hi, ive downloaded the trial of Photoshop Cs5 but it wont install, i get to about 10% in the install and then i get "Exit Code: 6".
ill begin with my system specs:
(Swedish language) Windows 7 Ultimate 64-bit
Intel Core 2 Duo E6600 @ 2.40GHz 2.39GHz
4GB Ram
Ati Radeon x1950xTx
Asus P5B deluxe motherboard
1680x1050 Acer P223w screen.
i've cleaned my regestry for problems with "Glarysoft Regestry repair", disabled my ESET NOD32 anti-vir, ran the setup as Administrator, choose to install as trial but i get to about 10% and i get Exit Code: 6.
this is what the log file said:
Exit Code: 6
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 58 error(s), 58 warning(s)
WARNING: OS requirements not met for {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}
WARNING: OS requirements not met for {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E}
WARNING: Payload cannot be installed due to dependent operation failure
ERROR: The following payload errors were found during install:
ERROR: - Adobe CSXS Infrastructure CS5: Install failed
ERROR: - Microsoft_VC90_ATL_x86: Install failed
ERROR: - Adobe Media Player: Install failed
ERROR: - Adobe Linguistics CS5 x64: Install failed
ERROR: - Adobe Photoshop CS5 Support: Install failed
ERROR: - Adobe Bridge CS5: Install failed
ERROR: - Microsoft_VC80_ATL_x86: Install failed
ERROR: - Recommended Common Fonts Installation x64: Install failed
ERROR: - AdobePDFL x64 CS5: Install failed
ERROR: - DeviceCentral_DeviceCentral3LP-en_GB: Install failed
ERROR: - Microsoft_VC80_MFCLOC_x86_x64: Install failed
ERROR: - Adobe XMP Panels CS5: Install failed
ERROR: - Photoshop Camera Raw: Install failed
ERROR: - AdobeColorCommonSetCMYK: Install failed
ERROR: - Adobe Mini Bridge CS5: Install failed
ERROR: - Microsoft_VC80_CRT_x86_x64: Install failed
ERROR: - AdobeColorJA CS5: Install failed
ERROR: - Adobe ReviewPanel CS5: Install failed
ERROR: - Photoshop Camera Raw (64 bit): Install failed
ERROR: - Microsoft_VC90_MFC_x86: Install failed
ERROR: - Adobe Photoshop CS5 Core_x64: Failed due to Language Pack installation failure
ERROR: - Suite Shared Configuration CS5: Install failed
ERROR: - Adobe Linguistics CS5: Install failed
ERROR: - PDF Settings CS5: Install failed
ERROR: - DeviceCentral: Failed due to Language Pack installation failure
ERROR: - AdobeTypeSupport CS5: Install failed
ERROR: - AdobeColorVideoProfilesCS CS5: Install failed
ERROR: - AdobeColorCommonSetRGB: Install failed
ERROR: - Adobe Player for Embedding x64: Install failed
ERROR: - Adobe Photoshop CS5 Core: Failed due to Language Pack installation failure
ERROR: - Required Common Fonts Installation x64: Install failed
ERROR: - Microsoft_VC90_ATL_x86_x64: Install failed
ERROR: - Adobe Photoshop CS5 International English Language Pack_AdobePhotoshop12-en_GB: Install failed
ERROR: - Adobe CSXS Extensions CS5: Install failed
ERROR: - Microsoft_VC80_ATL_x86_x64: Install failed
ERROR: - AdobeOutputModule: Install failed
ERROR: - Microsoft_VC80_CRT_x86: Install failed
ERROR: - AdobeCMaps x64 CS5: Install failed
ERROR: - AdobeTypeSupport x64 CS5: Install failed
ERROR: - Microsoft_VC90_MFC_x86_x64: Install failed
ERROR: - Adobe Photoshop CS5 International English Language Pack_x64_AdobePhotoshop12-en_GB_x64: Install failed
ERROR: - Adobe WinSoft Linguistics Plugin CS5: Install failed
ERROR: - Adobe WinSoft Linguistics Plugin CS5 x64: Install failed
ERROR: - AdobeColorEU CS5: Install failed
ERROR: - AdobePDFL CS5: Install failed
ERROR: - AdobeCMaps CS5: Install failed
ERROR: - AdobeColorNA CS5: Install failed
ERROR: - Microsoft_VC80_MFC_x86_x64: Install failed
ERROR: - Required Common Fonts Installation: Install failed
ERROR: - Adobe SwitchBoard 2.0: Install failed
ERROR: - Microsoft_VC80_MFC_x86: Install failed
ERROR: - AdobeColorPhotoshop CS5: Install failed
ERROR: - Microsoft_VC80_MFCLOC_x86: Install failed
ERROR: - Recommended Common Fonts Installation: Install failed
ERROR: - Adobe Extension Manager CS5: Install failed
ERROR: - Adobe ExtendScript Toolkit CS5: Install failed
ERROR: - Adobe AIR: Install failed
Help would be much appriciated
/Andreas
Can you try downloading the installer again and see if that fixes it? These errors suggest expected files are missing in the installer.
