Stephen Starkman
CS5 Crashes on Quit
May 2, 2010 2:36 PM
Has anyone else seen this and found a solution?
Installed CS5 Standard, OS 10.6.3, MacBook Pro 4,1
When first installed, I could not change prefs - as discussed in thread:
http://forums.adobe.com/thread/628368?tstart=0
I manually changed permissions. CS 5 will now launch and operate. When choosing "Quit" CS5 closes all windows normally, however the menu bar does remains and the spinning beachball displays. After about 20 seconds Mac OS reports that Photoshop quit unexpectedly. A minute later Adobe's crash reporter appears.
I've uninstalled and re-installed.
Stephen
    Adobe Employee
    May 2, 2010 3:46 PM
    Send in the crash report with details (what did during the session, what troubleshooting you might have done, etc.).
    I'm looking at all the crash reports.
    Adobe Employee
    May 2, 2010 4:05 PM
    Without seeing your exact report, I'm going to guess that it's a crash in ServiceManager because of bad permissions on a different folder. (we've got several crashes because of that)
    Adobe Employee
    May 2, 2010 4:27 PM
    Also check /Library/ApplicationSupport
    I'm still trying to get details from the ServiceManager team as they investigate the crash reports.
    Community Member
    May 2, 2010 6:45 PM
    hi, i changed the permissions with the finder but it didn't work on all the nested files for some reason..i fixed it with batchmod.app which you can find on versiontracker or macupdate (i'll assume i shouldn't post a link). i fixed the user/library/permissions folder and the user/application support folder
    Community Member
    May 4, 2010 7:12 AM
    I tried the Uninstall/Install Temp Account User method, but it did not work for me. CS5 Photoshop still crashes/hangs on quit. Any other suggestions?
    Thank you,
    -Doren
    Adobe Employee
    May 4, 2010 10:22 PM
    No more suggestions right now.  Folder permissions is the one cause we know about.
    I'm still looking at all the crash reports for more clues.
    I've managed to reproduce one other crash on quit myself - but it's one that very few people have reported.
    But we've got several people looking into these issues.
    Community Member
    May 4, 2010 10:36 PM
    I am getting this also
    macpro 2x2.8 quad core 14gb memory osx10.6.3
    Community Member
    May 10, 2010 2:20 PM
    I had the same issues, changed the permissions as mentioned here:
    I've changed permissions on the following folders (added myself as owner, read and write privs)
    Application Folder:
    Adobe Bridge CS5 (folder)
    Adobe Device Central CS5 (folder)
    Adobe Extension Manager CS5 (folder)
    Adobe Photoshop CS5 (folder)
    User/Library/Preferences folder:
    Adobe (folder)
    Adobe Photoshop CS5 Settings (folder)
    User/Library/Application Support Folder:
    Adobe (folder)
    Still had crashes on Illustrator...
    Solution: Change the permissions in the ~/Library/Application Support/Adobe/CS5ServiceManager as well.
    I don't know why, but you must change the permissions separatly, it does not work setting the permissions on the CS5ServiceManager and set them directly to all subfolders
    Community Member
    May 10, 2010 7:47 PM
    THIS old cowboy needs some pointers to information on PERMISSIONS and other changes suggested here that could expect to be necessary if this were a Microsoft product. You know, crashes with no good reason on a PC where it shouldn't be used.
    Where do I find and how do I use the various technical nostrums suggested? Permissions and the other places we're being sent with no help? CS5 Service Manager? What's that? Where is the badly needed information on installation problems?
    I'm running CS4 Design Premium and have now loaded -- from purchased Adobe discs! -- CS5 Design Premium on my 17" MacBookPro using 10.5.8 because of the problems with Snow Leopard.
    All was running fine on CS4 so while this gets sorted out, I guess it will be necessary to go back to CS4 so I can get some work done to pay for this lost time.
    Bill Eger
    Community Member
    May 10, 2010 7:50 PM
    Last Adobe employee note here was written on May 4. This is May 10 and seems to be very little to help those of us who have bought this upgrade. Where do we file for a refund?
    Community Member
    May 14, 2010 4:56 PM
    I had all these same problems. Spent HOURS on the phone with Adobe tech support today, and I am very upset that they did not inform me that this is a known issue! They had me uninstalling and installing numerous times. I repaired all permissions system-wide, changed all relevant Adobe permissions, and then I was able to save a preset. But the program still crashed on quit. It ran fine via an alternate user.
    So I checked here, and what DID work for me, thanks to the notes posted, was to uninstall, log in as a test user, reinstall via test user (I still changed permissions again to read/write for everyone); log out of test; log in as main user. It works!
    I wish I had known to do this this morning; it would have saved me the whole day. At one point, I was on hold more than 40 minutes -- after talking with someone and waiting to be transferred to a "Photoshop specialist." I finally hung up in desperation. Eventually the tech person told me it is an "Apple problem, not an Adobe problem."
    Chris, my Incident # is 181590512. If you send me an email, I will gladly send you a crash report.
    Thanks to whoever came up with the above solution!
    Community Member
    May 14, 2010 7:06 PM
    I seem to have the same problems with permissions.  I activated the root accounrt and installed from there, but I have permission problems and crashes on exit unless I also run from the root account.  My regular account also has admin permissions.
    New install, running 10.6.3 on a MacBook Pro.  Here is my crash log:
    Process:         Adobe Photoshop CS5 [3484]
    Path:            /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/MacOS/Adobe Photoshop CS5
    Identifier:      com.adobe.Photoshop
    Version:         12.0 (12.0x20100407.r.1103) (12.0)
    Code Type:       X86-64 (Native)
    Parent Process:  launchd [3042]
    Date/Time:       2010-05-14 17:56:40.439 -0700
    OS Version:      Mac OS X 10.6.3 (10D573)
    Report Version:  6
    Interval Since Last Report:          252742 sec
    Crashes Since Last Report:           13
    Per-App Interval Since Last Report:  7827 sec
    Per-App Crashes Since Last Report:   7
    Anonymous UUID:                      8A7919A9-74FE-4C5C-AFC2-897EFF689A72
    Exception Type:  EXC_CRASH (SIGABRT)
    Exception Codes: 0x0000000000000000, 0x0000000000000000
    Crashed Thread:  5
    Application Specific Information:
    abort() called
    Thread 0:  Dispatch queue: com.apple.main-thread
    0   libSystem.B.dylib                 0x00007fff84acc316 __semwait_signal + 10
    1   libSystem.B.dylib                 0x00007fff84ad0131 _pthread_cond_wait + 1286
    2   ServiceManager-Launcher.dylib     0x0000000119b2e735 Invoke + 57527
    3   ServiceManager-Launcher.dylib     0x0000000119b2d85b Invoke + 53725
    4   ServiceManager-Launcher.dylib     0x0000000119b2741a Invoke + 28060
    5   ServiceManager-Launcher.dylib     0x0000000119b2d635 Invoke + 53175
    6   ServiceManager-Launcher.dylib     0x0000000119b1eca4 Login + 9698
    7   ServiceManager-Launcher.dylib     0x0000000119b1ece2 Login + 9760
    8   ServiceManager-Launcher.dylib     0x0000000119b21e0f Invoke + 6033
    9   ServiceManager-Launcher.dylib     0x0000000119b1cb19 Login + 1111
    10  ServiceManager-Launcher.dylib     0x0000000119b1c73c Login + 122
    11  libSystem.B.dylib                 0x00007fff84aa3c58 __cxa_finalize + 203
    12  libSystem.B.dylib                 0x00007fff84aa3b70 exit + 18
    13  com.adobe.Photoshop               0x0000000100002eab 0x100000000 + 11947
    Thread 1:  Dispatch queue: com.apple.libdispatch-manager
    0   libSystem.B.dylib                 0x00007fff84aaa4ea kevent + 10
    1   libSystem.B.dylib                 0x00007fff84aac3bd _dispatch_mgr_invoke + 154
    2   libSystem.B.dylib                 0x00007fff84aac094 _dispatch_queue_invoke + 185
    3   libSystem.B.dylib                 0x00007fff84aabbbe _dispatch_worker_thread2 + 252
    4   libSystem.B.dylib                 0x00007fff84aab4e8 _pthread_wqthread + 353
    5   libSystem.B.dylib                 0x00007fff84aab385 start_wqthread + 13
    Thread 2:
    2   com.adobe.amt.services            0x000000010907cc53 AMTConditionLock::LockWhenCondition(int) + 37
    3   com.adobe.amt.services            0x0000000109075cce _AMTThreadedPCDService::PCDThreadWorker(_AMTThreadedPCDService*) + 92
    4   com.adobe.amt.services            0x000000010907ccbe AMTThread::Worker(void*) + 28
