RE: "Unable to create font" After Effects CS 5 won't launch
May 1, 2010 7:16 AM
My spanking new After Effects CS5 won't launch due to "Unable to create font" error.
I'm running OS X 10.6.3 on a 17" with specs listed below.
After Effects CS3 is running fine. What's the solution?
Model Name: MacBook Pro
  Model Identifier: MacBookPro5,2
  Processor Name: Intel Core 2 Duo
  Processor Speed: 3.06 GHz
  Number Of Processors: 1
  Total Number Of Cores: 2
  L2 Cache: 6 MB
  Memory: 8 GB
  Bus Speed: 1.07 GHz
  Boot ROM Version: MBP52.008E.B05
  SMC Version (system): 1.42f4
  Serial Number (system): W89400R18YB
  Hardware UUID: E2300327-D5D3-5DC2-85CF-9FFA9CEAD9ED
  Sudden Motion Sensor:
  State: Enabled
    May 1, 2010 8:07 AM   in reply to billsantry
    Start with the solutions listed here:
    http://aeerrors.myleniumstuff.de/?p=482
    May 1, 2010 4:47 PM   in reply to billsantry
    Same for me, I'm trying a lot of things but nothing work – I keep checking and let you know If I've got a solution
    May 3, 2010 8:14 AM   in reply to Maherso
    There are 3 possible issues on the system. A corrupt font, a corrupt Adobe font list and/or a corrupt system font database.
    Try the following:
    1) On the Mac, delete all copies of the AdobeFnt.lst on the system. They will have a name like AdobeFnt10.lst, AdobeFnt11.lst, etc.. On the Mac this will be found in the /Library/Application  Support/Adobe/PDFL/9.0/Fonts folder.
    2) Then restart the system holding down the S key while the system is starting up for Safe Mode. That will reset the system database.
    On Windows,
    1) search and delete the AdobeFnt.lst files found in C:\Program Files\Common  Files\Adobe\PDFL\...,
    2) restart the system.
    May 3, 2010 8:44 AM   in reply to Will Lockwood
    Hi Will,
    I did all that but nothing fixed the problems. Finally, I'm suspecting a corrupted drive. When I fix the drive with fsck command it gets corrupted after each system launch. I plan to clone my system on another drive, boot from the new one, check if everything is ok. I let you know.
    May 3, 2010 8:49 AM   in reply to Maherso
    Bummer. Sorry to hear that. Let us know how this works out.
    Mar 3, 2012 12:59 AM   in reply to billsantry
    Finally I found the solution, I don't know if it's gonna work for you, but you should give it a try. After hours of troubleshooting, I found that a missing Verdana Fonts (version 1.0 from Microsoft) is causing the problem. Just put Verdana in YourHardDrive/Library/Fonts and AfterEffects CS5 should start normally. It would be cool to have a better dialog box like "Unable to create font - please locate and Install Verdana".
    For your convenience, you can download Verdana here : [removed by moderator, since Verdana is not a freely distributable font]
    Enjoy
    May 3, 2010 12:00 PM   in reply to Maherso
    Hi Will
    I posted a solution that works for me.
    May 11, 2010 4:17 AM   in reply to Maherso
    After Effects Warning Unable To Create Font
    @Maherso
    Thanks that works perfect.
    Verdana, Typeface and data © 1996 Microsoft Corporation. All Rights Reserved Version 2.45 - Thursday, 8 April 2004 08:00
    May 11, 2010 4:35 PM   in reply to Maherso
    your link to the font is gone. (sigh).
    could you reupload, please?
    Mar 3, 2012 2:12 AM   in reply to karolus ka
    Hi Karolus,
    The link is now working, enjoy...
    [removed by moderator]
    Jun 19, 2010 6:51 AM   in reply to Maherso
    Worked the first time! Thanks for the link too!
    Jun 29, 2010 1:01 PM   in reply to billsantry
    You can buy Verdana font from Microsoft site for 30$ (aamof from Ascender Corporation). It's not legal to download it from above links (unless this guy have license for sharing this font, and I doubt about that). It is laughing because after you spend 999$ for a software, you have to pay 30$ more for the fonts. Did Adobe have no money for licensing this font?
    Jun 29, 2010 3:18 PM   in reply to Mac0SX
    Oooops, I was sure Verdana was free. Sorry folks, you'll have to buy that font or find it in another way (try installing Office 2008 trial...). We live in a strange world full of contradictions.
