I needed to keep CS4 as my "working" copy of InDesign since all others in our office use it. When I loaded CS5, it defaults to opening all of my files on my Mac. I want to open the files in CS4 when I double click them. I know I need to change this in the Info pane, but it keeps reverting to CS5 as the default (yes, I unlocked it also). Is CS5 doing something to lock the file type? It's just a pain to right click and open with on every file I open.
Any help appreciated... FYI, very experienced user (not novice) but stumped on this one. Actually tried downloaded software also, no go.
Not sure I like this.
It's because Adobe made the decision to keep the file types unchanged -- even though the files are not compatible along the different versions (although I have no idea how other applications handle this).
Try Soxy: http://www.rorohiko.com/wordpress/2010/03/15/soxy-1-1-3-released-for-m ac-os-x-and-windows/
Thanks for the quick reply, it is really appreciated. However, adding another program is really not the answer I'd use (especially purchasing one). Seems like a dumb thing to do on Adobe's part, but that wouldn't be the first time.
Again, I thank you for your help. Maybe someone will come up with another solution, if not, I'll just have to deal with it.
Have a great day!
The full version of Soxy sounds awesome (I only have CS4 installed, so I simply don't need it
An older version, just for InDesign, was free -- and perhaps it will work with CS5 as well! Try http://www.rorohiko.com/wordpress/2008/11/13/recipe-making-mac-os-x-la unch-the-correct-version-of-indesign/
You could probably get by with RC Default apps too if you just want to make one version of indesign be the default. Soxy looks like it can do a lot more.
http://www.rubicode.com/Software/RCDefaultApp/
It's pretty darn good and also great for keeping preview's fingers off your files. Never used Soxy, but there is a similar product in JoJo by the guy who makes up for QuarkXPress' pathetic inability to export a competent pdf of multiple eps files without hitting "save as eps…" 400 hundred times in a catalog. If you have just a handful of people JoJo may be a better solution, or at least one to consider. It is only available as a 4 seat minimum order for 29 euros.
FWIW I can run both CS3 and CS4 on my machine, OS 10.57. It will always open files (by double clicking them) in CS3 ONLY if I have started CS3 FIRST, and then started CS4. If I open CS4 first then that is the "default" InDesign that is used. So this isn't an official workaround, it just works for me.
A stable beta of the Soxy that supports CS5 has gone up on our web site - check it out at
http://www.rorohiko.com/wordpress/downloads/lightning-brain-soxy/
Download links are way at the bottom of the page - for CS5 support you want the 1.2.0b2 version.
Cheers,
Kris
I'm suffering from the same problem and it's very fustrating. I use CS3 because my entire work uses that workspace for reasons I wont go into, but I use everything else in CS5.
If I accidently open the file in CS5 and save it, all hell breaks loose because no one can open the file in CS3 again.
Changing the 'open with' was a very basic way of fixing that. I'd love to know if anyone has a work around that doesnt mean installing more programs.
