TypeError: Error #1010: A term is undefined and has no properties.
May 4, 2010 11:40 AM
Hello,
Having a bit of trouble with some AS3.  Any help you can provide would be very appreciated.
Error:
Code:
var soundReq:URLRequest = new URLRequest("audio05.mp3");
var sound:Sound = new Sound();
sound.load(soundReq);
sound.addEventListener(Event.COMPLETE, onComplete);
function onComplete(event:Event):void
sound.play();
var mySoundChannel:SoundChannel;
var isPlaying:Boolean = false;
var pos:Number = 0;
play_btn.addEventListener(MouseEvent.CLICK, play_);
function play_(event:Event):void
if (!isPlaying)
mySoundChannel = sound.play(pos);
isPlaying = true;
pause_btn.addEventListener(MouseEvent.CLICK, pause_);
function pause_(event:Event):void
if (isPlaying)
pos = mySoundChannel.position;
mySoundChannel.stop();
isPlaying = false;
stop_btn.addEventListener(MouseEvent.CLICK, stop_);
function stop_(event:Event):void
if (mySoundChannel != null)
pos = 0;
isPlaying = false;
var rectangle:Rectangle = new Rectangle(0,0,48,0);
var dragging:Boolean = false;
volume_mc.mySlider_mc.addEventListener(MouseEvent.MOUSE_DOWN, startDragging);
function startDragging(event:Event):void
volume_mc.mySlider_mc.startDrag(false,rectangle);
dragging = true;
volume_mc.mySlider_mc.addEventListener(Event.ENTER_FRAME, adjustVolume);
function adjustVolume(event:Event):void
var myVol:Number = volume_mc.mySlider_mc.x / 48;
var mySoundTransform:SoundTransform = new SoundTransform(myVol);
mySoundChannel.soundTransform = mySoundTransform;
stage.addEventListener(MouseEvent.MOUSE_UP, stopDragging);
function stopDragging(event:Event):void
if (dragging)
dragging = false;
volume_mc.mySlider_mc.stopDrag();
Thank you,
~AMH~
  • kglad
    Jul 21, 2002
    May 4, 2010 11:48 AM   in reply to ~AMH~
    click file/publish settings/flash/ and tick "permit debugging".  retest.
    copy and paste the error message and highlight or otherwise indicate the line of code mentioned in the error message.
  • kglad
    Jul 21, 2002
    May 4, 2010 1:39 PM   in reply to ~AMH~
    then volume_mc.mySlider_mc doesn't exist when that line of code executes.
    check for typos first.  if you see none, just above that line 51 use:
    trace(volume_mc.name);
    for(var i:uint=0;i<volume_mc.numChildren;i++){
    trace(volume_mc.getChildAt(i).name);
  • kglad
    Jul 21, 2002
    Jun 8, 2010 2:06 PM   in reply to ~AMH~
    1 month later is not much of a priority.
    anyway, something on line 79 of frame 1 doesn't exist when your code executes.
    Jul 4, 2012 11:22 AM   in reply to ~AMH~
    At this line,
    add the line:
    trace("Volume MC Slider: " + volume_mc.mySlider_mc);
    If I'm correct this will come up as "null". Odds are, your slider is not named mySlider_mc or it is perhaps nested in another MovieClip.