    Sep 10, 2010 12:55 AM   in reply to Will Lockwood
    I tried this soln ..and it's worked finally
    Sep 10, 2010 8:47 AM   in reply to jackie.vishwakarma
    The After Effects CS5 (10.0.1) update should fix this problem.
    Oct 28, 2010 7:28 AM   in reply to Todd_Kopriva
    For me the Adobe update *DID NOT* fix this but copying over and activating the Veranda family of fonts from my MBP that had Office on it, did - kind of a sorry situation if this is what's actually needed to fix it but at least there is a way.
    Jan 31, 2011 8:01 AM   in reply to billsantry
    I had the same problem. Also after updating AE. But this worked for me:
    Activate the verdana font in your system Fontbook (dutch: Lettertypecatalogus).
    (Suitcase Fusion 3 turned it off)
    Grtz,
    Code d'Azur
    Feb 24, 2011 12:46 PM   in reply to billsantry
    The Verdana trick worked for me too. AE’s type engine fails if there isn’t a font at /Library/Fonts/Verdana.ttf —common, simple programming problem. Mahalo for posting all this, guys!
    Mar 21, 2011 6:40 PM   in reply to Todd_Kopriva
    And a March 2011 download of the Master Collection & update to 10.0.1 (everything that updates) reveals that the same issue still exists. Installing Verdana "fixes" it. <font family="Verdana">Idiots.</font>
    Apr 8, 2011 8:00 AM   in reply to Maherso
    Thank you!!! This totally worked for me!!
    Apr 11, 2011 11:32 PM   in reply to Maherso
    Just want to add that this worked for me. But it didn't at first. I moved Verdana to the right place but it did not work. The problem was that you need all the files. I had them all but not "Verdana Italic.ttf" for som reason. I had to get that from a disc and then it worked. So make sure you get them all to /Library/Fonts/.
    Verdana Bold Italic.ttf
    Verdana Bold.ttf
    Verdana Italic.ttf
    Verdana.ttf
    Apr 25, 2011 7:05 AM   in reply to billsantry
    Worked for me (I ended up adding all the Verdana affiliates as well....bold..italic..etc)
    Such a relief, as I had already gone through a reinstall, and several other troubleshooting workarounds...
    thanks!!!
    jon
    Jun 7, 2011 8:30 AM   in reply to billsantry
    I'm running OSX 10.6.7 and started getting this error after validating my fonts & resolving duplicates in Font Book. Verdana was still installed on my machine (worked in Photoshop & Illustrator), but for some reason After Effects wasn't able to locate it, hence "Unable to create font."
    What worked was re-installing Verdana, which caused another duplicate. Oh well, at least it works again.
    Jun 7, 2011 10:27 AM   in reply to iamshaun
    It's important that you install the specific version of Verdana that comes with AE… probably something to do with its ID #… sounds like you got it figured out!!
    All contents are confidential. Delete if you are not the intended recipient.
    Jun 7, 2011 10:28 AM   in reply to thinkingmanhawaii
    Yep, got it going. Thanks man!
    Aug 5, 2011 4:37 AM   in reply to iamshaun
    Thanks guys
    Nov 3, 2011 3:21 AM   in reply to billsantry
    had the same problem but solved in a little different way since I have no Administrator privileges. I use Fontexplorer to manage my fonts instead of Fontbook. I've found in it multiple versions of Verdana font . I removed everything but system Verdana, now everything works.
    Lorenzo
    Nov 21, 2011 11:06 AM   in reply to Todd_Kopriva
    I updated to the current after effects and I am still getting this problem. I have homework to finish today. Please help! :-)
    Nov 21, 2011 11:15 AM   in reply to suz56
    I went into type book and activated verdana in computer and inactivated verdana in user. It worked.
    Dec 7, 2011 6:47 AM   in reply to Maherso
    And now for something completely different:
    I was having this problem and I went to the Fonts folder and saw that Verdana was there!  Just for giggles, I went ahead and dragged the font out of the folder and, yes, After Effects worked just fine for me afterwards!
    I'm running a 2.66 GHz Intel Core 2 Duo iMac on 10.6.8, but this problem also reared its ugly head when I was running 10.5.
    Feb 17, 2012 3:49 PM   in reply to billsantry
    May 8, 2012 9:25 AM   in reply to billsantry
    I have encountered the same problem on OSX 10.7.3 and I searched for Verdana in the FontBook to find that it was only disabled. Try this first; all you may need to do is enable the font family.
    I hope this is helpfull and nobody needs to spend 30$ to fix this error.
