surferstylee
Convert pdf to word .doc without frames
Jan 22, 2009 4:09 PM
I have some users who I recently upgraded to Adobe Acro 8 and are now having issues with pdf's that they are converting to word documents. The problem is that each paragraph and/or line is contained within FRAMES. Now I can remove the frames from Word but every method destroys the formatting and on a 500 + page legal document . . . . well, you get the picture.
They are then trying to merge and compare from withing word which crashes when comparing/merging a framed and unframed document.
Any ideas on how to keep this from happening during conversion?
    Community Member
    Jan 23, 2009 12:51 PM
    Hello surferstylee,
    Thank you for your post.
    You should know that these forums are specific to the Acrobat.com website and conversion using its set of hosted services, and do not cover the Acrobat family of desktop products.
    Any questions related to the Acrobat family of desktop products would be best suited in the Acrobat Forums:
    http://www.adobeforums.com/cgi-bin/webx/.3bbeda8b/
    Pete
    Feb 23, 2009 3:06 PM
    OK - here's my issue:
    1) PDF document - originally converted form Word document.
    2) Verion 9 Acrobat - converts document, but document has tables in it (word created) - drops the data from the tables, but brings the tables over.
    3) PDF converted to Word in verion 8, from another PC, and no issue - EU doing this - tried version 9 on 2 pcs with same result - so now need to see why 9 is having an issue when ver 8 is not.
    Community Member
    Feb 24, 2009 12:33 PM
    Hi Franinlv,
    Your post is also an Acrobat 9 posting/question. Thanks for posting, but you would probably benefit most from posting to that link I posted above...
    Here it is again -- Link to Acrobat Forums
    Pete
    Community Member
    Aug 23, 2009 11:28 PM
    Hi, do your pdf is contains tables? If so, the generated word file is with frames.
    If not, you may try to convert pdf to word using anybizsoft pdf to word converter. The conversion quality is good without frames and text boxes.
    You may have a free trial.
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