Barry
jabloomf1230 wrote:
"This error is showing up for a lot of people with Windows 7 x64. Basically, the setup program can't find the payloads (the files used to install the various components). It doesn't matter whether you have a fresh install or whether you log on with a "true" administrator account. The setup is broken and Adobe needs to fix it. The same problem occurs with AE CS5 and PPro CS5 and it doesn't matter whether you install as a trial or an upgrade either..."
jabloomf1230 wrote this in an other thread, about Cs5 master collection Exit code: 7. but it should be pretty close, the errormessages i get in the log is "setup program can't find the payloads". so, it may be the installer/setup thats "broken" (or should i call it "non-compatible" with my (swedish) version of Win 7 64-bit?). i will try to re-download the installer again, dosent that work, well, ive probably will do a reinstall of the system to 32-bit win 7, if that dosent work, i have to go back to vista
but ill post here if i find a solution of the problem, and how i did if so.
/andreas
Exit code 7 message is because of another reason.In your case installation is failing because it cannot find payloads to install.Please try to download again once and install,If it is still fails then it is something worth being concerned about. Thanks for bringing in light the severity of this issue as many other are facing it too.
well, as i thought, it failed again
as requested, heres the install log from the install http://rapidshare.com/files/382400976/Photoshop_CS5_Install_logg.rar.html
hope we can reach a solution, i will reinstall my system to 32-bit, as said, if that dosent work, i will downgrade to vista
Thanks for the logs Andreas.Can you try couple of things:
1) Try to run the msi installer directly from this location:C:\Users\Andreas\Desktop\Adobe CS5\Photoshop\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\
and report if you see any error message or if the install is successfull. Your installer failed while installing this component. In case it installs then run the Photoshop installer again and report what you observe.
2) In case it fails, try creating another User account and then Run the Photoshop Installer again from there.
Hope it resolves this issue.
I am having the same issue as well on my laptop. I have a Core2Duo CPU. I get exit code 6 and none of the 64 bit programs will install.
CPU: Core2Duo T5550 1.83
RAM: 3GB
OS: WINDOWS 7 ULTIMATE
HD: 500GB
Nvidia 8m Graphics Card
Its a Dell XPS M1530
Can you please share your logs too from the same location listed above.
1) i ran the msi installer, worked fine, no errors and was installed correctly. i began to install photoshop again, no luck though, same Exit Code
2) i created a new user (with admin rights), but no luck there either, Exit Code 6.
just an small idea i came up with as u wrote that i should run the msi installer, maybye i should try to install all the Msi installers manually?
/andreas
I just downloaded and installed ps cs5 trial with no problems. I didn't use the downloader. I downloaded the 2 files and placed them on the desktop in a folder. Then open the folder and look for the .exe file. Right click on that, choose properties, then under the general tab you want to unlock it. Hit apply, then go to the compatibility tab, check the run as admin so the installer will be given full rights.
After I did this my computer told me that it needed to reboot (not sure why) so I did. Then I went back to the folder, clicked on the .exe file. It proceded to make a folder on my desktopcalled photoshop and unpacked everything there. After it was finished I went to the photoshop folder and opened it. I right clicked on the .exe file, choose properties, went to the general tab and unlocked that, then went to the compatibility tab and checked run as Admin, hit apply then close out. This again gives the software .exe full rights.
I then clicked on the .exe file in the photoshop folder and went thru the install screens. I did a custom install anddid not insall AIR or the movie reader. The install went perfect. After install I rebooted. Before running the software I went to start and all programs right clicked on both 32 bit and 64 bit, choose properties, compatibility, and checked run as Admin so the software itself will have full right7 s.
With Vista and Windows everything has to be installed as Admin, Being Admin and installing software as admin are two different things.
Looking at your post it seems you do not have the permission levels granted. This will help you.
The issue with me at least is that i can install all 32bit versions but not the 64bit.