    5   libSystem.B.dylib                 0x00007fff84aca8b6 _pthread_start + 331
    6   libSystem.B.dylib                 0x00007fff84aca769 thread_start + 13
    Thread 3:
    0   libSystem.B.dylib                 0x00007fff84a9175a mach_msg_trap + 10
    1   libSystem.B.dylib                 0x00007fff84a91dcd mach_msg + 59
    2   com.apple.CoreFoundation          0x00007fff827c6452 __CFRunLoopRun + 1698
    3   com.apple.CoreFoundation          0x00007fff827c58df CFRunLoopRunSpecific + 575
    4   com.apple.CoreMediaIOServices     0x00007fff86a3f637 MIO::DAL::RunLoop::OwnThread(void*) + 147
    5   com.apple.CoreMediaIOServices     0x00007fff86a41202 CAPThread::Entry(CAPThread*) + 140
    6   libSystem.B.dylib                 0x00007fff84aca8b6 _pthread_start + 331
    7   libSystem.B.dylib                 0x00007fff84aca769 thread_start + 13
    Thread 4:
    0   libSystem.B.dylib                 0x00007fff84a917a2 semaphore_wait_signal_trap + 10
    1   libSystem.B.dylib                 0x00007fff84a96ced pthread_mutex_lock + 469
    2   ServiceManager-Launcher.dylib     0x0000000119b2d811 Invoke + 53651
    3   ServiceManager-Launcher.dylib     0x0000000119b277c6 Invoke + 29000
    4   ServiceManager-Launcher.dylib     0x0000000119b277e3 Invoke + 29029
    5   ServiceManager-Launcher.dylib     0x0000000119b275a0 Invoke + 28450
    6   ServiceManager-Launcher.dylib     0x0000000119b2a49f Invoke + 40481
    7   ServiceManager-Launcher.dylib     0x0000000119b1f137 Login + 10869
    8   ServiceManager-Launcher.dylib     0x0000000119b1ccc4 Login + 1538
    9   ServiceManager-Launcher.dylib     0x0000000119b1e265 Login + 7075
    10  ServiceManager-Launcher.dylib     0x0000000119b2b2a8 Invoke + 44074
    11  ServiceManager-Launcher.dylib     0x0000000119b2d6c1 Invoke + 53315
    12  libSystem.B.dylib                 0x00007fff84aca8b6 _pthread_start + 331
    13  libSystem.B.dylib                 0x00007fff84aca769 thread_start + 13
    Thread 5 Crashed:
    0   libSystem.B.dylib                 0x00007fff84b608c9 usleep$NOCANCEL + 0
    1   libSystem.B.dylib                 0x00007fff84b7feb8 abort + 93
    2   libstdc++.6.dylib                 0x00007fff889e65d2 __tcf_0 + 0
    3   libstdc++.6.dylib                 0x00007fff889e4ae1 __cxxabiv1::__terminate(void (*)()) + 11
    4   libstdc++.6.dylib                 0x00007fff889e4b16 __cxxabiv1::__unexpected(void (*)()) + 0
    5   libstdc++.6.dylib                 0x00007fff889e4fd6 std::bad_cast::what() const + 0
    6   ServiceManager-Launcher.dylib     0x0000000119b24f15 Invoke + 18583
    7   ServiceManager-Launcher.dylib     0x0000000119b24e15 Invoke + 18327
    8   ServiceManager-Launcher.dylib     0x0000000119b2c8fd Invoke + 49791
    9   ServiceManager-Launcher.dylib     0x0000000119b2cd23 Invoke + 50853
    10  ServiceManager-Launcher.dylib     0x0000000119b2c974 Invoke + 49910
    11  ServiceManager-Launcher.dylib     0x0000000119b2dfde Invoke + 55648
    12  ServiceManager-Launcher.dylib     0x0000000119b2e06e Invoke + 55792
    13  ServiceManager-Launcher.dylib     0x0000000119b2a8f7 Invoke + 41593
    14  ServiceManager-Launcher.dylib     0x0000000119b2aac2 Invoke + 42052
    15  ServiceManager-Launcher.dylib     0x0000000119b2aaf4 Invoke + 42102
    16  ServiceManager-Launcher.dylib     0x0000000119b2ab49 Invoke + 42187
    17  ServiceManager-Launcher.dylib     0x0000000119b2ad71 Invoke + 42739
    18  ServiceManager-Launcher.dylib     0x0000000119b1cdaf Login + 1773
    19  ServiceManager-Launcher.dylib     0x0000000119b1b953 GetUserInfo2 + 257
    20  com.adobe.PlugPlug                0x00000001068582b6 csxs::servicemgr::api::ServiceManager::DoGetUserInfo(char const*, csxs::servicemgr::api::AMTProductCycleInfo) + 74
    21  com.adobe.PlugPlug                0x0000000106859264 csxs::servicemgr::api::ServiceManager::GetUserInfo(std::string&) + 30
    22  com.adobe.PlugPlug                0x000000010685adb0 csxs::services::csi::AsyncGetUserInfo::DoRun() + 122
    23  com.adobe.PlugPlug                0x00000001068598b7 csxs::services::csi::AsyncCall::Run() + 51
    24  com.adobe.PlugPlug                0x000000010686d5ae vcfoundation::thread::AbstractThread::Run() + 54
    25  com.adobe.PlugPlug                0x000000010686fb6d vcfoundation::thread::Thread::ThreadProc(void*) + 9
    26  libSystem.B.dylib                 0x00007fff84aca8b6 _pthread_start + 331
    27  libSystem.B.dylib                 0x00007fff84aca769 thread_start + 13
    Thread 6:
    0   libSystem.B.dylib                 0x00007fff84ad5286 select$DARWIN_EXTSN + 10
    1   com.apple.CoreFoundation          0x00007fff827e7ef2 __CFSocketManager + 818
    Thread 7:
    0   libSystem.B.dylib                 0x00007fff84aab30a __workq_kernreturn + 10
    1   libSystem.B.dylib                 0x00007fff84aab71c _pthread_wqthread + 917
    2   libSystem.B.dylib                 0x00007fff84aab385 start_wqthread + 13
    Thread 8:
    Thread 5 crashed with X86 Thread State (64-bit):
      rax: 0x0000000000000000  rbx: 0x0000000000000000  rcx: 0x00007fff84adf886  rdx: 0x0000000000000000
      rdi: 0x0000000000002710  rsi: 0x0000000000000006  rbp: 0x000000011e81b6a0  rsp: 0x000000011e81b688
       r8: 0x00007fff70a7ba00   r9: 0x000000011e81b932  r10: 0x00007fff84adb8ca  r11: 0x0000000000000206
      r12: 0x000000011e81b932  r13: 0x0000000000000067  r14: 0x0000000000000000  r15: 0x0000000000000021
      rip: 0x00007fff84b608c9  rfl: 0x0000000000010206  cr2: 0x00000001069cc800
    Binary Images:
           0x100000000 -        0x1026b5fff +com.adobe.Photoshop 12.0 (12.0x20100407.r.1103) (12.0) <B69D89E5-01DD-C220-48B1-E129D0574536> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/MacOS/Adobe Photoshop CS5
           0x103295000 -        0x10330dfef +com.adobe.adobe_caps adobe_caps 3.0.116.0 (3.0.116.0) <4A355686-1451-B19A-0C55-DFE49FD2539E> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_cap s
           0x103323000 -        0x10332afff  org.twain.dsm 1.9.4 (1.9.4) <D32C2B79-7DE8-1609-6BD4-FB55215BD75B> /System/Library/Frameworks/TWAIN.framework/Versions/A/TWAIN
           0x103332000 -        0x103342ff8 +com.adobe.ahclientframework 1.5.0.30 (1.5.0.30) <5D6FFC4E-7B81-3E8C-F0D4-66A3FA94A837> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
           0x10334d000 -        0x103353ff7  com.apple.agl 3.0.12 (AGL-3.0.12) <C8CBED46-DB62-3D5C-70BE-B6FD407223A8> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
           0x10335a000 -        0x103560fef +com.adobe.linguistic.LinguisticManager 5.0.0 (11696) <499B4E7A-08BB-80FC-C220-D57D45CA424F> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/Adob eLinguistic
           0x1035f3000 -        0x1037a1fef +com.adobe.owl AdobeOwl version 3.0.91 (3.0.91) <C36CA603-EFFB-2EED-6CEE-0B532CE052D2> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
           0x103843000 -        0x103c73fef +AdobeMPS ??? (???) <FA334142-5343-8808-7760-4318EB62AD51> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
           0x103dcd000 -        0x1040f8ff7 +AdobeAGM ??? (???) <52E17D56-6E7A-A635-82ED-5DE1F3E5045D> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
           0x1041c5000 -        0x1044edfe7 +AdobeCoolType ??? (???) <9E03F47A-06A3-F1F4-AC4C-76F12FACC294> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeC oolType
           0x104585000 -        0x1045a6ff7 +AdobeBIBUtils ??? (???) <F7150688-2C15-0F0C-AF24-93ED82FC321A> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeB IBUtils
           0x1045b3000 -        0x1045deff6 +AdobeAXE8SharedExpat ??? (???) <7E809606-BF97-DB3A-E465-156446E56D00> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A /AdobeAXE8SharedExpat
           0x1045f0000 -        0x104734fef +WRServices ??? (???) <76354373-F0BD-0BAF-6FC0-B96DBB371755> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/WRServices.framework/Versions/A/WRService s
           0x10477b000 -        0x1047e0fff +aif_core ??? (???) <12FA670E-05A8-1FCB-A7A2-AAE68728EA30> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/aif_core.framework/Versions/A/aif_core
           0x1047fc000 -        0x104812fff +data_flow ??? (???) <9C5D39A6-D2A2-9B6A-8B64-D1B59396C112> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/data_flow.framework/Versions/A/data_flow
           0x10482a000 -        0x1048c0fff +image_flow ??? (???) <B72AA922-0D68-D57E-96B1-2E009B0AD4AE> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/image_flow.framework/Versions/A/image_flo w
           0x104937000 -        0x104955fff +image_runtime ??? (???) <32786637-C9BF-4CB6-2DF9-5D99220E00BE> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/image_runtime.framework/Versions/A/image_ runtime
           0x104972000 -        0x104ba1fff +aif_ogl ??? (???) <615E7DF6-09B1-857A-74AC-E224A636BEE1> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/aif_ogl.framework/Versions/A/aif_ogl
