Abdlah
Powerful SMS Server?
May 3, 2010 3:31 AM
Hello, I am wondering is Coldfusion 9 is a good product for developing an election tracking system, where results from over 22000 polling stations are send in via SMS.
Since I have not found any information on who much information the SMS gateway can process per minute/ per second, I a not able to decide whether is would be able to handle the job.
Any insights would be much appreciated.
    May 3, 2010 6:33 AM   in reply to Abdlah
    That would most probably be because those numbers would depend greatly on the hardware you install CF on and how you write your CFML SMS application.  I am sure a ColdFusion application could be created that would handle that load.  I can't tell you how much hardware|licenses it would take as that would require an applciation to load test against to find out.
    May 3, 2010 10:56 AM   in reply to Abdlah
    we've crushed SMS aggregators sending from 1 cf7 server (using the asynch
    gateway). cf9 is even more ruthless if your network is up to it & your cf &
    db servers are beefy enough, you should be able to handle 22k SMS but consider
    the followng:
    besides h/w & network latency, throughput is going to depend on your app's logic
    (processing, synch vs asynch, etc.) & more importantly on the SMS provider--even
    some of the more reliable/costly ones still need 400-500ms per SMS.
    so i would worry more about the SMS provider especially if you go for one of the
    cheaper ones. besides the obvious issues w/the low cost ones, note that
    currently cf only does transceiver binding which some of the really cheap ones
    won't support.
    btw this wouldn't happen to be in ghana? i seem to recall something about SMS &
    elections 1-2 years ago on these forums.