Exit Code: 6
- 0 fatal error(s), 53 error(s), 57 warning(s)
WARNING: OS requirements not met for {288DB08D-0708-4A94-B055-55B99E39EB62}
WARNING: OS requirements not met for {33A3F995-8333-4676-8D6F-AB7674BB52EA}
WARNING: OS requirements not met for {694213D7-1E0E-4C8F-B822-E2E3680C0FCE}
WARNING: OS requirements not met for {AAE6F374-91CB-45FB-9282-4CFA0DED2088}
WARNING: OS requirements not met for {C21384F7-1A36-4706-95AB-B09BCE3C144F}
WARNING: OS requirements not met for {DA1B174B-4297-467C-9EF8-0AB8D4D5171E}
ERROR: - SiteCatalyst NetAverages: Install failed
ERROR: - Adobe After Effects CS5 Third Party RoyaltyContent Wrapper: Install failed
ERROR: - Adobe Premiere Pro CS5 Third Party Content Wrapper: Install failed
ERROR: - Adobe Premiere Pro CS5_AdobePremierePro5en_USLanguagePack: Install failed
ERROR: - AdobeHelp: Install failed
ERROR: - Adobe After Effects CS5 Third Party Content Wrapper: Install failed
ERROR: - Adobe Photoshop CS5 English Language Pack_x64_AdobePhotoshop12-en_US_x64: Install failed
ERROR: - Adobe BrowserLab CS Live: Install failed
ERROR: - Adobe After Effects CS5 Support: Install failed
ERROR: - CSXS Story Extension: Install failed
ERROR: - Adobe Media Encoder CS5 X64: Install failed
ERROR: - Adobe After Effects CS5_AdobeAfterEffects10en_USLanguagePack: Install failed
ERROR: - Adobe Premiere Pro CS5 Third Party Royalty Content Wrapper: Install failed
ERROR: - DeviceCentral: Install failed
ERROR: - Adobe Media Encoder CS5 PCI WRAPPER X64: Install failed
ERROR: - AdobeColorVideoProfilesAE CS5: Install failed
ERROR: - Adobe Premiere Pro CS5: Failed due to Language Pack installation failure
ERROR: - Adobe After Effects CS5 Presets: Install failed
ERROR: - AmericanEnglishSpeechAnalysisModels: Install failed
ERROR: - Pixel Bender Toolkit: Install failed
ERROR: - Adobe After Effects CS5: Failed due to Language Pack installation failure
ERROR: - AdobeMotionPicture CS5: Install failed
ERROR: - Adobe Premiere Pro CS5 Support: Install failed
ERROR: - Adobe Media Encoder CS5 Dolby WRAPPER X64: Install failed
In case the installation results in same error code after re downloading and installing as suggested by Barry then please share logs kept at:ProgramFiles(x86)/Common Files/Adobe/Installer/Adobe Photoshop Cs5 logs.
I've tried to install all the msi installers manually, a longshot that didnt work.
i tried your approach to it Dec9, but without any luck.
i have tried to strip it down to just photoshop (deselecting all the extensions etc.) but also that didnt work.
so, i will back evrything up on my computer, reinstall to 32-bit, and hopefully by monday i will have a computer that is running.
vista will be my last way out
/andreas, without any luck installing stuff today.
I noticed in your bug report that it reads international english. If you live in the USA you have to select North American.
im swedish, so thats why i chose international but i have no idea if north american language works now, althrough, it didnt at first.
I live in USA and I used North America. So that doesnt help.. argh. Could it be a Core 2 Duo thing that Adobe doesnt recognize as a 64 bit chip?
Go to help, system information. If PS CS5 sees a 64 bit processor then it will be listed.
Andreas,
May be I have to look in your system in order to narrow down the issue , will it be ok with you to setup a remote session. Rest of the details I can share with you on email if you agree.
Regards
Anshum
I also tried running the setup as administrator and exact error still so remote
session would be fine when you are available?
I agree, let me know when
Anshum Arora wrote:
Andreas,
Regards
Anshum
if that could work im up to it, there may be a small issue over timezones as sweden is GMT +1. but send the details to my mail, ill PM it to you now.
/Andreas
Sounds good, let me know when
I am trying to install CS5 Upgrade on Windows Vista 32 Bit and getting the same
errors
UAC is off
Virus is off
Firewall is off
booted to safe mode
tried running setup as administrator
Seems like no0 matter what I have tried it is same error every time and its at about 12%
Here is log file
Exit Code: 6
- 0 fatal error(s), 43 error(s), 41 warning(s)
WARNING: The payload: Adobe Photoshop CS5 Core {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E} requires a UI parent with following specification:
Family: Photoshop
ProductName: Adobe Photoshop CS5 Core_x64
This parent relationship is not satisfied, because this payload is not present in this session.
ERROR: - Microsoft_VC90_CRT_x86: Install failed
ERROR: - DeviceCentral_DeviceCentral3LP-en_US: Install failed
ERROR: - Adobe Photoshop CS5 English Language Pack_AdobePhotoshop12-en_US: Install failed
ERROR: - AdobeJRE: Install failed
@ artdecorportraits : dec9 suggested a good way to continue with installation. Can you try to do same i.e Rebooting your system then giving full Admin rights to installer and then try install Photoshop. Logging remotely into one of the machines will help narrow down the root cause for this issue and the solution will be available for all to follow.
Also, share the complete log file kept at ProgramFiles/CommonFile/Adobe/Installer/Adobe Photoshop CS5.log