           0x104c80000 -        0x104d13fff +AdobeOwlCanvas ??? (???) <EC667F6D-0BB6-03EA-41E8-624425B2BF4B> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeOwlCanvas.framework/Versions/A/Adobe OwlCanvas
           0x104d33000 -        0x10507cfef +com.adobe.dvaui.framework dvaui version 5.0.0 (5.0.0.0) <023E0760-0223-AB5D-758C-2C5A052F6AF4> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
           0x10520c000 -        0x10538efe7 +com.adobe.dvacore.framework dvacore version 5.0.0 (5.0.0.0) <42077295-9026-D519-C057-35E07029D97B> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
           0x105430000 -        0x1057a8fff +com.adobe.dvaadameve.framework dvaadameve version 5.0.0 (5.0.0.0) <0E95A0DF-038A-CFF2-EC7B-BDB905CDF5C5> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadamev e
           0x1058f2000 -        0x105a06fff +AdobeACE ??? (???) <E359887D-1E7F-5E62-CB8D-37CE4DBFB4D8> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
           0x105a2b000 -        0x105a47fff +AdobeBIB ??? (???) <7A792F27-42CC-2DCA-D5DF-88A2CE6C2626> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
           0x105a51000 -        0x105abbff7 +com.adobe.amtlib amtlib 3.0.0.64 (3.0.0.64) <6B2F73C2-10AB-08B3-4AB0-A31C83D1E5E0> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
           0x105aee000 -        0x105bc1ffb +AdobeJP2K ??? (???) <465D1693-BE79-590E-E1AA-BAA8061B4746> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
           0x105be1000 -        0x105be5ff8 +com.adobe.ape.shim adbeape version 3.1.65.7508 (3.1.65.7508) <0C380604-C686-C2E4-0535-C1FAB230187E> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
           0x105be9000 -        0x105c60fff +FileInfo ??? (???) <6D5235B9-0EB6-17CA-6457-A2507A87EA8F> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
           0x105c81000 -        0x105cdfffd +AdobeXMP ??? (???) <561026BB-C6EA-29CE-4790-CABCB81E8884> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
           0x105ced000 -        0x106188fff +com.nvidia.cg 2.2.0006 (???) /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/Cg.framework/Cg
           0x10670e000 -        0x106764feb +com.adobe.headlights.LogSessionFramework ??? (2.0.1.011) <03B80698-2C3B-A232-F15F-8F08F8963A19> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSessio n
           0x1067a9000 -        0x1067ceffe +adobepdfsettings ??? (???) <56E7F033-6032-2EC2-250E-43F1EBD123B1> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/adobepdfsettings.framework/Versions/A/ado bepdfsettings
           0x106808000 -        0x10680dffd +com.adobe.AdobeCrashReporter 3.0 (3.0.20100302) <DFFB9A08-8369-D65F-161F-7C61D562E307> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/A dobeCrashReporter
           0x106812000 -        0x1069adfff +com.adobe.PlugPlug 2.0.0.746 (2.0.0.746) <CB23C5AA-0E4B-182B-CB88-57DD32893F92> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
           0x106a55000 -        0x106a6efeb +libtbb.dylib ??? (???) /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/libtbb.dylib
           0x106a7f000 -        0x106a85feb +libtbbmalloc.dylib ??? (???) /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/libtbbmalloc.dylib
           0x106a8c000 -        0x106a8cff7  libmx.A.dylib 315.0.0 (compatibility 1.0.0) <B146C134-CE18-EC95-12F8-E5C2BCB43A6B> /usr/lib/libmx.A.dylib
           0x106a8f000 -        0x106a97ff3 +com.adobe.boost_threads.framework boost_threads version 5.0.0 (5.0.0.0) <6858DF5A-F020-22A7-B945-14EC277724D4> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_ threads
           0x106a9e000 -        0x106b84fe7  libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <26FC56A6-EFD6-22FA-E1F1-4E1BA61C85BB> /usr/lib/libcrypto.0.9.7.dylib
           0x106f52000 -        0x106f54fef  com.apple.textencoding.unicode 2.3 (2.3) <B254327D-2C4A-3296-5812-6F74C7FFECD9> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
           0x106ff1000 -        0x106ff2fff  libCyrillicConverter.dylib 49.0.0 (compatibility 1.0.0) <763A4C25-2E76-3F9B-BBC4-4A022F0360E0> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
           0x109059000 -        0x1090c9ff6 +com.adobe.amt.services AMTServices 3.0.0.64 (BuildVersion: 3.0; BuildDate: Mon Jan 26 2010 21:49:00) (3.0.0.64) <52FF1F9B-9991-ECE2-C7E3-09DA1B368CBE> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/amtservices.framework/Versions/a/amtservi ces
           0x1118e1000 -        0x1118f8fe7  libJapaneseConverter.dylib 49.0.0 (compatibility 1.0.0) <92A88D03-FABF-24D6-992A-19B023390FA1> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
           0x1118fc000 -        0x11191dfef  libKoreanConverter.dylib 49.0.0 (compatibility 1.0.0) <835A6BD9-EA17-57B7-17D6-08DC53EBA240> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
           0x111921000 -        0x111930fe7  libSimplifiedChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <727A0DD2-6866-5E0D-2AA5-43F5035D7130> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter. dylib
           0x111934000 -        0x111946fff  libTraditionalChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <F86B5994-BD36-2B87-2C4A-523668E29192> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter .dylib
           0x11194a000 -        0x111952fff +com.adobe.asneu.framework asneu version 1.7.0.1 (1.7.0.1) <3D59CB21-F5C7-4232-AB00-DFEB04206024> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/asneu.framework/Versions/a/asneu
           0x1119e5000 -        0x1119ecfff +Enable Async IO ??? (???) <9C98DC9E-5974-FE5D-75C3-16BC4738DCC8> /Applications/Adobe Photoshop CS5/Plug-Ins/Extensions/Enable Async IO.plugin/Contents/MacOS/Enable Async IO
           0x11336f000 -        0x113378fff +FastCore ??? (???) <F1D1C94D-4FE1-F969-6FC2-8D81837CA5E1> /Applications/Adobe Photoshop CS5/Plug-Ins/Extensions/FastCore.plugin/Contents/MacOS/FastCore
           0x113385000 -        0x1133e8ff3 +MMXCore ??? (???) <2DB6FA8E-4373-9823-C4F5-A9F5F8F80717> /Applications/Adobe Photoshop CS5/Plug-Ins/Extensions/MMXCore.plugin/Contents/MacOS/MMXCore
           0x11346e000 -        0x1134d9ff0 +MultiProcessor Support ??? (???) <1334B570-C713-3767-225F-3C1CBA1BF37C> /Applications/Adobe Photoshop CS5/Plug-Ins/Extensions/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
           0x115a4b000 -        0x115a67ff7 +MeasurementCore ??? (???) <0E3BE9B3-FF3D-78A6-38EC-5CB0828B80EB> /Applications/Adobe Photoshop CS5/Plug-Ins/Measurements/MeasurementCore.plugin/Contents/MacOS/Measu rementCore
           0x115ac7000 -        0x115ae7ffb +com.adobe.ape adbeapecore version 3.1.65.7508 (3.1.65.7508) <284C86BE-ACD8-31DD-E58D-544F581BC93B> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/adbeapecore
           0x115f00000 -        0x11615cfef +com.adobe.PSAutomate 12.0 (12.0) <35AEF3A8-2E64-71D1-39ED-A34760CAAC29> /Applications/Adobe Photoshop CS5/Plug-Ins/Extensions/ScriptingSupport.plugin/Contents/MacOS/Script ingSupport
           0x116372000 -        0x116416ffb +com.adobe.AdobeExtendScript ExtendScript 4.1.23 (4.1.23.7573) <332E7D8D-BF42-3177-9BC5-033942DE35E0> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/Ad obeExtendScript
           0x116478000 -        0x116518fef +com.adobe.AdobeScCore ScCore 4.1.23 (4.1.23.7573) <53DD7281-5B59-7FF5-DB57-C9FD60E524C7> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScC ore
           0x1165cf000 -        0x1165d3fff  com.apple.audio.AudioIPCPlugIn 1.1.2 (1.1.2) <4E3DABFF-191F-7E57-2A78-12E34D68FAC4> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/Aud ioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
           0x11676a000 -        0x116770fff  com.apple.audio.AppleHDAHALPlugIn 1.8.4 (1.8.4fc3) <106DABA7-C630-C839-50CE-60D5992E6091> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHAL PlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
           0x116775000 -        0x1167b3ff7  com.apple.DP.ScreenInputDevice 13.0 (13.0) <22174597-D163-7A20-C82A-C00C2CA19640> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Resou rces/AppleScreenInputDevice.plugin/Contents/MacOS/AppleScreenInputDevi ce
           0x116f00000 -        0x117d47fcf +com.adobe.adobeswfl ??? (2.0.0.7489) <DBD38111-48D6-C031-EF50-D034C94ED38B> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/Resources/AdobeSWFL.bundl e/Contents/MacOS/AdobeSWFL
           0x119244000 -        0x11926efef  com.apple.mio.DAL.VDC_4 130.0 (1035) <605498BB-69D1-09C2-2720-FC7FBE9C289E> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Resou rces/VDC.plugin/Contents/MacOS/VDC
           0x119ac2000 -        0x119afffeb +com.adobe.AAM.AdobeUpdaterNotificationFramework UpdaterNotifications 1.0.0.64 (1.0.0.64) <CD8BD7C7-0F66-29B6-C158-A6EF8DF69996> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/updaternotifications.framework/Versions/a /UpdaterNotifications
