artboard background color
Apr 29, 2010 Apr 29, 2010
Can you make a background color in Illustrator like you can in photoshop?
181.0K
LEGEND , Apr 29, 2010 Apr 29, 2010
Or.....
Use the transparency settings in the Document set up and set both colors to the same thing and check "Simulate Colored Paper"
I generally use Larry's method though.
Adobe
Just by making a filled box the desired color. Put it on a layer by itself at the bottom of the layer stack and lock it.
Or.....
Oct 11, 2010 Oct 11, 2010
If you need to use the grid,
and therefore see it over the rectangle you are using as a background:
(Edit>Preferences>Guides&Grids) and uncheck "Grids in back".
Engaged ,
Jan 15, 2012 Jan 15, 2012
This does change your background but  the background color covers over all your other layers/objects. This means you really can't do any design if your art board is set to a black or too dark background. If you are doing web work, you can save for web as a .png and then open in Fireworks. Once in Fireworks, you can easliy change the background color. In fact, Fireworks is a much easier to to use  drawing tool then Ilustrator or Photoshop. If you have'nt tried FW,  give it a shot.
Jul 30, 2016 Jul 30, 2016
Hi, I tried your method and other methods on youtube. When I press ok, my backround color does not change it remains white. Would you know how to correct this?
Are you using the method I suggested or the one Scott made in post#2? The method I use will always work.
Aug 10, 2016 Aug 10, 2016
I had the same problem, I opened the "artboard options" from the artboard pallet and it seemed to instantly refresh and apply my color.
So, here's what worked for me:
  1. FILE > DOCUMENT SETUP > Check SIMULATE COLORED PAPER > Change top color to your desired color > Hit OK
  2. If the artboard does not change, open the artboard pallet > select your artboard > from the dropdown choose "ARTBOARD OPTIONS" - This should refresh/update the artboard to your desired color. > Hit OK or Cancel
But as mentioned above, it will just simulate a background color as if your artwork was printed on color paper. It will not cause that color to be printed as part of the artwork.
Sep 25, 2016 Sep 25, 2016
So I can get it to work this way. But what I am wanting to do is have a colored background with text on top, and the background color be a part of my final design. How can I achieve that ?
Please show something.
