x86_64. Everything worked like charm in Fedora 11 x86_64 prior to the upgrade. I tried re-installing Adobe Air, but to no avail. I have attached the crash log the program produces.
I did also try using "strace" to see what AIR was up to when it fails. Looks as if it might relate to some encryption settings in /etc/opt/Adobe/certificates/crypt//config.xml
Also looking at the core file I can see (an excerpt)
/opt/Adobe AIR/Versions/1.0/libCore.so(+0x2ea3ba) [0xfd03ba]
/opt/Adobe AIR/Versions/1.0/libCore.so(+0x2de565) [0xfc4565]
[0xca940c]
/usr/lib/libxml2.so.2(xmlHasProp+0x27) [0x3b8cae7]
/usr/lib/libxml2.so.2(xmlGetProp+0x19) [0x3b8d5f9]
/usr/lib/libadobecertstore.so(+0xf345) [0x5aa345]
/usr/lib/libadobecertstore.so(+0xf7db) [0x5aa7db]
/usr/lib/libadobecertstore.so(AUCS_GetCertificateList+0x29) [0x5aa727]
/opt/Adobe AIR/Versions/1.0/libCore.so(+0x4a937c) [0x118f37c]
That worked!
Adobe AIR Application Installer.swf libCore.so
I/O warning : failed to load external entity "/etc/opt/Adobe/certificates/crypt//config.xml"
Unable to parse Document: /etc/opt/Adobe/certificates/crypt//config.xml.
So there's obviously some complaining about certificates, but tweetdeck is running.
Thanks for the quick helpful answer. Does this mean there's some breakage in the certificate checking (possibly after an update) or is this just cached/temporary data that needed to be cleared out?
Nigel.
It worked - i.e. both the installation, as well as the installed application itself. Adobe Air complained about missing files, though, but I guess that's expected:
$ "/usr/bin/Adobe AIR Application Installer"
Unfortunately, that got me back to square one: Adobe Air segfaults again.
The issue is still present with 1.5.3. The crypt directory rename still works the problem around.
After playing with aucm, I noticed that adding new certs added the <UserPreferences> tags when adding a new cert. The config.xml from the adobe-certs package did not have this tag. I added it to each certificate object in config.xml, for example:
<certificate trustAnchor="true" trusted="true" sslServerAuth="true" codeSign="true" >
<UserPreferences/>
<LastUpdatedBy trustAnchor="adobe" codeSign="adobe" sslServerAuth="adobe" trusted="adobe"/>
<subjectHash>2afc57aa.0</subjectHash>
<publicKeyHash>46tUTICh21ZDt5FKy/OCehNcCKt=</publicKeyHash>
</certificate>
That fixed all the SIGSEGV dumps. (And keeps you from getting all the unknown/unverified cert messages during application installation you get when you just rename the crypt directory.)
related to this:
I get the same issue, but that's because I am using the SDK adl tool to run the application.
So all I did was create a folder under /opt/AIR-apps/ for the application and I unziped the *.air file into a folder of its own.
Then I used the command line to run it and I get stuck on this error.
Should I do something extra to get these certificates 'installed'?
my /etc/opt/ folder is completely empty.
// Sal
I must be missing something.
You mean when one runs the application ... It should install these certs?
I looked for something with 'cert' in the qsin/ folder an found nothing. Is it because I am using this on Gentoo rather then Ubuntu or Fedora?
Should I have ran some other script after unpacking the SDK and putting it on /opt/AIR-SDK/ ? Sounds to me like that is what I missed?
Bottom line: What do I do to get these certs installed on that folder ?
Any help will be greatly appreciated!
Thank you!
For working with Certificates you would need to install AIR runtime on your machine, SDK is not enough. Please install the AIR runtime from: http://get.adobe.com/air/
I did try that, but because I'm using Sabayon (a gentoo derivative) It tells me that the Installer is not supported in Non rpm or debian bases distros.
So that's why I resorted to using the SDK. Which I can get to work for other Air apps, but not mine: qsin. This works fine in Fedora and Ubuntu.
So is there a work-around to the runtime in Gentoo/Sabayon? Any help will be appreciated.
// Sal
Copyright © 2012 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