           0x119b1a000 -        0x119b42fef +ServiceManager-Launcher.dylib ??? (???) <4608E5E7-7F22-A4FF-527C-E97EA339FCCC> /Library/Application Support/Adobe/CS5ServiceManager/lib/ServiceManager-Launcher.dylib
           0x119e00000 -        0x11a598feb +com.adobe.CameraRaw 6.0 (6.0.0d205) <35A90E86-FBFE-D694-CAA7-C9471E98611A> /Library/Application Support/Adobe/Plug-Ins/CS5/File Formats/Camera Raw.plugin/Contents/MacOS/Camera Raw
           0x11de13000 -        0x11de2dfff +com.adobe.pip ??? (5.0.0.2021) <47380937-5088-41F7-50FA-ADAC9B15C783> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
           0x11de9a000 -        0x11e027fe7  GLEngine ??? (???) <85971DA9-5140-A226-7898-21B2D6C6F7FE> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle /GLEngine
           0x11e058000 -        0x11e47aff7  libclh.dylib 3.1.1 C  (3.1.1) <08830748-80A3-2928-BDC9-D5512BE2715C> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libc lh.dylib
           0x11e4a8000 -        0x11e4cefe7  GLRendererFloat ??? (???) <684EBDC4-63B4-BC55-60EF-0F6A7D666551> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat .bundle/GLRendererFloat
           0x11ffe3000 -        0x11ffe6fef  libLatinSuppConverter.dylib 49.0.0 (compatibility 1.0.0) <C13E084D-DF38-B1BC-9772-7B03428E7969> /System/Library/CoreServices/Encodings/libLatinSuppConverter.dylib
           0x121a9f000 -        0x121e16fec +com.adobe.standard.multiplugin 12.0 (12.0) <6A10EB0E-BAED-6911-C012-323995F1514D> /Applications/Adobe Photoshop CS5/Plug-Ins/Filters/Standard Multiplugin.plugin/Contents/MacOS/Standard Multiplugin
           0x12295b000 -        0x12297dff7  com.apple.URLMount.CIFSPlugin 4.0.0 (4.0.0) <7EC413B1-DEA3-A503-3628-F3B719E18839> /System/Library/Filesystems/NetFSPlugins/smb.bundle/Contents/MacOS/sm b
           0x122b0f000 -        0x123127fef +com.adobe.S4W 12.0 (12.0) <0F19BE78-94B0-7039-12C1-7ED3B8021369> /Applications/Adobe Photoshop CS5/Plug-Ins/Import-Export/Save for Web.plugin/Contents/MacOS/Save for Web
           0x200000000 -        0x2006c3fe7  com.apple.GeForceGLDriver 1.6.10 (6.1.0) <8946B71C-EA96-5AFA-B8B6-E9029EAF56CD> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeFo rceGLDriver
        0x7fff5fc00000 -     0x7fff5fc3bdef  dyld 132.1 (???) <B633F790-4DDB-53CD-7ACF-2A3682BCEA9F> /usr/lib/dyld
        0x7fff80020000 -     0x7fff80020ff7  com.apple.vecLib 3.6 (vecLib 3.6) <08D3D45D-908B-B86A-00BA-0F978D2702A7> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
        0x7fff80021000 -     0x7fff80065ff7  com.apple.ImageCaptureCore 1.0.1 (1.0.1) <788A9BF0-691B-FE10-7385-AF4A7A786478> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/Imag eCaptureCore
        0x7fff8008a000 -     0x7fff801a3fef  libGLProgrammability.dylib ??? (???) <9D2B1DA3-C581-73F8-A2E4-01C4CE1C3B32> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LProgrammability.dylib
        0x7fff801a4000 -     0x7fff80259fe7  com.apple.ink.framework 1.3.3 (107) <FFC46EE0-3544-A459-2AB9-94778A75E3D4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink .framework/Versions/A/Ink
        0x7fff802a7000 -     0x7fff80337fff  com.apple.SearchKit 1.3.0 (1.3.0) <4175DC31-1506-228A-08FD-C704AC9DF642> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/SearchKit.framework/Versions/A/SearchKit
        0x7fff8036e000 -     0x7fff8039efef  com.apple.shortcut 1.1 (1.1) <A99C9D8E-290B-B1E4-FEA5-CC5F2FB9C18D> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Short cut
        0x7fff803aa000 -     0x7fff803f9fef  libTIFF.dylib ??? (???) <D6BED22B-A092-EC70-6E1D-0B52FA6FBBDE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
        0x7fff803fa000 -     0x7fff803fbfff  liblangid.dylib ??? (???) <EA4D1607-2BD5-2EE2-2A3B-632EEE5A444D> /usr/lib/liblangid.dylib
        0x7fff80409000 -     0x7fff80444fff  com.apple.AE 496.4 (496.4) <CBEDB6A1-FD85-F842-4EB8-CC289FAE0F24> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/AE.framework/Versions/A/AE
        0x7fff8044e000 -     0x7fff80471fff  com.apple.opencl 12.1 (12.1) <AB00CB6B-5BBD-C819-007A-08C0B110AB93> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
        0x7fff80472000 -     0x7fff80512fff  com.apple.LaunchServices 362.1 (362.1) <2740103A-6C71-D99F-8C6F-FA264546AD8F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/LaunchServices.framework/Versions/A/LaunchServices
        0x7fff80513000 -     0x7fff80516ff7  libCoreVMClient.dylib ??? (???) <9A0E75A9-7964-CAF9-DEB7-11A073530F64> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC oreVMClient.dylib
        0x7fff80517000 -     0x7fff80575ff7  com.apple.framework.IOKit 2.0 (???) <516EB9AF-4723-FC17-984B-918115E53459> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
        0x7fff80576000 -     0x7fff80581ff7  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <F0DDF27E-DB55-07CE-E548-C62095BE8167> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Spe echRecognition.framework/Versions/A/SpeechRecognition
        0x7fff80582000 -     0x7fff805d7fef  com.apple.framework.familycontrols 2.0.1 (2010) <E6E1C44A-6513-92DF-F71E-C157C485024C> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A /FamilyControls
        0x7fff805d8000 -     0x7fff805eefff  com.apple.ImageCapture 6.0 (6.0) <5B5AF8FB-C12A-B51F-94FC-3EC4698E818E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ima geCapture.framework/Versions/A/ImageCapture
        0x7fff805ef000 -     0x7fff8061aff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <87A0B228-B24A-C426-C3FB-B40D7258DD49> /usr/lib/libxslt.1.dylib
        0x7fff8061b000 -     0x7fff8062fff7  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <621B7415-A0B9-07A7-F313-36BEEDD7B132> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
        0x7fff80630000 -     0x7fff80677fef  com.apple.QuickLookFramework 2.2 (327.4) <4E1658D4-F268-2A82-C095-1D01E9EAD05F> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
        0x7fff80678000 -     0x7fff80678ff7  com.apple.Carbon 150 (152) <8D8CF535-90BE-691C-EC1B-63FBE2162C9B> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
        0x7fff80679000 -     0x7fff8067aff7  com.apple.TrustEvaluationAgent 1.1 (1) <51867586-1C71-AE37-EAAD-535A58DD3550> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Vers ions/A/TrustEvaluationAgent
        0x7fff8067b000 -     0x7fff80761fe7  com.apple.DesktopServices 1.5.5 (1.5.5) <EFCBA7C3-A6CE-9550-FE19-73BB3D046549> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versi ons/A/DesktopServicesPriv
        0x7fff807bf000 -     0x7fff807c6fff  com.apple.OpenDirectory 10.6 (10.6) <72A65D76-7831-D31E-F1B3-9E48BF26A98B> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDir ectory
        0x7fff807c7000 -     0x7fff807cdff7  com.apple.DiskArbitration 2.3 (2.3) <857F6E43-1EF4-7D53-351B-10DE0A8F992A> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskA rbitration
        0x7fff807ce000 -     0x7fff807d6fff  com.apple.DisplayServicesFW 2.2.2 (251) <3E7C0CF8-117D-9C7F-577C-C199901DFF37> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/ A/DisplayServices
        0x7fff807d7000 -     0x7fff80818fef  com.apple.QD 3.35 (???) <78C9A560-E6F7-DC4F-F85E-E63CF8A98F0B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/QD.framework/Versions/A/QD
        0x7fff80819000 -     0x7fff808d6ff7  com.apple.CoreServices.OSServices 357 (357) <7CFA1963-B639-BE99-12F1-220DF214AB50> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/OSServices.framework/Versions/A/OSServices
        0x7fff808d7000 -     0x7fff80920fef  libGLU.dylib ??? (???) <FEDE662B-46B2-26D8-3E57-84E4C15A4FB2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LU.dylib
        0x7fff8097d000 -     0x7fff8097dff7  com.apple.Cocoa 6.6 (???) <68B0BE46-6E24-C96F-B341-054CF9E8F3B6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
        0x7fff8097e000 -     0x7fff80a3efe7  libFontParser.dylib ??? (???) <2C6B6ABB-7EF0-3CD8-97D2-9B4534D0056C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
        0x7fff80a3f000 -     0x7fff80a43ff7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <95718673-FEEE-B6ED-B127-BCDBDB60D4E5> /usr/lib/system/libmathCommon.A.dylib
        0x7fff80a44000 -     0x7fff80e87fef  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <0CC61C98-FF51-67B3-F3D8-C5E430C201A9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libLAPACK.dylib
        0x7fff80e88000 -     0x7fff810f1ff7  com.apple.QuartzComposer 4.1 (156.13) <0A7E8CDB-77DB-F96F-9CA4-867E9D45EB69> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qua rtzComposer.framework/Versions/A/QuartzComposer
        0x7fff810f2000 -     0x7fff81377fef  com.apple.security 6.1.1 (37594) <ED08CC62-42E2-E97F-E807-C09EB1CF950D> /System/Library/Frameworks/Security.framework/Versions/A/Security
        0x7fff81378000 -     0x7fff81378ff7  com.apple.ApplicationServices 38 (38) <10A0B9E9-4988-03D4-FC56-DDE231A02C63> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/A pplicationServices
        0x7fff81379000 -     0x7fff81444fe7  ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <C85548CF-DED1-4672-0167-3F32A6DD0D55> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/C olorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
        0x7fff81445000 -     0x7fff81445ff7  com.apple.quartzframework 1.5 (1.5) <B182B579-BCCE-81BF-8DA2-9E0B7BDF8516> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
        0x7fff814fc000 -     0x7fff81737fef  com.apple.imageKit 2.0.3 (1.0) <9F7CBDFB-EBDC-5B86-ED43-5195F4AE9D52> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Ima geKit.framework/Versions/A/ImageKit
        0x7fff81738000 -     0x7fff81738ff7  com.apple.CoreServices 44 (44) <210A4C56-BECB-E3E4-B6EE-7EC53E02265D> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServ ices
        0x7fff81739000 -     0x7fff81776ff7  libFontRegistry.dylib ??? (???) <12FDAEB9-01F7-5562-DBC6-7B2374CCAEA1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
        0x7fff81777000 -     0x7fff817dffff  com.apple.MeshKitRuntime 1.1 (49.2) <1F4C9AB5-9D3F-F91D-DB91-B78610562ECC> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Framew orks/MeshKitRuntime.framework/Versions/A/MeshKitRuntime
        0x7fff817e0000 -     0x7fff821d5fe7  com.apple.AppKit 6.6.5 (1038.29) <AC1ED9CC-6149-36EE-AA57-15BA4F05EAAA> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
        0x7fff821d6000 -     0x7fff821e1ff7  com.apple.HelpData 2.0.4 (34) <B44D2E2A-BC1E-CD63-F8A1-C9465491693A> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpD ata
        0x7fff82226000 -     0x7fff8225fff7  com.apple.MeshKit 1.1 (49.2) <3795F201-4A5F-3D40-57E0-87AD6B714239> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKi t
        0x7fff823cf000 -     0x7fff824e6fef  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <EE067D7E-15B3-F043-6FBD-10BA31FE76C7> /usr/lib/libxml2.2.dylib
        0x7fff824e7000 -     0x7fff824f6ff7  com.apple.opengl 1.6.7 (1.6.7) <63D8F554-2488-4811-EEC7-672FCFAF731B> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
        0x7fff824f7000 -     0x7fff82778fe7  com.apple.Foundation 6.6.2 (751.21) <49BEB8B8-BC1F-B4E4-3D90-A141AC764A8D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
        0x7fff82779000 -     0x7fff82779ff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <DA9BFF01-40DF-EBD5-ABB7-787DAF2D77CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/vecLib
        0x7fff8277a000 -     0x7fff828effef  com.apple.CoreFoundation 6.6.1 (550.19) <1051BA2C-DCD7-787C-907C-A50D12AA6049> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFo undation
        0x7fff8292d000 -     0x7fff82995fff  com.apple.AppleVAFramework 4.8.11 (4.8.11) <14AE8878-A7A6-D024-3DD4-BBFB5E7FC008> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleV A
        0x7fff82996000 -     0x7fff82a4cfff  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <F206BE6D-8777-AE6C-B367-7BEA76C14241> /usr/lib/libobjc.A.dylib
        0x7fff82a4d000 -     0x7fff82acffff  com.apple.QuickLookUIFramework 2.2 (327.4) <C35D9F62-73D0-262C-B0CE-BFF64E230588> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qui ckLookUI.framework/Versions/A/QuickLookUI
        0x7fff82e03000 -     0x7fff82e15fe7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <76B83C8D-8EFE-4467-0F75-275648AFED97> /usr/lib/libsasl2.2.dylib
        0x7fff83156000 -     0x7fff831a7fe7  com.apple.HIServices 1.8.0 (???) <1ABA7802-C1E4-06A0-9035-2792CC915BF6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/HIServices.framework/Versions/A/HIServices
        0x7fff831a8000 -     0x7fff831ddff7  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <0C865212-6427-5DE4-40C4-B5739491B691> /usr/lib/libcups.2.dylib
        0x7fff831de000 -     0x7fff8339cfff  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <1B6C3785-BE99-EAD5-69AB-B28C40466A82> /usr/lib/libicucore.A.dylib
        0x7fff8339d000 -     0x7fff836d0fef  com.apple.CoreServices.CarbonCore 861.6 (861.6) <652B1704-460F-F0D1-B917-B08698E0EF7F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CarbonCore.framework/Versions/A/CarbonCore
        0x7fff83721000 -     0x7fff83750ff7  com.apple.quartzfilters 1.6.0 (1.6.0) <9CECB4FC-1CCF-B8A2-B935-5888B21CBEEF> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qua rtzFilters.framework/Versions/A/QuartzFilters
        0x7fff83871000 -     0x7fff839e1fef  com.apple.MediaToolbox 0.484.5 (484.5) <DA4772AD-9430-024F-39FF-8B9D4B52DCD2> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/M ediaToolbox
        0x7fff839e2000 -     0x7fff83a9bfff  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <5A15E12A-AE8F-1A36-BBC7-564E7D7AD0FB> /usr/lib/libsqlite3.dylib
        0x7fff83b36000 -     0x7fff83b3cff7  IOSurface ??? (???) <F998C45A-CCCF-2306-F37A-389EE0054CB3> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
        0x7fff83b3d000 -     0x7fff83bc9fef  SecurityFoundation 36840.0.0 (compatibility 1.0.0) <B69E2FF9-A698-4923-BC8B-180224B6EF75> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/Se curityFoundation
        0x7fff83bca000 -     0x7fff83be0fef  libbsm.0.dylib ??? (???) <42D3023A-A1F7-4121-6417-FCC6B51B3E90> /usr/lib/libbsm.0.dylib
        0x7fff83be1000 -     0x7fff83c30ff7  com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) <14FD0978-4BE0-336B-A19E-F388694583EB> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A /PasswordServer
        0x7fff83c74000 -     0x7fff83db2fff  com.apple.CoreData 102.1 (251) <32233D4D-00B7-CE14-C881-6BF19FD05A03> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
        0x7fff83dbf000 -     0x7fff83ee4fef  com.apple.audio.toolbox.AudioToolbox 1.6.3 (1.6.3) <4DCCD01F-7516-4240-09DC-EE553317D345> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToo lbox
        0x7fff83ee5000 -     0x7fff83ee6fff  com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <5062DACE-FCE7-8E41-F5F6-58821778629C> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/M onitorPanel
        0x7fff83ee7000 -     0x7fff8427ffe7  com.apple.QuartzCore 1.6.1 (227.18) <ADB9E286-C5AB-3505-35D2-849E1F560A2A> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
        0x7fff84280000 -     0x7fff84463fef  libType1Scaler.dylib ??? (???) <98F6C486-4DA0-0903-CDC6-67C85ED206B2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib
        0x7fff84464000 -     0x7fff84468ff7  libCGXType.A.dylib 543.33.0 (compatibility 64.0.0) <27FF96BC-1F15-A52D-3339-4BFC49D6810E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dyl ib
        0x7fff84469000 -     0x7fff84476fe7  libCSync.A.dylib 543.33.0 (compatibility 64.0.0) <540820E4-75E3-B2A0-5EF2-222304250CD8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
        0x7fff84477000 -     0x7fff8448dff7  com.apple.MultitouchSupport.framework 204.12.1 (204.12.1) <38D0D705-FD15-38AE-A8B9-F9970508D1BD> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Version s/A/MultitouchSupport
        0x7fff8448e000 -     0x7fff8478cfef  com.apple.HIToolbox 1.6.2 (???) <759E1C39-58EB-C434-3E33-416C04AFE6DC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIT oolbox.framework/Versions/A/HIToolbox
        0x7fff8478d000 -     0x7fff84867ff7  com.apple.vImage 4.0 (4.0) <354F34BF-B221-A3C9-2CA7-9BE5E14AD5AD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vImage.framework/Versions/A/vImage
        0x7fff84868000 -     0x7fff84877fff  com.apple.NetFS 3.2.1 (3.2.1) <FF21DB1E-F425-1005-FB70-BC19CAF4006E> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
        0x7fff84878000 -     0x7fff84948fff  com.apple.CFNetwork 454.9.4 (454.9.4) <33395EDD-D653-6EAD-57A6-9C718D69D2DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CFNetwork.framework/Versions/A/CFNetwork
        0x7fff84949000 -     0x7fff8494aff7  com.apple.audio.units.AudioUnit 1.6.3 (1.6.3) <D4183AC4-8A65-8368-A9AF-E2A13D18519C> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
        0x7fff84a4c000 -     0x7fff84a8fff7  libRIP.A.dylib 543.33.0 (compatibility 64.0.0) <677BA546-F215-C5C8-9C65-305E43633FDA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
        0x7fff84a90000 -     0x7fff84c4fff7  libSystem.B.dylib 125.0.1 (compatibility 1.0.0) <CB9A4929-61AF-DE71-5635-133E9EC95783> /usr/lib/libSystem.B.dylib
        0x7fff84c62000 -     0x7fff84d71fe7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <826C2437-F760-E049-1719-9C69A3BAA4B0> /usr/lib/libcrypto.0.9.8.dylib
        0x7fff84d72000 -     0x7fff84dbaff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <170DE04F-89AB-E295-0880-D69CAFBD7979> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvDSP.dylib
        0x7fff84dbb000 -     0x7fff84dfefff  libtidy.A.dylib ??? (???) <8AF4DB3A-7BDB-7AF7-0E9C-413BBBD0E380> /usr/lib/libtidy.A.dylib
        0x7fff84dff000 -     0x7fff84e02fff  com.apple.help 1.3.1 (41) <54B79BA2-B71B-268E-8752-5C8EE00E49E4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Hel p.framework/Versions/A/Help
        0x7fff84e03000 -     0x7fff84e4aff7  com.apple.coreui 2 (114) <D7645B59-0431-6283-7322-957D944DAB21> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
        0x7fff84e5a000 -     0x7fff851d0fe7  com.apple.RawCamera.bundle 3.0.2 (527) <E70071D3-CC39-4B14-2AA3-EAC42BC84AD4> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamer a
        0x7fff851d1000 -     0x7fff856dafe7  com.apple.VideoToolbox 0.484.5 (484.5) <174EF984-21FE-071C-4AB4-DE345BF87791> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/V ideoToolbox
        0x7fff856db000 -     0x7fff8571cfff  com.apple.SystemConfiguration 1.10.2 (1.10.2) <7DADC459-6E38-084A-B333-8332B28C244E> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/S ystemConfiguration
        0x7fff85949000 -     0x7fff859b3fe7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <75A8D840-4ACE-6560-0889-2AFB6BE08E59> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvMisc.dylib
        0x7fff859b7000 -     0x7fff859c8ff7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <C1154E2E-B1CB-1FAD-77ED-B139BA1AB073> /usr/lib/libz.1.dylib
        0x7fff859c9000 -     0x7fff85a15fff  libauto.dylib ??? (???) <072804DF-36AD-2DBE-7EF8-639CFB79077F> /usr/lib/libauto.dylib
        0x7fff85a6f000 -     0x7fff85a71fff  com.apple.print.framework.Print 6.1 (237.1) <4513DB2F-737C-B43C-2D0E-23CD6E838014> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Pri nt.framework/Versions/A/Print
        0x7fff85a72000 -     0x7fff8627cfe7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) <FC941ECB-71D0-FAE3-DCBF-C5A619E594B8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libBLAS.dylib
        0x7fff862b3000 -     0x7fff869b0037  com.apple.CoreGraphics 1.543.33 (???) <359B3BC6-0152-94D2-3CAA-D8C24C0B9E65> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/CoreGraphics
        0x7fff869b1000 -     0x7fff86a30fff  com.apple.audio.CoreAudio 3.2.2 (3.2.2) <2633DFAC-F6A6-489D-8DF0-F12639CCD8C4> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
        0x7fff86a31000 -     0x7fff86a76fff  com.apple.CoreMediaIOServices 130.0 (1035) <6D6834F6-4DB5-03E9-3962-480BBEE176EB> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versi ons/A/CoreMediaIOServices
        0x7fff86ad8000 -     0x7fff86ae9fff  com.apple.DSObjCWrappers.Framework 10.6 (134) <3C08225D-517E-2822-6152-F6EB13A4ADF9> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A /DSObjCWrappers
        0x7fff86b0d000 -     0x7fff86b92fff  com.apple.print.framework.PrintCore 6.2 (312.5) <E736F6DC-2E69-A14D-6BCF-69D14232F8B8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/PrintCore.framework/Versions/A/PrintCore
        0x7fff86b93000 -     0x7fff86b98fff  libGIF.dylib ??? (???) <0E58DF99-B3DF-6FF9-E810-CCEC0853C8B0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
        0x7fff86b99000 -     0x7fff86d1ffe7  com.apple.JavaScriptCore 6531.22 (6531.22.5) <E33572F9-95E3-85D1-5B5E-2B240E3BF2B1> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaSc riptCore
        0x7fff86d9e000 -     0x7fff86ea8ff7  com.apple.MeshKitIO 1.1 (49.2) <F296E151-80AE-7764-B969-C2050DF26BFE> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Framew orks/MeshKitIO.framework/Versions/A/MeshKitIO
        0x7fff86ea9000 -     0x7fff86eabfff  libRadiance.dylib ??? (???) <73CE39EA-E38B-4320-8A7D-11C1A08A8A7A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
        0x7fff86eac000 -     0x7fff86ecafff  libPng.dylib ??? (???) <D0512FBF-911C-A9EC-465D-48A411509D6C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
        0x7fff86ed7000 -     0x7fff86f21ff7  com.apple.Metadata 10.6.3 (507.8) <A850E5A6-69D8-EBC1-B005-43F72B58EA36> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/Metadata.framework/Versions/A/Metadata
        0x7fff86fa9000 -     0x7fff86fbdfff  libGL.dylib ??? (???) <A85982AB-6395-DE2B-2023-F735093E663D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG L.dylib
        0x7fff86fbe000 -     0x7fff8703cfff  com.apple.CoreText 3.1.0 (???) <B740DA1D-EFD0-CCBF-F893-E3004FE58A98> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreText.framework/Versions/A/CoreText
        0x7fff8703d000 -     0x7fff870f2fe7  com.apple.ColorSync 4.6.3 (4.6.3) <0522B33D-F78A-9A46-1CB2-9073E4F8EFD8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ColorSync.framework/Versions/A/ColorSync
        0x7fff870f3000 -     0x7fff8711bfff  com.apple.DictionaryServices 1.1.1 (1.1.1) <9FD709FC-23F0-F270-EAC1-C590CD516A36> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/DictionaryServices.framework/Versions/A/DictionaryServices
        0x7fff8711c000 -     0x7fff871cbfff  edu.mit.Kerberos 6.5.9 (6.5.9) <42364D54-C647-14DE-2B1C-D94DAA03F092> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
        0x7fff871cc000 -     0x7fff871cfff7  com.apple.securityhi 4.0 (36638) <77F40B57-2D97-7AE5-1331-8945C71DFB57> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Sec urityHI.framework/Versions/A/SecurityHI
        0x7fff87245000 -     0x7fff873fffff  com.apple.ImageIO.framework 3.0.2 (3.0.1) <911FA1A5-7063-6A19-73D3-95B78A265524> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/ImageIO
        0x7fff87400000 -     0x7fff87400ff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <2BB7D669-4B40-6A52-ADBD-DA4DB3BC0B1B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
        0x7fff87440000 -     0x7fff874acfe7  com.apple.CorePDF 1.1 (1.1) <D47B2366-5D1B-147B-B1FA-C9FE36C4EFFF> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePD F
        0x7fff874ad000 -     0x7fff874f6ff7  com.apple.securityinterface 4.0.1 (37214) <F8F2D8F4-861F-6694-58F6-3DC55C9DBF50> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/Sec urityInterface
        0x7fff8750b000 -     0x7fff8754dfef  com.apple.CoreMedia 0.484.5 (484.5) <FF8F87CB-7087-A46F-D633-6A93054BDBA2> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/Core Media
        0x7fff8754e000 -     0x7fff87553ff7  com.apple.CommonPanels 1.2.4 (91) <4D84803B-BD06-D80E-15AE-EFBE43F93605> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Com monPanels.framework/Versions/A/CommonPanels
        0x7fff87f9d000 -     0x7fff87fabff7  libkxld.dylib ??? (???) <E685E658-C908-95B9-8D16-8153C1CE05D7> /usr/lib/system/libkxld.dylib
        0x7fff88001000 -     0x7fff88022fff  libresolv.9.dylib 40.0.0 (compatibility 1.0.0) <1AE68BBB-6536-125C-DE2A-13CA916D0EC4> /usr/lib/libresolv.9.dylib
        0x7fff88023000 -     0x7fff88192ff7  com.apple.QTKit 7.6.6 (1729) <CEDDAEA5-82F9-FF5D-B9AF-C68ACC1E3225> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
        0x7fff88193000 -     0x7fff8828bff7  libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <7E4ADB5A-CC77-DCFD-3E54-2F35A2C8D95A> /usr/lib/libiconv.2.dylib
        0x7fff88459000 -     0x7fff8845efff  libGFXShared.dylib ??? (???) <A2C80199-6076-3CBE-E418-E0AD0A3053DE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG FXShared.dylib
        0x7fff8845f000 -     0x7fff88490fff  libGLImage.dylib ??? (???) <7E8A6ED2-B093-0714-F65A-64ECC41187C4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LImage.dylib
        0x7fff888c0000 -     0x7fff888dbff7  com.apple.openscripting 1.3.1 (???) <FD46A0FE-AC79-3EF7-AB4F-396D376DDE71> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ope nScripting.framework/Versions/A/OpenScripting
        0x7fff88937000 -     0x7fff88999fe7  com.apple.datadetectorscore 2.0 (80.7) <F9D2332D-0890-2ED2-1AC8-F85CB89D8BD4> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Version s/A/DataDetectorsCore
        0x7fff8899a000 -     0x7fff88a17fef  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <35ECA411-2C08-FD7D-11B1-1B7A04921A5C> /usr/lib/libstdc++.6.dylib
        0x7fff88a18000 -     0x7fff88a49fef  libTrueTypeScaler.dylib ??? (???) <C15B0761-5136-BD0C-20F7-C8F8A95AF367> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
        0x7fff88a4a000 -     0x7fff88ae4fff  com.apple.ApplicationServices.ATS 4.2 (???) <E31469D3-A97D-63BB-FB00-05ACB2CEC561> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/ATS
        0x7fff88ae5000 -     0x7fff88afaff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <E83DAF4F-F284-BE0B-3D9D-D573023098B4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/LangAnalysis.framework/Versions/A/LangAnalysis
        0x7fff88b77000 -     0x7fff88b9cfe7  com.apple.CoreVideo 1.6.1 (45.4) <B1516554-88BC-CF1E-5409-BFF27A73D1AF> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
        0x7fff88b9d000 -     0x7fff88c2cfff  com.apple.PDFKit 2.5.1 (2.5.1) <7B8A187A-F0BB-44E7-FBD4-9E1C5F9D5E85> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDF Kit.framework/Versions/A/PDFKit
        0x7fff88c2d000 -     0x7fff88c53fe7  libJPEG.dylib ??? (???) <85902BC7-43AE-E202-0EEE-3C9996D00971> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
        0x7fff88c54000 -     0x7fff88c6dfff  com.apple.CFOpenDirectory 10.6 (10.6) <0F46E102-8B8E-0995-BA85-3D9608F0A30C> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Framewo rks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
        0x7fff88c6e000 -     0x7fff88c8eff7  com.apple.DirectoryService.Framework 3.6 (621.3) <EDCAF7ED-36E1-121F-D294-5CEBC1C34C5A> /System/Library/Frameworks/DirectoryService.framework/Versions/A/Dire ctoryService
        0x7fffffe00000 -     0x7fffffe01fff  libSystem.B.dylib ??? (???) <CB9A4929-61AF-DE71-5635-133E9EC95783> /usr/lib/libSystem.B.dylib
    Model: MacBookPro3,1, BootROM MBP31.0070.B07, 2 processors, Intel Core 2 Duo, 2.2 GHz, 4 GB, SMC 1.16f11
    Graphics: NVIDIA GeForce 8600M GT, GeForce 8600M GT, PCIe, 128 MB
    Memory Module: global_name
    AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x87), Atheros 5416: 2.0.19.10
    Bluetooth: Version 2.3.1f4, 2 service, 19 devices, 1 incoming serial ports
    Network Service: AirPort, AirPort, en1
    PCI Card: pci168c,24, sppci_othernetwork, PCI Slot 5
    Serial ATA Device: FUJITSU MHW2160BHPL, 149.05 GB
    Parallel ATA Device: HL-DT-ST DVDRW  GSA-S10N
    USB Device: Bluetooth USB Host Controller, 0x05ac  (Apple Inc.), 0x8205, 0x1a100000
    USB Device: Built-in iSight, 0x05ac  (Apple Inc.), 0x8502, 0xfd400000
    USB Device: Apple Internal Keyboard / Trackpad, 0x05ac  (Apple Inc.), 0x021a, 0x5d200000
    USB Device: IR Receiver, 0x05ac  (Apple Inc.), 0x8242, 0x5d100000
    Adobe Employee
    May 14, 2010 9:28 PM
    Service Manager crash on quit -- seems to be caused by a permissions problem (according to the service manager team), and we know that sometimes the installer has problems assigning the correct permissions.
    The Service Manager team is supposed to be working on a way to patch permissions, and a fix to their code.
    Community Member
    May 15, 2010 7:23 PM
    it looks like adding myself to the sharing/permission and giving read/write permission for
    fixed the problem
    Community Member
    May 15, 2010 9:45 PM
    Like everyone else on here, I'm getting the same error and crashes with PS CS5 on Mac Pro with 32Gig of RAM.  Please send us a fix ASAP.  As of right now it is useless software we have paid for.
    Adobe Employee
    May 15, 2010 10:06 PM
    Please read the existing answers before posting.
    You didn't even tell us WHICH error or crash you're seeing.
    Community Member
    May 15, 2010 10:15 PM
    This seems lame but sorry to say I'm having a problem finding how to address the 'permissions' problem.
    Is there a link to a fixit or just plain "here's how it works" site on that?
    Thank you.
    Community Member
    May 15, 2010 10:27 PM
    I've read every answer before responding.  Why the hostile response?
    PS CS5 says my Nvidia GTX 285 card doesn't meet minimum standard and
    will not do Open GL/CL, yet It is listed as meeting standards on the
    Adobe requirements.
    It says it cannot save my preferences and Open GL is grated out.  It
    then crashes and says it can't save my preferences.  I'm just trying
    to get my $2500 investment in CS5 Master Collection to work.
      I appreciate any help you can provide but don't be hostile to those
    seeking solutions.
    Dave
    Community Member
    May 15, 2010 10:45 PM
    Adobe requirements.
    seeking solutions.
    Dave
    don't take it personally videobuddy, this release has had alot of issues, some trade offs, and one brilliantly stupid installation flaw which is kind of embarrassing and has made alot of people rather angry. by all accounts chris is a good guy just trying to gather all the data he can to get this fixed, but i imagine things are a bit fraught in the bunker right now!
    Community Member
    May 15, 2010 10:46 PM
    I believe here are a whole lot of permissions problems occuring here, and I agree with others that this is not acceptable for software product like this.
    In any case I have solved the permission problem of CS5 not being able to save your preferences on exit. You need to add read/write permissions to
    /users/<your username>/library/preferences/adobe.
    To change permissions of a folder, right-click on that folder, select Get Info, then click the lock on the bottom, enter your password.
    Then select a + to add yourself with read/write permissions if you don't have them.
    Unfortunatly I believe there are other permission problems at play here as well, that also need to be fixed.
    You should NOT have to add yourself to any permissions in the ~/library  folder. This is a system folder.
    Adobe Employee
    May 16, 2010 3:21 AM
    That wasn't hostile.
    That was simply pointing out your mistakes and lack of information.
    The only thing I know that makes Macintosh OpenGL fail is having multiple mismatched video cards or using the Intel integrated chipset.  MacOS OpenGL only works with matching video cards.  And the Intel graphics chipset is just underpowered. (oh, and certain video cards that just don't work: like the old 7300GT)
    The preferences file is in /Users/<yournamehere>/Library/Preferences/Adobe Photoshop CS5/...
    (or ~/Library/Preferences/... for folks familiar with Unix)
    Adobe Employee
    May 15, 2010 11:07 PM
    /Library is a system folder
    ~/Library is inside your user directory, as indicated by the ~ character (which resolves to your user's home directory).
    Community Member
    May 15, 2010 11:46 PM
    Thank you for that but the question remains that in some cases the "permissions" don't seem to be functioning as they SHOULD so I was just seeking a place where I could find a better understanding of what we are discussing to help me spot the problems.
    Perhaps there is no way to find that.
    Community Member
    May 16, 2010 12:48 AM
    you may check here
    http://driverscat.com/photoshop.aspx  may help you out
    Community Member
    May 16, 2010 9:17 AM
    I had all these errors and crashes, and I have been using Photoshop CS5 for a couple of days now with no problems, starting and quitting many times. MacBook Pro 10.6.3. Here's what I did:
    *  Uninstalled Photoshop CS5 and all previous versions of Photoshop. Used the appropriate uninstall programs -- did not rely on dragging files to the trash. I had saved  a copy of my former Presets (brushes, actions, etc.) that I wanted to use with the new version.
    *  Created a new Test user account. I left the password area blank; kept it simple. If you don't know how to do this, here's how: http://docs.info.apple.com/article.html?path=Mac/10.6/en/8235.html
    *  Logged out and logged in as Test user.
    *  Installed the program from the CD within the Test user account. Made sure to install it in the system-wide Applications area (under the name of your hard drive) so it can be used by any user on the computer.
    *  Used Get Info to change permissions on all the Adobe files and folders listed by another writer above to Read/Write for Everyone.
    *  Opened PS CS5, created and saved a new document size preset, put some type into a dummy document, saved the doc.
    *  Quit -- no crash.
    *  Reopened program; document and preset (a change to preferences) had been saved.
    *  Logged out and logged back in to my regular user account.
    *  After another fine start and quit, I moved all my former brush folders and actions into the CS5 Presets folders.
    *  Everything has been working fine ever since.
    Community Member
    May 16, 2010 8:03 PM
    Thank you clstern for that good detail. Seems very different from the instructions passed along by Adobe.
    I've been noticing a lot more problems from folks using Snow Leopard than I see from old Leopard where I'm still parked.
    Wonder if there are some internal CS5 differences with Leopard 10.5.8 a few different problems to go with them.
    Community Member
    May 16, 2010 8:20 PM
    i'm hoping there'll be some improvement with the graphic driver update in 10.6.4. 10.6.3 seemed to make alot of open gl stuff unpredictable and i found in the past that gpu freakyness in general would make cs4 unstable
    Community Member
    May 16, 2010 9:01 PM
    Thanks.  That worked perfect for me and now everything works as it should.
    Community Member
    May 18, 2010 6:25 PM
    Hey Everybody,
    Let's focus on this first. How the hell can Adobe miss this after ALL THE YEARS THEY HAVE BEEN RELEASING PRODUCTS FOR OSX!!!
    Unforgiveable...
    Now to the first solution for the inherent problems with the installation, more to come on the problems within the applications later.
    Fix the permissions on the Library/Application Support/Adobe, User/Library/Application Support/Adobe, User/Library/Preferences and User/Applications by selecting the folder itself, adding your user and allowing read/write permissions and then Apply to Enclose Items
    This will change the permission for all items that Adobe somehow missed if they beta tested on anyone's system before release...
    Really poor programming and customer support.
    Community Member
    May 18, 2010 6:29 PM
    Can anyone tell us if Adobe is a.) aware of this problem and,
    b.) doing anything about it and,
    c.) the schedule for getting CS5 back to expectations?
    Thank you
    Adobe Employee
    May 18, 2010 7:38 PM
    a) and b) - read the existing posts in the topic
    c) nope, not yet.
    Community Member
    May 18, 2010 8:04 PM
    It gets worser and worser (and yes, I do speak English).  I fixed the permissions problem by following the instructions provided in this thread.  The good news is PS CS5 will now open and close properly and it recognizes my Nvidia GTX 285 Video card as being adequate as a GPU for working with PS CS5.  The bad news is the permissions fix also locked me out of my three disk RAID attached to my Apple RAID card, which just happens to be where all of my audio, video, and photographs are.  I have the same question you are now asking, "How can that possibly be true?"  So far, Apple's only solution to fixing the problem is to trash the RAID and rebuild it.  They have never seen anything like this happen before.  Disk Utilities and RAID utilities see the disk and everything I run on it says everything is OK, but there is a small "lock" icon on the disk icon and it will not allow me to see what is on the RAID disk.  I suppose this problem could get worse, but I'm having a hard time imagining how.  I will probably start all over tomorrow and rebuild everything from scratch.  Something tells me this version of the Creative Suite was not fully vetted and beta tested.  We are at least part of the beta testers and I'm about to lose dozens of hours rebuilding everything to add to the many hours already lost in this mess.
    Community Member
    May 18, 2010 8:15 PM
    Maybe others can confirm, but it appears this problem only seems to occur
    for those users with past Photoshop installs. From what I have seen, it the
    system has NEVER had an Photoshop install, it seems to work OK.  Is this
    what others are seeing?  This has been my experience.
    Still no excuse for this.
    Community Member
    May 18, 2010 8:17 PM
    Even at my modest hourly rate, I've wasted more billable time fixing CS5 than it cost for the "upgrade."
    These forums seem to be the only way Adobe has found to be notified of problems but they are insufficient when most of the acknowledged problem fixes came from other customers. Or am I missing something, Chris?
    Community Member
    May 18, 2010 8:25 PM
    OK new wrinkle. I've found this in the console log entry:
    5/18/10 7:09:41 PM [0x0-0x44044].com.adobe.flash[533] 2010-05-18 19:09:41 : ERROR vcfoundation::system::VCAccessDenied: open('logs/CS5ServiceManager_native.log', 1545) failed <13: Permission denied>
    Adobe has an application running in background called CS5 Service Manager and this is generating hundreds of errors for all their apps in the background probably causing the app hangs and crashes. It's is related to permission access to a log file. Just one other missed item during Adobe extensive beta testing on Snow Leopard. (OK, they didn't do a lot of testing, heck their are bills to pay and pockets to line.)
    Community Member
    May 18, 2010 8:28 PM
    Ano,
    A professional software company would have put betas out in all likely environments. If Adobe did that, they have managed somehow to avoid anything that might have been learned from installing CS5 into a CS4-running system. The variety of "advice" given those with different problems with CS5 is very worrisome. Adobe tech support is quoted as saying 4 and 5 co-exist just fine but also advising uninstall of cs4, new install of cs5, etc. So it can't be true both ways.
    It's interesting to note the heavy emphasis on these free "trial versions." Makes me wonder if the buyer base is so leary of new releases that a substantial number now wait for all -- or some -- of the bugs to get worked out before buying. That's this old cowboy's strategy next time! And now I see that those of us who paid for the upgrade on announcement day in early April are seeming to play second fiddle to those who are struggling with "trial" versions. In other words, no express service for the paying customers that one would expect from a civilized company.
    Community Member
    May 18, 2010 8:27 PM
    Yes this is an "upgrade" problem. If the permissions had been set to copy those of the corresponding folders from CS4 there would be no problems. As it is I'm still debugging the CS5 Service Manager as we speak.
    Community Member
    May 18, 2010 9:10 PM
    CS5 Upgrade Path:
    Well most of the struggle is behind me. This is a HUGE permissions clusterf*ck and there are some other significant let downs but hey, its Adobe!
    1. Use a utility such as BATCHMOD to change and repair permissions. These are the areas to work with but may not be limited to these alone. I did enable viewing hidden files and had my console close at hand to monitor the progress.
    • User/Library/Adobe
    • User/Library/Preferences < all Adobe Preferences >
    • Applications < All Adobe Applications >
    You will need to add the User/Administrator for your computer to the ACL list and then apply those permissions to all the enclosed items. That should allow all the CS applications to write the necessary files in the appropriate locations.
    But, you will lose your workspaces, your custom actions, styles etc. Those can be found in the CS4 (3) folders and copied to the corresponding CS5 folders. The Adobe Extension manager will allow you to import the extensions you have loaded from previous versions.
    I imagine that Adobe is letting us do a lot of the beta testing ourselves. Hey I only lost a half a day! Hooray...
    Solved on a Mac
    Community Member
    May 18, 2010 9:11 PM
    Believe me, I'm not defending them.
    Community Member
    May 18, 2010 9:18 PM
    Actually I WASN'T performing an upgrade install, I was installing FULL copy, it just so happens that I had previously attemted to install CS2, which never so much as ran, but apparently it was enough to screw up this install.
    In any case I think Adobe needs to invest a bit more in quality control on the Mac platform.
    Adobe Employee
    May 18, 2010 9:31 PM
    Yes, you're missing the many employees posting fixes and working with customers to diagnose the problems.  (some of whom failed to get employee labels on their AdobeID account)
    Technical Support is also gathering reports of problems, and possible solutions.
    User submitted bug reports also help, when they include contact info so we can get in touch and help solve the issue.
    The crash reporter system is gathering data, and we have created bug reports from those and assigned them to engineers to investigate.
    You're seeing less than 5% of the troubleshooting going on.
    Community Member
    May 18, 2010 9:41 PM
    Franssen,
    You have earned a very enthusiastic note of appreciation for your detailed work. Alas, it's wasted on this old cowboy because the technical aspects of this mess are beyond my ken. In the "good old days" I was a programmer but the issues involved in 'service managers' and 'permissions' and using and repairing damage is just not possible. When you are 75 I hope you can still do it!
    The arrogance of a monopoly such as Adobe holds in the creative suite functions -- if history is consistent -- will attract competition sooner or later. It's already 'later' for me and I hope Google gets busy or another group and they take the trouble to coordinate the various elements of a new creative software package. That similar functions are treated differently in their commands as you switch from Illustrator's needs to InDesign and over to Photoshop and I can't tell you how nervous I am that one day I'll have to use Flash. Perhaps by that time a truly unifying concept will be in charge and the suite that results will be far more powerful with much less grief and probably be available for half the price to a waiting and friendly customer base. They might even give you a free copy for being a beta tester and I bet there are those on this board who think that's a new idea.
    There is possibly what seems to be competition between various groups, the constituency of programmers that 'owns' the different parts of the suites. That's why we have this problem with what should have been TASK ONE, thinking of successfully about installing the new code before you get too busy with the 'goodies' to take care of it properly and -- as a result -- the new stuff doesn't work.
    Community Member
    May 18, 2010 9:39 PM
    Chris,
    You are right that there are probably hundreds of forum posts, blogs and sites posting the fixes and work arounds. What is being said is that Adobe should have been aware of this problem — this is a simple problem. And there are many other small problems as well that are vexing like the loss of settings and customization. Plus the upgrade is not something that I believe we will be raving about. $600 and more is big outlay but more than that we would like for Adobe to be a bit more "Mac friendly" after all we were the original developers for the software. I feel like they've migrated to the Windows world and have neglected the Mac lately. Here's hoping they jump on the bandwagon but of course... we have to work out the kinks with Flash/HTML5 for now.
    Adobe Employee
    May 18, 2010 9:40 PM
    (OK, they didn't do a lot of testing...)
    5000 users over a year and a half wasn't a lot of testing?
    Wow.
    This permissions bug appeared after beta testing was completed, and before we shipped the builds to customers -- sometime during the suite integration of the installers.   We're still trying to figure out what went wrong.    We have many people working on a short term solution, and on long term fixes.
    Stop with the insults and either help other users solve their problems, or sit back and wait for a fix.
    Community Member
    May 18, 2010 9:58 PM
    Well, looks like I'll be one of the "sit back and wait for the fix" types since I'll spend the next two days rebuilding my system since this entire mess has trashed it top to bottom.  I'll be watching the mailbox for a new set of CS5 Master Collection install disks sometime down the road.  This time, I'll wait a week or so to see how the new set of installation disks works for others before being a "guinea pig."  There are several features I really need in CS5, but the lost time can never be made up.  As an engineer and developer, I've always followed the rule of not being the first to jump on a new product...until now.  Man, I hate it when I have to tell students and coworkers how stupid I was to not follow my own advice.
    I don't mean this as an insult, because I agree that insults will get us nowhere in solving the problem.  However, how can something this big sneak by 5000 users (beta testers?) over year and a half and not be isolated?  Something doesn't jive.
    Adobe Employee
    May 18, 2010 10:01 PM
    Read what I said.
    After beta testing is completed, the installer team finalizes things for the suite installers.  Somewhere in that process (AFTER beta testing), this bug was introduced.
1 2 Previous Next
Actions
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
